    4. javascript.0 bricht ab
      Digi-Bit last edited by Digi-Bit
      Ich habe hier einen merkwürdigen fehler und komm da mit nicht weiter.
      Der javascript Adapter startet dauernd neu ich komm da irgend wie seit 3 Tagen nicht weiter
      Vieleieicht weis hier ja jemand weiter.
      javascript.0
      2025-11-04 17:32:22.619	info	received all states
      javascript.0
      2025-11-04 17:32:20.661	info	received all objects
      javascript.0
      2025-11-04 17:32:15.874	info	requesting all objects
      javascript.0
      2025-11-04 17:32:15.874	info	requesting all states
      javascript.0
      2025-11-04 17:32:14.668	warn	Cannot install custom npm package "setObject@latest"
      javascript.0
      2025-11-04 17:31:53.283	info	starting. Version 8.9.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.21.0, js-controller: 7.0.7
      host.debianIOB1
      2025-11-04 17:31:51.602	info	instance system.adapter.javascript.0 in version "8.9.2" started with pid 385701
      tuya.0
      2025-11-04 17:31:50.102	info	33031685500291bdfd1f Init with IP=10.10.136.100, Key=.=N`6!or>A!wti=}, Version=3.3
      tuya.0
      2025-11-04 17:31:50.102	info	33031685500291bdfd1f: Connect locally to device
      host.debianIOB1
      2025-11-04 17:31:50.090	info	Restart adapter system.adapter.javascript.0 because enabled
      host.debianIOB1
      2025-11-04 17:31:50.090	info	instance system.adapter.javascript.0 terminated with code null ()
      host.debianIOB1
      2025-11-04 17:31:50.090	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[6]: 8: 0x1cba291 [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[5]: 7: 0x1454428 [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[4]: 6: 0x145125a [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[3]: 5: 0x1438183 [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[2]: 4: 0x1438155 [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[2]: 3: 0x120a877 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[2]: 2: 0x120a5a0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: 1: 0xe38a0e node::OOMErrorHandler(char const*, v8::OOMDetails const&) [io.javascript.0]
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: ----- Native stack trace -----
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: <--- JS stacktrace --->
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: [375565:0x2fc25000] 1789588 ms: Mark-Compact 4022.8 (4137.0) -> 4008.5 (4138.8) MB, pooled: 0 MB, 2652.31 / 0.00 ms (average mu = 0.061, current mu = 0.030) allocation failure; scavenge might not succeed
      host.debianIOB1
      2025-11-04 17:31:50.090	error	Caught by controller[1]: [375565:0x2fc25000] 1786855 ms: Mark-Compact 4020.4 (4134.3) -> 4006.1 (4136.3) MB, pooled: 0 MB, 2748.47 / 0.00 ms (average mu = 0.090, current mu = 0.028) allocation failure; scavenge might not succeed
      host.debianIOB1
      2025-11-04 17:31:50.089	error	Caught by controller[1]: <--- Last few GCs --->
      Ich weiss nicht genau was man braucht um zu helfen aber iob diag kann ja nicht falsch sein oder ?
      iob diag:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
      Static hostname: debianIOB1
            Icon name: computer-desktop
              Chassis: desktop 🖥️
               Kernel: Linux 6.12.48+deb13-amd64
         Architecture: x86-64
      Hardware Vendor: Intel_R_ Client Systems
       Hardware Model: NUC11PAHi5
      Firmware Version: PATGL357.0052.2023.0901.1439
        Firmware Date: Fri 2023-09-01
         Firmware Age: 2y 2month 4d
      OS is similar to:
      model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      17:42:37 up 19:30,  1 user,  load average: 1.67, 1.12, 0.94
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                    Local time: Tue 2025-11-04 17:42:37 CET
                Universal time: Tue 2025-11-04 16:42:37 UTC
                      RTC time: Tue 2025-11-04 16:42:37
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      digibit
      HOME=/home/digibit
      GROUPS=digibit cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/digibit
      GROUPS=iobroker tty dialout audio video plugdev bluetooth
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             50G        6.9G         38G        4.5M        5.8G         43G
      Swap:           1.0G          0B        1.0G
      Total:           51G        6.9G         39G
      Active iob-Instances:   59
             47807 M total memory
              6548 M used memory
              7540 M active memory
              3393 M inactive memory
             36291 M free memory
              1017 M buffer memory
              4508 M swap cache
               975 M total swap
                 0 M used swap
               975 M free swap
      top - 17:42:37 up 19:30,  1 user,  load average: 1.67, 1.12, 0.94
      Tasks: 246 total,   1 running, 245 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 10.3 us,  1.1 sy,  0.0 ni, 87.4 id,  1.1 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  47808.0 total,  36297.7 free,   6542.8 used,   5526.6 buff/cache
      MiB Swap:    976.0 total,    976.0 free,      0.0 used.  41265.2 avail Mem
      *** FAILED SERVICES ***
       UNIT                LOAD   ACTIVE SUB    DESCRIPTION
      * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
             ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
             SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs   24G     0   24G   0% /dev
      tmpfs          tmpfs     4.7G  1.2M  4.7G   1% /run
      /dev/sda2      ext4      456G   19G  415G   5% /
      tmpfs          tmpfs      24G     0   24G   0% /dev/shm
      efivarfs       efivarfs  192K  110K   78K  59% /sys/firmware/efi/efivars
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs      24G  2.9M   24G   1% /tmp
      /dev/sda1      vfat      511M  4.4M  507M   1% /boot/efi
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/telegraf.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     4.7G  8.0K  4.7G   1% /run/user/1000
      [Mon Nov  3 22:12:24 2025] EXT4-fs (sda2): mounted filesystem 2548fd25-8c0f-46fc-8ad3-8e65ada10bf7 ro with ordered data mode. Quota mode: none.
