    4. Proxmox
    5. Certificate verification failed.
    • G
      guitardoc last edited by
      Beim Update auf Trixie hab ich einen Fehler:
      root@proxmox:~# apt update
      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 http://download.proxmox.com/debian/ceph-squid trixie InRelease
      Ign:5 https://download.proxmox.com/debian/pve trixie InRelease
      Err:5 https://download.proxmox.com/debian/pve trixie InRelease
        Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 45.84.67.184 443]
      Reading package lists... Done
      Building dependency tree... Done
      513 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: Failed to fetch https://download.proxmox.com/debian/pve/dists/trixie/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 45.84.67.184 443]
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      root@proxmox:~#
      Kann mir jemand helfen, was ich da machen muss?
      Danke schon mal im Voraus!
        Thomas Braun Most Active @guitardoc last edited by
        @guitardoc sagte in Certificate verification failed.:
        Stell das in deinen Quellen auf
        http://download.proxmox.com/debian/pve
        um. Soweit ich das sehe sind die Community Repos nicht per https erreichbar.
        • G
          guitardoc @Thomas Braun last edited by
          @thomas-braun Yep, das wars. Ich hab mir schon einen Wolf gesucht. Jetzt scheint es zu passen:
          Get:5 http://download.proxmox.com/debian/pve trixie InRelease [2,771 B]
          Get:6 http://download.proxmox.com/debian/pve trixie/pve-no-subscription amd64 Packages [239 kB]
          Fetched 242 kB in 1s (293 kB/s)
          575 packages can be upgraded. Run 'apt list --upgradable' to see them.
          root@proxmox:~#
            War einer der ersten Treffer in meiner Suchmaschine.
            • G
              @thomas-braun Bei mir kamen bei Google kamen nur kryptische englische Anleitungen wie man irgendwelche Schlüssel wiederherstellen soll. Da hab ich gleich die Finger davon gelassen. Aber stimmt, im Proxmox-Forum steht http statt https - aber dass das die Lösung für einen fehlerhaften Schlüssel sein soll... Wieder was gelernt.
                Die Melduung ist da etwas irreführend. Es wird ja kein Cert verwendet, https erwartet aber eins. (Gut, deswegen passt es ja auch nicht zur Erwartung...)
                81.1k
