    4. [GELÖST]RingAdapter Error: Could not load the "sharp" module
      torstenhe last edited by torstenhe
      Moin,
      ich habe den Ring-Adapter installiert und bekomme nach dem Start des Adapters diese Meldung:
      code_text
      host.ioBroker(SmartHome1)
      2025-10-16 08:35:31.150	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: Node.js v22.20.0
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sharp/lib/constructor.js:10:1)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
      2025-10-16 08:35:31.150	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
      2025-10-16 08:35:31.149	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
      2025-10-16 08:35:31.149	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sharp/lib/sharp.js:121:9)
      2025-10-16 08:35:31.149	error	Caught by controller[0]: See https://sharp.pixelplumbing.com/install
      2025-10-16 08:35:31.149	error	Caught by controller[0]: - Consult the installation documentation:
      2025-10-16 08:35:31.149	error	Caught by controller[0]: npm install --os=linux --cpu=x64 sharp
      2025-10-16 08:35:31.149	error	Caught by controller[0]: - Add platform-specific dependencies:
      2025-10-16 08:35:31.149	error	Caught by controller[0]: See https://sharp.pixelplumbing.com/install#cross-platform
      2025-10-16 08:35:31.149	error	Caught by controller[0]: - Ensure your package manager supports multi-platform installation:
      2025-10-16 08:35:31.149	error	Caught by controller[0]: npm install --include=optional sharp
      2025-10-16 08:35:31.149	error	Caught by controller[0]: - Ensure optional dependencies can be installed:
      2025-10-16 08:35:31.149	error	Caught by controller[0]: Possible solutions:
      2025-10-16 08:35:31.148	error	Caught by controller[0]: Unsupported CPU: Prebuilt binaries for linux-x64 require v2 microarchitecture
      2025-10-16 08:35:31.148	error	Caught by controller[0]: Error: Could not load the "sharp" module using the linux-x64 runtime
      2025-10-16 08:35:31.148	error	Caught by controller[0]: ^
      2025-10-16 08:35:31.148	error	Caught by controller[0]: throw new Error(help.join('\n'));
      2025-10-16 08:35:31.148	error	Caught by controller[0]: /opt/iobroker/node_modules/sharp/lib/sharp.js:121
      code_text
      Kann mir da jemand helfen was ich machen kann?
      Vielen Dank im Voraus
      LG
      • haselchen
        haselchen Most Active @torstenhe last edited by
        @torstenhe sagte in Ring-Adapter: Error: Could not load the "sharp" module:
        Auf was fürn System mit Hardware bist Du unterwegs?
        Kompletten Auszug von
        iob diag
        bitte.
          torstenhe @haselchen last edited by torstenhe
          @haselchen
          Ich habe einen Proxmox laufen auf nem Lenovo Thinkcentre Tiny. iob info kommt noch. Bin @ Work und komm nicht ran wie ich ran will. 😉
          PlatformBetriebssystem:linux
          Architektur:x64
          CPUs:4
          Modell:Common KVM processor
          RAM:11.6 GB
          Node.js:v22.20.0
          NPM:10.9.3
          _nodeCurrent:22.20.0
          _nodeNewest:22.20.0
          _nodeNewestNext:22.20.0
          _npmCurrent:10.9.3
          _npmNewest:10.9.3
          _npmNewestNext:10.9.3
          • haselchen
            @torstenhe
            Bei der Suche nach Deinem Error habe ich diese Antwort gefunden.
            I used pve to simulate the centos system, the cpu is Model: 15.6.1 "Common KVM processor", I just modified the hardware processor of the pve virtual machine and it worked
            Da ich da nicht in der Materie stecke und hoffe und denke, dass Du eine VM hast, musst Du wohl an den CPU Einstellungen etwas ändern.
              @haselchen
              Hmm. Den Fehler hatte ich noch bei keinem anderen Adapter und das System läuft eigentlich sehr gut.
              Dann versuche ich mal in diese Richtung zu forschen.
              Dankeschön
                @haselchen
                Du hast mich auf den richtigen Weg gebracht, vielen Dank. 🙂
                Die Lösung war, den Prozessortyp der VM auf HOST umzustellen, jetzt läuft der Adapter.
                LG
                • haselchen
                  @torstenhe
                  Siehste, kaum macht man es richtig 😬
                    @haselchen
                    Man lernt nie aus. 😄
                    • haselchen
                      @torstenhe
                      Setz noch bitte [GELÖST) vor Deinen Threadtitel.
                        @haselchen
                        Aber klar doch. 🙂
                        81.0k
                        133