      [Mon Nov  3 22:12:25 2025] EXT4-fs (sda2): re-mounted 2548fd25-8c0f-46fc-8ad3-8e65ada10bf7 r/w.
      Show mounted filesystems:
      TARGET      SOURCE    FSTYPE OPTIONS
      /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      3.1G    /var/
      1.9G    /var/lib
      838M    /var/lib/influxdb
      837M    /var/lib/influxdb/engine
      827M    /var/lib/mysql
      Archived and active journals take up 289.9M in the file system.
      /opt/iobroker/backups:
      5.9G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.7G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      323M    /opt/iobroker/iobroker-data/backup-objects
      227M    /opt/iobroker/iobroker-data/files/0_userdata.0
      226M    /opt/iobroker/iobroker-data/files/0_userdata.0/VIS
      135M    /opt/iobroker/iobroker-data/states.jsonl
      100M    /opt/iobroker/iobroker-data/objects.jsonl
      85M     /opt/iobroker/iobroker-data/files/0_userdata.0/VIS/Meine_Icons/Netzwerk/peugeot_update (1).exe
      41M     /opt/iobroker/iobroker-data/files/vis-2.0/Meine_Icons/Netzwerk/HeidiSQL_12.5.0.6677_Setup.exe
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.38__Embed_with_CMSIS-DAP_L430047T-if03
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.38__Embed_with_CMSIS-DAP_L430047T-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.21.0
      /usr/bin/node           v22.21.0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      /usr/bin/corepack       0.34.0
      nodejs:
       Installed: 22.21.0-1nodesource1
       Candidate: 22.21.0-1nodesource1
       Version table:
      *** 22.21.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          22.20.0-1nodesource1 1001
          22.19.0-1nodesource1 1001
          22.18.0-1nodesource1 1001
          22.17.1-1nodesource1 1001
          22.17.0-1nodesource1 1001
          22.16.0-1nodesource1 1001
          22.15.1-1nodesource1 1001
          22.15.0-1nodesource1 1001
          22.14.0-1nodesource1 1001
          22.13.1-1nodesource1 1001
          22.13.0-1nodesource1 1001
          22.12.0-1nodesource1 1001
          22.11.0-1nodesource1 1001
          22.10.0-1nodesource1 1001
          22.9.0-1nodesource1 1001
          22.8.0-1nodesource1 1001
          22.7.0-1nodesource1 1001
          22.6.0-1nodesource1 1001
          22.5.1-1nodesource1 1001
          22.5.0-1nodesource1 1001
          22.4.1-1nodesource1 1001
          22.4.0-1nodesource1 1001
          22.3.0-1nodesource1 1001
          22.2.0-1nodesource1 1001
          22.1.0-1nodesource1 1001
          22.0.0-1nodesource1 1001
          20.19.2+dfsg-1 500
             500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      debianIOB1          debianIOB1 (version: 7.0.7, hostname: debianIOB1    , alive, uptime: 36607)
      raspberrypi-IOB     raspberrypi-IOB (version: 7.0.7, hostname: raspberrypi-IOB, alive, uptime: 70208)
      Core adapters versions
      admin:          7.7.19
      javascript:     8.9.2
      nodejs modules from github:     2
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
      Adapter State
      + system.adapter.admin.0                  : admin                 : debianIOB1                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
       system.adapter.admin.1                  : admin                 : debianIOB1                               - disabled, port: 12081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : debianIOB1                               -  enabled
      + system.adapter.backitup.0               : backitup              : debianIOB1                               -  enabled
      + system.adapter.bambulab.0               : bambulab              : debianIOB1                               -  enabled, port: 8883
       system.adapter.ble.0                    : ble                   : debianIOB1                               - disabled
       system.adapter.cameras.0                : cameras               : debianIOB1                               - disabled, port: 8200, bind: 127.0.0.1
       system.adapter.daswetter.0              : daswetter             : debianIOB1                               -  enabled
      + system.adapter.denon.0                  : denon                 : debianIOB1                               -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi-IOB                          -  enabled
      + system.adapter.dysonairpurifier.0       : dysonairpurifier      : debianIOB1                               -  enabled
      + system.adapter.email.0                  : email                 : debianIOB1                               -  enabled
      + system.adapter.enigma2.0                : enigma2               : debianIOB1                               -  enabled
      + system.adapter.enigma2.1                : enigma2               : debianIOB1                               -  enabled
       system.adapter.flot.0                   : flot                  : debianIOB1                               - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : debianIOB1                               -  enabled
      + system.adapter.harmony.0                : harmony               : debianIOB1                               -  enabled
      + system.adapter.heos.0                   : heos                  : debianIOB1                               -  enabled
      + system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : debianIOB1                               -  enabled, port: 8089, bind: 10.10.50.100
      + system.adapter.hmip.0                   : hmip                  : debianIOB1                               -  enabled
       system.adapter.ical.0                   : ical                  : debianIOB1                               -  enabled
