    4. Fehler bei mehreren Adaptern nach öffnen der Instanz
      Jan201 last edited by
      Moin,
      Nach dem öffnen der Instanzen: I-Cal, trashschedule, vis-2, bekomme ich folgende Meldung:
      2025-10-31 11:09:39.390 - warn: admin.0 (5166) vis-2 has an invalid jsonConfig: [{"instancePath":"/items/loading/items/loading-bg.png/accept","schemaPath":"#/patternProperties/%5E.%2B/allOf/10/then/properties/accept/type","keyword":"type","params":{"type":"object"},"message":"must be object"},{"instancePath":"/items/loading","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
      Iob Diag sagt:
      ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: IoBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.8-2-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:17:11 up 2 days, 17:43,  1 user,  load average: 0.50, 0.27, 0.19
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-10-31 11:17:11 CET
                 Universal time: Fri 2025-10-31 10:17:11 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout sudo audio video plugdev users
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/iobroker
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Run 'iobroker fix' or use the system tools to create a user.
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.3G        2.6G        621M        3.1M        1.1G        1.7G
      Swap:           536M        7.3M        529M
      Total:          4.8G        2.6G        1.2G
      Active iob-Instances:   20
               4096 M total memory
               2504 M used memory
               2563 M active memory
                674 M inactive memory
                592 M free memory
                  0 M buffer memory
               1002 M swap cache
                512 M total swap
                  6 M used swap
                505 M free swap
      top - 11:17:12 up 2 days, 17:43,  1 user,  load average: 0.50, 0.27, 0.19
      Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.0 us,  4.2 sy,  0.0 ni, 40.6 id, 54.2 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,    590.5 free,   2505.4 used,   1003.0 buff/cache
      MiB Swap:    512.0 total,    505.0 free,      7.0 used.   1590.6 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      [sudo] password for iobroker:
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       12G  4.8G  6.4G  43% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.9G  3.0M  3.8G   1% /tmp
      tmpfs                            tmpfs     779M  4.0K  779M   1% /run/user/1000
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      /var:
      454M    /var/
      275M    /var/cache
      272M    /var/cache/apt
      181M    /var/cache/apt/archives
      161M    /var/lib
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      273M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      756M    /opt/iobroker/iobroker-data/
      635M    /opt/iobroker/iobroker-data/files
      233M    /opt/iobroker/iobroker-data/files/vis
      225M    /opt/iobroker/iobroker-data/files/vis/widgets
      122M    /opt/iobroker/iobroker-data/files/vis-2
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      14M     /opt/iobroker/iobroker-data/states.jsonl
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.21.0
      /usr/bin/node           v22.21.0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.21.0-1nodesource1
        Candidate: 22.21.0-1nodesource1
        Version table:
       *** 22.21.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      IoBroker            IoBroker (version: 7.0.7, hostname: IoBroker      , alive, uptime: 235498)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : IoBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
        system.adapter.bring.0                  : bring                 : IoBroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : IoBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : IoBroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : IoBroker                                 - disabled
        system.adapter.eventlist.0              : eventlist             : IoBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
        system.adapter.fullcalendar.0           : fullcalendar          : IoBroker                                 - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
      + system.adapter.history.0                : history               : IoBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
        system.adapter.mqtt-client.0            : mqtt-client           : IoBroker                                 - disabled, port: 1884
      + system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        system.adapter.reolink.0                : reolink               : IoBroker                                 - disabled
        system.adapter.ring.0                   : ring                  : IoBroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 - disabled
        system.adapter.spotify-premium.0        : spotify-premium       : IoBroker                                 - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
      + system.adapter.time-switch.0            : time-switch           : IoBroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : IoBroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : IoBroker                                 -  enabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: IoBroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IoBroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IoBroker                                 -  enabled
        system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : IoBroker                                 - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: IoBroker                                 - disabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IoBroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IoBroker                                 - disabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: IoBroker                                 - disabled
      + system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IoBroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IoBroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : IoBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : IoBroker                                 - disabled
      + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yahka.0                  : yahka                 : IoBroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "admin"        : 7.7.19   , installed 7.7.19
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
      Adapter    "bring"        : 1.9.1    , installed 1.9.1
      Adapter    "daswetter"    : 3.2.6    , installed 3.2.6
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "eventlist"    : 2.1.0    , installed 2.1.0
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
      Adapter    "ical"         : 1.18.1   , installed 1.18.1
      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "ring"         : 6.4.0    , installed 6.4.0
      Adapter    "shelly"       : 10.4.0   , installed 10.4.0
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 4.0.1    , installed 4.0.1
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "vis-2"        : 2.13.6   , installed 2.13.6
      Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
      Adapter    "vis-2-widgets-icontwo": 1.18.0, installed 1.18.0
      Adapter    "vis-2-widgets-inventwo": 0.3.9, installed 0.3.9
      Adapter    "vis-2-widgets-jaeger-design": 1.4.9, installed 1.4.9
      Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
      Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.9    , installed 7.0.9
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Objects and States
      Objects:        12073
      States:         10629
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://security.debian.org trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1124018    271/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1160265    1731/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1161269    1731/iobroker.js-co
      tcp        0      0 192.168.178.62:42001    0.0.0.0:*               LISTEN      1000       1217795    5272/io.hm-rpc.0
      tcp        0      0 192.168.178.62:42010    0.0.0.0:*               LISTEN      1000       1217825    5283/io.hm-rpc.1
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1122562    1/init
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       1218145    5403/io.shelly.1
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       1421800    7955/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1218115    5410/io.sonoff.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1214003    5166/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1216458    5554/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1124019    271/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1123582    1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1122564    1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1218023    5362/io.mihome-vacu
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1216299    5396/io.shelly.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1122563    1/init
      udp6       0      0 :::111                  :::*                                0          1122565    1/init
      2025-10-31 11:15:14.648  - info: admin.0 (5166) ==> Connected system.user.admin from ::ffff:192.168.178.70
      2025-10-31 11:15:16.062  - info: host.IoBroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 67400
      2025-10-31 11:15:17.351  - info: admin.0 (5166) <== Disconnect system.user.admin from ::ffff:192.168.178.70
      2025-10-31 11:15:18.784  - info: host.IoBroker "system.adapter.yahka.0" disabled
      2025-10-31 11:15:18.784  - info: host.IoBroker stopInstance system.adapter.yahka.0 (force=false, process=true)
      2025-10-31 11:15:18.799  - info: yahka.0 (5625) Got terminate signal TERMINATE_YOURSELF
      2025-10-31 11:15:18.815  - info: yahka.0 (5625) cleaning up ...
      2025-10-31 11:15:18.816  - info: yahka.0 (5625) cleaned up ...
      2025-10-31 11:15:18.817  - info: yahka.0 (5625) terminating
      2025-10-31 11:15:18.818  - info: yahka.0 (5625) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-31 11:15:18.921  - info: host.IoBroker stopInstance system.adapter.yahka.0 send kill signal
      2025-10-31 11:15:19.191  - info: tvspielfilm.0 (67400) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v22.21.0, js-controller: 7.0.7
      2025-10-31 11:15:19.322  - info: yahka.0 (5625) terminating
      2025-10-31 11:15:19.431  - info: host.IoBroker instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-31 11:15:21.269  - info: tvspielfilm.0 (67400) objects written
      2025-10-31 11:15:25.048  - info: daswetter.0 (67383) still wrong data structure from server received! repaired...
      2025-10-31 11:15:27.065  - info: host.IoBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 67415
      2025-10-31 11:15:29.973  - info: dwd.0 (67415) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7
      2025-10-31 11:15:30.714  - info: dwd.0 (67415) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-31 11:15:30.922  - info: daswetter.0 (67383) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-31 11:15:31.250  - info: host.IoBroker instance system.adapter.dwd.0 having pid 67415 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-31 11:15:31.435  - info: daswetter.0 (67383) cleaned everything up...
      2025-10-31 11:15:31.456  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 67383 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-31 11:15:31.776  - info: tvspielfilm.0 (67400) Terminated (NO_ERROR): Without reason
      2025-10-31 11:15:32.307  - info: host.IoBroker instance system.adapter.tvspielfilm.0 having pid 67400 terminated with code 0 (NO_ERROR)
      iob diag has finished.
      iobroker@IoBroker:~$ ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               4096 M total memory
               2504 M used memory
                592 M free memory
                  0 M buffer memory
               1002 M swap cache
                512 M total swap
                  6 M used swap
                505 M free swap
      iob diag has finished.l here for C&P =============tance system.adapter.tvspielfilm.0 having pid 67400 terminated with code 0 (NO_ERROR)QUESTED_TERMINATION)enter: 7.0.7
      [/s]
      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jan201 last edited by
        @jan201 sagte in Fehler bei mehreren Adaptern nach öffnen der Instanz:
        Tu das.
        Schalt das um.
        Die eigentliche Meldung ist soweit aber harmlos.
