    4. IoBroker unter Windows7 64bit installiert einfach nicht
      andiandi last edited by
      Habe ein Windows 7 Pro 64bit auf dem ioBroker drauf soll.
      Mit dem Installationsprogramm gehts nicht.
      Manuell habe ich zu erst die aktuelle Nodejs LTS-Version (6.x.x) installiert.
      Dann Ordner c:\iobroker angelegt.
      mittels Admin-Console in den Ordner gewechselt und nom install iobroker eingegebn.
      Dann fängt er an und bringt Fehler.
      Hier die Ausgabe:
      C:\ioBroker>npm install iobroker
      > iobroker@1.0.2 install C:\ioBroker\node_modules\iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix "C:/ioBroker"
      npm install iobroker.admin --production --prefix "C:/ioBroker"
      npm install iobroker.js-controller --production --prefix "C:/ioBroker"
      npm WARN deprecated tar.gz@1.0.7: ??  WARNING ?? tar.gz module has been deprecat
      ed and your application is vulnerable. Please use tar module instead: https://np
      mjs.com/tar
      gyp ERR! build error
      gyp ERR! stack Error: `C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.exe` fail
      ed with exit code: 1
      gyp ERR! stack     at ChildProcess.onExit (C:\Users\media\AppData\Roaming\npm\no
      de_modules\npm\node_modules\node-gyp\lib\build.js:276:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces
      s.js:219:12)
      gyp ERR! System Windows_NT 6.1.7601
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\media\\AppDat
      a\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "r
      ebuild"
      gyp ERR! cwd C:\ioBroker\node_modules\iobroker.js-controller\node_modules\unix-d
      gram
      gyp ERR! node -v v6.11.5
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      s.js:219:12)
      ebuild"
      gyp ERR! cwd C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ursa
      gyp ERR! not ok
      events.js:160
            throw er; // Unhandled 'error' event
      Error: listen EACCES 127.0.0.1:9001
          at Object.exports._errnoException (util.js:1020:11)
          at exports._exceptionWithHostPort (util.js:1043:20)
          at Server._listen2 (net.js:1249:19)
          at listen (net.js:1298:10)
          at net.js:1408:9
          at _combinedTickCallback (internal/process/next_tick.js:83:11)
          at process._tickCallback (internal/process/next_tick.js:104:9)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\i
      obroker.js-controller\node_modules\unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-
      gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules\iobroke
      r.js-controller\node_modules\ursa):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: `node-gyp re
      build`
      npm ERR! Windows_NT 6.1.7601
      npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\media\\AppData\\
      Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.js-control
      ler" "--production" "--prefix" "C:/ioBroker"
      npm ERR! node v6.11.5
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@1.2.0 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.2.0 install script 'node iobroke
      r.js setup first'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the iobroker.js-controlle
      r package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node iobroker.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
      Write "iobroker start" to start the ioBroker
      npm install https://github.com/arthurblake/node-windows/tarball/f1fd60e93e246966
      3b99a9cf3a64086ecedfe1e4 --production --prefix "C:\ioBroker\node_modules\iobroke
      r\lib/../../../"
      ioBroker service installed. Write "serviceIoBroker start" to start the service a
      nd go to http://localhost:8081 to open the admin UI.
      To see the outputs do not start the service, but write "node node_modules/iobrok
      er.js-controller/controller"
      C:\ioBroker
      `-- iobroker@1.0.2
        `-- yargs@7.1.0
          +-- cliui@3.2.0
          | +-- strip-ansi@3.0.1
          | `-- wrap-ansi@2.1.0
          +-- decamelize@1.2.0
          +-- get-caller-file@1.0.2
          +-- os-locale@1.4.0
          | `-- lcid@1.0.0
          |   `-- invert-kv@1.0.0
          +-- read-pkg-up@1.0.1
          | +-- find-up@1.1.2
          | | +-- path-exists@2.1.0
          | | `-- pinkie-promise@2.0.1
          | |   `-- pinkie@2.0.4
          | `-- read-pkg@1.1.0
          |   +-- load-json-file@1.1.0
          |   | +-- graceful-fs@4.1.11
          |   | +-- parse-json@2.2.0
          |   | | `-- error-ex@1.3.1
          |   | |   `-- is-arrayish@0.2.1
          |   | +-- pify@2.3.0
          |   | `-- strip-bom@2.0.0
          |   |   `-- is-utf8@0.2.1
          |   +-- normalize-package-data@2.4.0
          |   | +-- hosted-git-info@2.5.0
          |   | +-- is-builtin-module@1.0.0
          |   | +-- semver@5.4.1
          |   | `-- validate-npm-package-license@3.0.1
          |   |   +-- spdx-correct@1.0.2
          |   |   | `-- spdx-license-ids@1.2.2
          |   |   `-- spdx-expression-parse@1.0.4
          |   `-- path-type@1.1.0
          +-- require-directory@2.1.1
          +-- require-main-filename@1.0.1
          +-- set-blocking@2.0.0
          +-- string-width@1.0.2
          | +-- code-point-at@1.1.0
          | `-- is-fullwidth-code-point@1.0.0
          |   `-- number-is-nan@1.0.1
          +-- which-module@1.0.0
          +-- y18n@3.2.1
          `-- yargs-parser@5.0.0
      npm WARN enoent ENOENT: no such file or directory, open 'C:\ioBroker\package.jso
      n'
      npm WARN ioBroker No description
      npm WARN ioBroker No repository field.
      npm WARN ioBroker No README data
      npm WARN ioBroker No license field.
      • Dutchman
        Die Fehler sind normal und ok, ioBroker sollte jetzt laufen und der Admin erreichbar sein?
        Send from mobile device
        • rantanplan
          rantanplan last edited by
          Hallo andiandi
          Meine Installationen sind schon einige Zeit vorbei.
          Das angebotene Windows Installationsprogramm funktionierte auf XP 32Bit / Win7 32/64Bit und Win10 64Bit.
          Installation jeweils als Admin.