       system.adapter.icons-material-png.0     : icons-material-png    : debianIOB1                               - disabled
       system.adapter.icons-material-svg.0     : icons-material-svg    : debianIOB1                               - disabled
       system.adapter.icons-mfd-png.0          : icons-mfd-png         : debianIOB1                               - disabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debianIOB1                               - disabled
       system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debianIOB1                               - disabled
      + system.adapter.influxdb.0               : influxdb              : debianIOB1                               -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : debianIOB1                               -  enabled
      + system.adapter.iot.2                    : iot                   : debianIOB1                               -  enabled
      + system.adapter.javascript.0             : javascript            : debianIOB1                               -  enabled
      + system.adapter.linux-control.0          : linux-control         : debianIOB1                               -  enabled
      + system.adapter.logparser.0              : logparser             : debianIOB1                               -  enabled
       system.adapter.material.0               : material              : debianIOB1                               - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debianIOB1                               -  enabled, port: 54321
      + system.adapter.moma.0                   : moma                  : debianIOB1                               -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : debianIOB1                               -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.netatmo-energy.0         : netatmo-energy        : debianIOB1                               -  enabled
      + system.adapter.nut.0                    : nut                   : debianIOB1                               -  enabled
      + system.adapter.nut.1                    : nut                   : raspberrypi-IOB                          -  enabled
      + system.adapter.openligadb.0             : openligadb            : debianIOB1                               -  enabled
      + system.adapter.ping.0                   : ping                  : debianIOB1                               -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : debianIOB1                               -  enabled
      + system.adapter.radar2.0                 : radar2                : debianIOB1                               -  enabled
      + system.adapter.reolink.0                : reolink               : debianIOB1                               -  enabled
      + system.adapter.reolink.1                : reolink               : debianIOB1                               -  enabled
      + system.adapter.reolink.2                : reolink               : debianIOB1                               -  enabled
      + system.adapter.reolink.3                : reolink               : debianIOB1                               -  enabled
      + system.adapter.reolink.4                : reolink               : debianIOB1                               -  enabled
      + system.adapter.reolink.5                : reolink               : debianIOB1                               -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-IOB                          -  enabled
       system.adapter.samsung.0                : samsung               : debianIOB1                               - disabled
      + system.adapter.scenes.0                 : scenes                : debianIOB1                               -  enabled
      + system.adapter.simple-api.0             : simple-api            : debianIOB1                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
       system.adapter.smartthings.0            : smartthings           : debianIOB1                               - disabled
      + system.adapter.snmp.0                   : snmp                  : debianIOB1                               -  enabled
      + system.adapter.sonoff.0                 : sonoff                : debianIOB1                               -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : debianIOB1                               -  enabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : debianIOB1                               -  enabled
      + system.adapter.tankerkoenig.1           : tankerkoenig          : debianIOB1                               -  enabled
      + system.adapter.telegram.0               : telegram              : debianIOB1                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : debianIOB1                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : debianIOB1                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : debianIOB1                               -  enabled
      + system.adapter.tuya.0                   : tuya                  : debianIOB1                               -  enabled
       system.adapter.tuya.1                   : tuya                  : raspberrypi-IOB                          - disabled
      + system.adapter.unifi.0                  : unifi                 : debianIOB1                               -  enabled
       system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : debianIOB1                               - disabled
       system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : debianIOB1                               - disabled
       system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: debianIOB1                               - disabled
