    4. Rpc Adapter: Unterstützung für HmIP-SWDO-I fehlt
      holgerwolf last edited by
      Hier die Meldungen aus dem Log:
      host.lemaker	2017-10-27 15:32:24.363	info	object change system.adapter.hm-rpc.2
      hm-rpc.2	2017-10-27 15:32:24.219	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"MIN":"CLOSED","UNIT":"\"\"","OPERATIONS":5,"MAX":"OPEN","FLAGS":1,
      hm-rpc.2	2017-10-27 15:32:24.215	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SWDO-I.SHUTTER_CONTACT.1"
      hm-rpc.2	2017-10-27 15:32:24.126	info	xmlrpc -> getParamsetDescription ["xxxxxxxxxxxxxxxxx:1","VALUES"]
      hm-rpc.2	2017-10-27 15:32:23.470	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SABOTAGE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"SABOTAGE",
      hm-rpc.2	2017-10-27 15:32:23.468	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SWDO-I.MAINTENANCE.1"
      hm-rpc.2	2017-10-27 15:32:23.260	info	xmlrpc -> getParamsetDescription ["00109709xxxxxx:0","VALUES"]
      hm-rpc.2	2017-10-27 15:32:23.144	warn	No image for "HmIP-SWDO-I" found.
      Wenn weitere Infos benötigt werden, bitte melden.
      Holger
      geändert: Code in Code-Tags; Homoran (Mod)
      • Dutchman
        @holgerwolf:
        Holger
        geändert: Code in Code-Tags; Homoran (Mod) `
        Issue auf git erstellt sobald Bluefox es sueht und Zeit hat fix er es bestimmt, werde Post dann Updaten 🙂
        https://github.com/ioBroker/ioBroker.hm-rpc/issues/48
        Send from mobile device
        DutchmanNL created this issue in ioBroker/ioBroker.hm-rpc
        closed Send this info to developer : hm-rpc.meta.VALUES.HmIP-SWDO-I.SHUTTER_CONTACT #48
