    4. Plenticore Adapter - Vorhersage funktioniert nicht mehr
    • I
      iobrokerin last edited by
      seit ein paar Tagen stürzt der Plenticore Adapter komplett ab, sobald ich die Leistungsprognose aktiviere. Deaktiviere ich diese, funktioniert der Adapter perfekt. Im Log bekomme ich folgende Fehlermeldung:
      plenticore.0
      	2025-10-29 08:41:23.682	info	Logged out from API
      plenticore.0
      	2025-10-29 08:41:23.618	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      plenticore.0
      	2025-10-29 08:41:23.618	info	terminating
      plenticore.0
      	2025-10-29 08:41:23.617	info	[END] Stopping plenticore adapter...
      plenticore.0
      	2025-10-29 08:41:23.614	error	Cannot read properties of undefined (reading 'sky')
      plenticore.0
      	2025-10-29 08:41:23.614	error	TypeError: Cannot read properties of undefined (reading 'sky') at checkStoreSunPanelSkyData (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1068:48) at Object.storeSunPanelData (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1526:2) at /opt/iobroker/node_modules/iobroker.plenticore/main.js:221:15 at loginSuccess (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:2718:14) at /opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:2677:5 at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1585:16) at IncomingMessage.emit (node:events:531:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:90:21)
      plenticore.0
      	2025-10-29 08:41:23.614	error	uncaught exception: Cannot read properties of undefined (reading 'sky')
      plenticore.0
      	2025-10-29 08:41:23.612	info	Enabling forecast data.
      plenticore.0
      	2025-10-29 08:41:23.381	info	[INFO] Configured polling interval: 20000
      plenticore.0
      	2025-10-29 08:41:23.380	info	Configured battery strategy is: 1
      plenticore.0
      	2025-10-29 08:41:23.380	info	Configured maximum feed-in power is 5000
      plenticore.0
      	2025-10-29 08:41:23.380	info	Configured Wp of panel(s) is 10951
      plenticore.0
      	2025-10-29 08:41:23.380	warn	Kachelmannwetter lib failed to init.
      plenticore.0
      	2025-10-29 08:41:23.380	warn	Error getting city id for coordinates: null
      plenticore.0
      	2025-10-29 08:41:23.284	info	got weather data from met.no with 92 elements.
      plenticore.0
      	2025-10-29 08:41:23.016	info	[START] Starting adapter plenticore v2.3.1r237
      plenticore.0
      	2025-10-29 08:41:23.009	info	starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.plenticore, node: v22.21.0, js-controller: 7.0.7
      Ich habe geprüft, ob Koordinaten im ioBroker hinterlegt sind. Ja, das waren und sind sie. Hat jemand anderes das Gleiche Problem und evt. eine Lösung?
      81.1k