        • mcm1957
          mcm1957 @Jan201 last edited by mcm1957
          @jan201 said in Fehler bei mehreren Adaptern nach öffnen der Instanz:
          Moin,
          Iob Diag sagt:
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
                   4096 M total memory
                   2504 M used memory
                    592 M free memory
                      0 M buffer memory
                   1002 M swap cache
                    512 M total swap
                      6 M used swap
                    505 M free swap
          *** FILESYSTEM ***
          /var:
          454M    /var/
          275M    /var/cache
          272M    /var/cache/apt
          161M    /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        12073
          States:         10629
          Pending Updates: 0
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
                   4096 M total memory
                   2504 M used memory
                    592 M free memory
                      0 M buffer memory
                   1002 M swap cache
                    512 M total swap
                      6 M used swap
                    505 M free swap
          [/s]
          Mach mit den jeweiligen Meldungen ein Issue beim betroffenen Adapter auf - sofern noch kein Issue dazu existiert. Obige Meldung betrifft vis-2
          Welche Meldungen du voin ical und trashschedule bekommts ist daraus nicht zu sehen. Ebensowenig welche Versionen der betroffenen Adapter zu verwendest.
            Jan201 @Thomas Braun last edited by
            nach ausführen von iob fix hat sich nichts weiter mit der Medung geändert:
            2025-11-04 08:51:15.588 - info: web.0 (114941) starting. Version 7.0.9 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
            2025-11-04 08:51:16.805 - info: web.0 (114941) socket.io server listening on port 8082
            2025-11-04 08:51:16.835 - info: web.0 (114941) http server listening on port 8082
            2025-11-04 08:51:18.860 - info: web.0 (114941) ==> Connected system.user.admin from ::ffff:192.168.178.199
            2025-11-04 08:51:25.154 - info: vis.0 (114624) Uploaded. 0
            2025-11-04 08:51:25.670 - info: vis.0 (114624) Terminated (NO_ERROR): Without reason
            2025-11-04 08:51:26.496 - info: host.IoBroker instance system.adapter.vis.0 terminated while should be started once
            2025-11-04 08:51:27.631 - info: tankerkoenig.0 (114862) Start first request
            2025-11-04 08:51:32.460 - warn: admin.0 (114469) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
            2025-11-04 08:51:38.573 - error: daswetter.0 (114832) force terminate
            2025-11-04 08:51:38.575 - warn: daswetter.0 (114832) Terminated (UNKNOWN_ERROR): Without reason
            2025-11-04 08:51:39.100 - error: daswetter.0 (114832) exception in await insertIntoList [Error: DB closed]
            2025-11-04 08:51:39.101 - error: daswetter.0 (114832) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2": Connection is closed.
            2025-11-04 08:51:39.104 - error: daswetter.0 (114832) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2": Connection is closed.]
            2025-11-04 08:51:39.110 - error: daswetter.0 (114832) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_desc": Connection is closed.
            2025-11-04 08:51:39.217 - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
            2025-11-04 08:51:42.434 - info: shelly.1 (114783) [MQTT] Device with client id "shelly2pmg3-8cbfea94ad7c" connected from 192.168.178.85!
            2025-11-04 08:51:49.523 - info: web.0 (114941) <== Disconnect system.user.admin from ::ffff:192.168.178.199
            2025-11-04 08:51:52.852 - info: web.0 (114941) ==> Connected system.user.admin from ::ffff:192.168.178.199
            2025-11-04 08:53:23.924 - warn: admin.0 (114469) vis-2 has an invalid jsonConfig: [{"instancePath":"/items/loading/items/loading-bg.png/accept","schemaPath":"#/patternProperties/%5E.%2B/allOf/10/then/properties/accept/type","keyword":"type","params":{"type":"object"},"message":"must be object"},{"instancePath":"/items/loading","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
            2025-11-04 08:53:43.213 - warn: admin.0 (114469) trashschedule has an invalid jsonConfig: [{"instancePath":"/items/_advanced/items/trashtypes/items/4","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_advanced/items/trashtypes","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_advanced","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
            2025-11-04 08:54:45.391 - warn: admin.0 (114469) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
              @jan201
              • mcm1957
                mcm1957 @mcm1957 last edited by mcm1957
                @mcm1957 said in Fehler bei mehreren Adaptern nach öffnen der Instanz:
                Hast du bitte für die 'has an invalid jsonConfig' Meldungen ein Issue in den einzelnen Adapter Repos gemacht? Ohne Issue ist keine Analyse und keine Behebung zu erwarten.
