    4. Admin lädt nicht mehr/ web Adapter issues
      lessthanmore last edited by
      seit dem Update vom Admin auf 7.7.19 lädt mein Admin nicht mehr.
      Ich sehe im Grunde genommen nur das Logo/ Ladebildschirm ohne Fortschritt.
      Hier die diag - Ausgabe:
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.11-4-pve
          Architecture: x86-64
      OS is similar to:
      model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       13:25:38 up 9 min,  1 user,  load average: 0.46, 0.37, 0.22
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-11-04 13:25:38 CET
                 Universal time: Tue 2025-11-04 12:25:38 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      michael
      HOME=/home/michael
      GROUPS=michael sudo users iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/michael
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: 	false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session: 		tty
      *** MEMORY ***
      Mem:            8.6G        1.2G        6.7G        4.2M        604M        7.3G
      Swap:           536M          0B        536M
      Total:          9.1G        1.2G        7.3G
      Active iob-Instances: 	13
               8192 M total memory
               1187 M used memory
               1300 M active memory
                323 M inactive memory
               6431 M free memory
                  0 M buffer memory
                576 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 13:25:39 up 9 min,  1 user,  load average: 0.46, 0.37, 0.22
      Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   6430.8 free,   1188.2 used,    576.8 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7003.8 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--1 ext4       25G  5.0G   19G  22% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      /dev/mapper/pve-root             ext4       67G   38G   26G  61% /dev/ttyACM0
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  152K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs      32G  3.9M   32G   1% /tmp
      tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
      Show mounted filesystems:
      TARGET         SOURCE                                                 FSTYPE OPTIONS
      /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
      `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
      /var:
      337M	/var/
      218M	/var/lib
      92M	/var/cache
      91M	/var/cache/apt
      90M	/var/lib/apt
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      1.8M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      62M	/opt/iobroker/iobroker-data/
      56M	/opt/iobroker/iobroker-data/files
      38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
      5.3M	/opt/iobroker/iobroker-data/objects.jsonl
      3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
      3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
      3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v22.21.1
      /usr/bin/node 		v22.21.1
      /usr/bin/npm 		10.9.4
      /usr/bin/npx 		10.9.4
      /usr/bin/corepack 	0.34.0
      nodejs:
        Installed: 22.21.1-1nodesource1
        Candidate: 22.21.0-1nodesource1
        Version table:
       *** 22.21.1-1nodesource1 100
              100 /var/lib/dpkg/status
           22.21.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 106)
      Core adapters versions
      js-controller: 	7.0.7
      admin: 		7.7.19
      javascript: 	8.9.2
      nodejs modules from github: 	2
      +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
      +-- iobroker.lovelace@5.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.lovelace.git#0d3a5f35eecfe52bd4d382a5d9f8a7fb7ccb42ee)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
      + system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.19   , installed 7.7.19
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "lovelace"     : 5.0.1    , installed 5.0.1
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
      Adapter    "openknx"      : 0.9.0    , installed 0.9.0
      Adapter    "pirate-weather": 0.7.0   , installed 0.7.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
      Objects and States
      Objects: 	26515
      States: 	8525
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15147164   308/master
      tcp        0      0 127.0.0.1:36101         0.0.0.0:*               LISTEN      1000       15166411   2241/io.yahka.0
      tcp        0      0 127.0.0.1:39099         0.0.0.0:*               LISTEN      1000       15166407   2241/io.yahka.0
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        15146593   146/redis-server 12
      tcp        0      0 127.0.0.1:42891         0.0.0.0:*               LISTEN      1000       15166415   2241/io.yahka.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        15146834   299/mosquitto
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15139839   1/init
      tcp6       0      0 ::1:6379                :::*                    LISTEN      105        15146594   146/redis-server 12
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15147165   308/master
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15173225   2331/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15166047   2109/io.admin.0
      tcp6       0      0 :::8080                 :::*                    LISTEN      1001       15147402   149/node
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       15173158   2301/io.lovelace.0
      tcp6       0      0 :::1883                 :::*                    LISTEN      107        15146835   299/mosquitto
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15141524   1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15145985   1/init
      tcp6       0      0 :::45375                :::*                    LISTEN      1000       15166363   2241/io.yahka.0
      tcp6       0      0 :::45177                :::*                    LISTEN      1000       15166359   2241/io.yahka.0
      tcp6       0      0 :::44367                :::*                    LISTEN      1000       15166361   2241/io.yahka.0
      udp        0      0 0.0.0.0:46460           0.0.0.0:*                           1000       15166334   2226/io.openknx.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15139840   1/init
      udp        0      0 0.0.0.0:36157           0.0.0.0:*                           106        15146446   131/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15146444   131/avahi-daemon: r
      udp6       0      0 :::51173                :::*                                106        15146447   131/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15145986   1/init
      udp6       0      0 :::5353                 :::*                                106        15146445   131/avahi-daemon: r
