    4. RPI 2 V2.4 läßt sich nicht installieren
      plc last edited by
      Hallo, auf meinem Raspi Pi5 ist aktuell Node js v22,21.0 und npm v11.62. Bei der Installation bekomme ich folgende Ausgabe.
      $ iobroker add rpi2 --host rasppi5
      Installing iobroker.rpi2@2.4.0... (System call)
      npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioInput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:14:17: error: expected primary-expression before ‘line’npm error 14 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:19:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~npm error | gpiod::linenpm error In file included from /usr/include/gpiodcxx/chip.hpp:21,npm error from /usr/include/gpiod.hpp:27,npm error from ../cpp/opengpio.cpp:3:npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:19:58: error: ‘DIRECTION_INPUT’ is not a member of ‘gpiod::line_request’npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:28:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:30:22: error: ‘line’ is not capturednpm error 30 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:28:66: note: the lambda has no capture-defaultnpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:34:52: error: ‘line’ is not capturednpm error 34 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:33:67: note: the lambda has no capture-defaultnpm error 33 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioOutput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:49:17: error: expected primary-expression before ‘line’npm error 49 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:54:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:54:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:63:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:66:9: error: ‘line’ is not capturednpm error 66 | line.set_value(value); });npm error | ^~~~npm error ../cpp/opengpio.cpp:63:66: note: the lambda has no capture-defaultnpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:69:52: error: ‘line’ is not capturednpm error 69 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:68:67: note: the lambda has no capture-defaultnpm error 68 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:81:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 81 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:92:17: error: expected primary-expression before ‘line’npm error 92 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:100:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:100:58: error: ‘EVENT_BOTH_EDGES’ is not a member of ‘gpiod::line_request’npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:109:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:111:22: error: ‘line’ is not capturednpm error 111 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:109:66: note: the lambda has no capture-defaultnpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:115:11: error: ‘struct WatchContext’ has no member named ‘line’npm error 115 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:127:25: error: expected primary-expression before ‘line’npm error 127 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:131:33: error: ‘line’ is not capturednpm error 131 | bool hasEvent = line.event_wait(chrono::milliseconds(1));npm error | ^~~~npm error ../cpp/opengpio.cpp:124:10: note: the lambda has no capture-defaultnpm error 124 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp:134:28: error: ‘line_event’ is not a member of ‘gpiod’; did you mean ‘info_event’?npm error 134 | gpiod::line_event event = line.event_read();npm error | ^~~~~~~~~~npm error | info_eventnpm error ../cpp/opengpio.cpp:135:34: error: ‘event’ was not declared in this scope; did you mean ‘servent’?npm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~npm error | serventnpm error ../cpp/opengpio.cpp:135:61: error: ‘gpiod::line_event’ has not been declarednpm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~~~~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:147:19: error: ‘struct WatchContext’ has no member named ‘line’npm error 147 | data->line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:168:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 168 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioPwm(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:196:17: error: expected primary-expression before ‘line’npm error 196 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:201:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:201:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:213:11: error: ‘struct PwmContext’ has no member named ‘line’npm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:213:18: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 213 | data->line = line;npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:224:25: error: expected primary-expression before ‘line’npm error 224 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:264:17: error: ‘line’ is not capturednpm error 264 | line.set_value(true);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:278:17: error: ‘line’ is not capturednpm error 278 | line.set_value(false);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:327:25: error: expected primary-expression before ‘line’npm error 327 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:328:13: error: ‘line’ is not capturednpm error 328 | line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp:324:10: note: the lambda has no capture-defaultnpm error 324 | [](uv_work_t *req, int status)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712npm error gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v22.21.0npm error gyp ERR! node-gyp -v v11.4.2npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-22T11_44_39_541Z-debug-0.log
      host.raspberrypi5 Cannot install iobroker.rpi2@2.4.0: 1
      ERROR: Process exited with code 25
      wie ich lese ist wohl ein falsches npm? wie installiere ich ein passendes npm? Oder fehlt mir sonst noch was?
      Danke im Voraus.
        Thomas Braun Most Active @plc last edited by Thomas Braun
        @plc
        RaspberryOS 13 Trixie am Start?
        Falls ja, dann versuch mal diesen Fork via GitHub/URL einzuspielen:
        https://github.com/Grothesk242/ioBroker.rpi2
          plc @Thomas Braun last edited by
          @thomas-braun Vielen Dank. Es hat unktioniert.
          81.0k