      2025-11-04 13:16:04.578  - warn: web.0 (540) setTimeout called, but adapter is shutting down
      2025-11-04 13:16:05.652  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
      2025-11-04 13:16:14.771  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
      2025-11-04 13:16:43.177  - warn: host.iobroker instance system.adapter.zigbee2mqtt.0 terminated due to SIGTERM
      2025-11-04 13:17:11.266  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
      2025-11-04 13:23:43.902  - warn: web.0 (1540) setTimeout called, but adapter is shutting down
      2025-11-04 13:23:49.020  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
      2025-11-04 13:23:58.299  - error: homeconnect.0 (2181) AxiosError: Request failed with status code 429
      2025-11-04 13:23:58.300  - error: homeconnect.0 (2181) {"error":{"description":"The rate limit \"10 successive error calls in 10 minutes\" was reached. Requests are blocked during the remaining period of 202 seconds.","key":"429"}}
      2025-11-04 13:23:58.382  - error: homeconnect.0 (2181) 429 Too Many Requests
      2025-11-04 13:23:58.382  - error: homeconnect.0 (2181) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      2025-11-04 13:25:08.423  - error: homeconnect.0 (2181) 429 Too Many Requests
      2025-11-04 13:25:08.423  - error: homeconnect.0 (2181) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      Folgende Warnmeldungen irritieren mich bzw. ich kann damit nichts anfangen:
      Lieben Dank vorab für die Hilfe.
      crunchip 2 Replies Last reply Reply Quote 1
      • crunchip
        crunchip Forum Testing Most Active @lessthanmore last edited by
        @lessthanmore iob fix schon probiert? Bzw das system danach mal neu starten.
          lessthanmore @crunchip last edited by lessthanmore
          @crunchip Ja, beides. Inklusive Backup von heute Nacht eingespielt.
          Hier nochmal der aktuelle diag - Auszug. Irgendwas war bei nodejs krumm im ersten:
          Script v.2025-08-09
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           13:38:08 up 3 min,  1 user,  load average: 0.37, 0.68, 0.45
          CPU threads: 2
                         Local time: Tue 2025-11-04 13:38:08 CET
                     Universal time: Tue 2025-11-04 12:38:08 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          michael
          HOME=/home/michael
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session: 		tty
          *** MEMORY ***
          Mem:            8.6G        1.3G        6.7G        4.2M        628M        7.3G
          Swap:           536M          0B        536M
          Total:          9.1G        1.3G        7.2G
                   8192 M total memory
                   1247 M used memory
                   1357 M active memory
                    398 M inactive memory
                   6349 M free memory
                      0 M buffer memory
                    599 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          top - 13:38:08 up 3 min,  1 user,  load average: 0.37, 0.68, 0.45
          %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8192.0 total,   6348.3 free,   1248.2 used,    599.4 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6943.8 avail Mem
          *** FILESYSTEM ***
          /dev/mapper/pve-vm--100--disk--0 ext4       25G  5.0G   19G  22% /
          /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
          /var:
          337M	/var/
          218M	/var/lib
          92M	/var/cache
          91M	/var/cache/apt
          90M	/var/lib/apt
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm 		10.9.4
          /usr/bin/npx 		10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 196)
          admin: 		7.7.19
          javascript: 	8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	26515
          States: 	8525
          Hit:1 http://security.debian.org trixie-security InRelease
          Hit:2 http://deb.debian.org/debian trixie InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        15205722   146/redis-server 12
          tcp        0      0 127.0.0.1:39611         0.0.0.0:*               LISTEN      1000       15202045   474/io.yahka.0
          tcp        0      0 127.0.0.1:40673         0.0.0.0:*               LISTEN      1000       15202049   474/io.yahka.0
          tcp        0      0 127.0.0.1:33209         0.0.0.0:*               LISTEN      1000       15202041   474/io.yahka.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15205860   287/master
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        15206223   319/mosquitto
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15197967   1/init
          tcp6       0      0 :::44523                :::*                    LISTEN      1000       15201191   474/io.yahka.0
          tcp6       0      0 :::8091                 :::*                    LISTEN      1000       15209881   644/io.lovelace.0
          tcp6       0      0 :::8080                 :::*                    LISTEN      1001       15206328   150/node
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15206491   337/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15211290   888/io.web.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15205861   287/master
          tcp6       0      0 :::38507                :::*                    LISTEN      1000       15201189   474/io.yahka.0
          tcp6       0      0 ::1:6379                :::*                    LISTEN      105        15205723   146/redis-server 12
          tcp6       0      0 :::1883                 :::*                    LISTEN      107        15206224   319/mosquitto
          tcp6       0      0 :::32987                :::*                    LISTEN      1000       15201193   474/io.yahka.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15205404   1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          15197969   1/init
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15197968   1/init
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15203038   120/avahi-daemon: r
          udp        0      0 0.0.0.0:44688           0.0.0.0:*                           106        15203040   120/avahi-daemon: r
          udp        0      0 0.0.0.0:44913           0.0.0.0:*                           1000       15202004   459/io.openknx.0
          udp6       0      0 :::111                  :::*                                0          15197970   1/init
          udp6       0      0 :::5353                 :::*                                106        15203039   120/avahi-daemon: r
          udp6       0      0 :::46990                :::*                                106        15203041   120/avahi-daemon: r
          2025-11-04 13:34:44.536  - warn: host.iobroker No configuration found for scope "databaseErrors" and category "system"
          Kann das am neuen MacOS/ iOS liegen? Sonst wurde eigentlich kein Update gemacht.
          Auf der Windows Maschine mit Edge läuft es nämlich problemlos ...
          • crunchip
            @lessthanmore sagte in Admin lädt nicht mehr/ web Adapter issues:
            Hat eigentlich nix damit zu tun, von welchem Rechner du aufrufst
              @crunchip said in Admin lädt nicht mehr/ web Adapter issues:
              In dem Fall offensichtlich doch. Hab es gerade mit zwei identischen iPad Air getestet, eins noch mit 26.0.1 und eins mit 26.1.
              Letzteres öffnet iob nicht.
              • crunchip
                Auf die schnelle
                Das Problem mit endlosen Login-Schleifen in der ioBroker iOS-App nach iOS 26.1 ist bekannt und betrifft vor allem die Authentifizierung. Die App dreht sich beim Login endlos, springt ständig zwischen dem Anmeldebildschirm und der Projekt-Auswahl hin und her. Dieses Verhalten tritt vor allem dann auf, wenn in der ioBroker-Instanz die Authentifizierung aktiviert ist.Ursachen und Lösungen laut Community-Berichten:iOS Safari und die ioBroker App haben Schwierigkeiten mit bestimmten SSL-Zertifikaten, was zu Authentifizierungsabbrüchen führt.Temporäres Deaktivieren der Authentifizierung im ioBroker Web-Adapter kann das Problem beheben und die Views laden.Neuinstallation der App und manuelle Neueingabe der Parameter hilft manchmal nicht.Login-Probleme treten teils nur auf iOS-Geräten auf, während der Zugriff über MacOS-Browser ohne Probleme läuft.VPN- oder Cloud-Zugriffe scheinen anfälliger zu sein als lokale WLAN-Verbindungen.Einige Nutzer berichten, dass die App-Version 7.0.6 funktioniert
                  @crunchip Danke. Authentifikation ist deaktiviert.
                  Lustigerweise lädt der Bildschirm direkt, sobald ich die URL in einem zweiten Fenster erneut öffne.
                  Fehler taucht bei allen Geräten mit 26.1 auf (MacOS, iOS, iPadOS).
                  • miwi
                    miwi last edited by
                    Gleiches Verhalten hier. MacOS 26.1. Bei Safari nur Startlogo. Firefox offnet die WebUi. Danach geht auch es auch wieder in Safari. Beim nächsten Start des Rechners geht der Spaß von vorne los.
                    Berechtigung zum Finden von lokalen Geräten im Netzwerk ist für Firefox aktiviert. Für Safari existiert die Option garnicht.
                    O 1 Reply Last reply Reply Quote 1
                    • O
                      oreus @miwi last edited by oreus
                      Auch bei mir ... Gleiches Verhalten.
                      MacOS 26.1:
                      Nur Firefox öffnet problemlos den admin.
                      Safari nur wenn man ein 2.Fenster öffnet, aber auch nicht zuverlässig.
                      Chrome funktioniert überhaupt nicht.
                      iOS 26.1:
                      Chrome geht nicht
                      Safari geht auch nicht (nur das Startbild mit dem drehenden Kreis um das I)
                      • O
                        oreus @oreus last edited by
                        @oreus
                        Für Chrome habe folgende Lösung als Workaround gefunden:
                        Script in Automator einbauen und als Link auf den Desktop legen:
                        #!/bin/bash
                        open -a "/Applications/Google Chrome.app" --args --disable-features=BlockInsecurePrivateNetworkRequests
                        Startet den Chrome und man kann dann alle lokalen Netzwerkgeräte wieder erreichen, auch ohne SSL etc ...
                        Darunter auch alle Shelly Oberflächen
                          Tobi 1 last edited by
                          Mein Workaround zu diesem Problem auf dem iPhone:
                          Wlan Aus, VPN Verbindung zur Fritzbox herstellen, dann lädt die VIS2 Runtime und ioBroker wie gewohnt.
                          1.1k
                          213