       system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: debianIOB1                               - disabled
      + system.adapter.vis-2.0                  : vis-2                 : debianIOB1                               -  enabled
       system.adapter.vis-history.0            : vis-history           : debianIOB1                               - disabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debianIOB1                               - disabled
       system.adapter.vis-icontwo.0            : vis-icontwo           : debianIOB1                               - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : debianIOB1                               -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debianIOB1                               - disabled
       system.adapter.vis-justgage.0           : vis-justgage          : debianIOB1                               - disabled
       system.adapter.vis-map.0                : vis-map               : debianIOB1                               - disabled
       system.adapter.vis-material.0           : vis-material          : debianIOB1                               - disabled
       system.adapter.vis-materialdesign.0     : vis-materialdesign    : debianIOB1                               - disabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : debianIOB1                               - disabled
       system.adapter.vis.0                    : vis                   : debianIOB1                               -  enabled
      + system.adapter.web.0                    : web                   : debianIOB1                               -  enabled, port: 12085, bind: 0.0.0.0, run as: admin
       system.adapter.web.1                    : web                   : debianIOB1                               - disabled, port: 12090, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : debianIOB1                               -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : debianIOB1                               -  enabled
      + system.adapter.wled.0                   : wled                  : debianIOB1                               -  enabled
      + system.adapter.zigbee.0                 : zigbee                : debianIOB1                               -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.19   , installed 7.7.19
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "cameras"      : 2.1.2    , installed 2.1.2
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "dysonairpurifier": 3.2.7 , installed 3.2.7
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "heos"         : 2.2.1    , installed 2.2.4
      Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 5.0.7    , installed 5.0.5  [Updatable]
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
      Adapter    "netatmo-energy": 2.8.0   , installed 2.8.2
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openligadb"   : 1.9.1    , installed 1.9.1
      Adapter    "ping"         : 1.6.2    , installed 1.7.9
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "snmp"         : 3.3.0    , installed 3.3.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.3.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 4.0.1
      Adapter    "tuya"         : 3.16.0   , installed 3.17.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.5
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.2
      Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.3.9
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.6.0
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.6.0
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "web"          : 7.0.8    , installed 7.0.9
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.3
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
      Objects and States
      Objects:        83729
      States:         74561
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      W: https://dlm.mariadb.com/repo/maxscale/latest/apt/dists/trixie/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org/debian-security trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:7 https://dlm.mariadb.com/repo/mariadb-server/12.rolling/repo/debian trixie InRelease
      Hit:8 https://dlm.mariadb.com/repo/maxscale/latest/apt trixie InRelease
      Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
      Reading package lists...
      Pending Updates: 0
      Leider weis ich noch nicht mal in welcher Richtung ich suchen sollte um den Fehler zu finden ......
      mfg
      Digi-Bit
      • crunchip
        crunchip Forum Testing Most Active @Digi-Bit last edited by
        @digi-bit sagte in javascript.0 bricht ab:
        vllt mal haken entfernen
        dab6f982-b323-47b9-935b-0b75bf8ea2fd-image.png ![0_1762276442446_411dfac0-c976-4867-b376-0455afe51cd9-image.png](Lade 100% hoch)
        alle scripte mal stoppen
          ticaki last edited by ticaki
          Das npm module setObjects gibts nicht, daher das aus dem npm custom install entfernen
          Alle Scripte stoppen und dann schauen welches da in einer Endlosschleife den Speicher vollschreibt.
            Digi-Bit @ticaki last edited by
            Moin,
            Ich habe jetzt alle Skripte abgeschaltet aber wie kann es sein das da noch was passiert
            silly
            ⇥4499/↦2000
            1 3 * * *
            8192 MB
            1: Logikadapter
            debianIOB1
            Wenn alle Skripte auf Pause sind dann werden die doch nicht mehr beachtet oder ?
            mfg
            Digi-Bit
              ticaki @Digi-Bit last edited by ticaki
              @digi-bit
              Expert im Javascript-adapter aktivieren und mal in global gucken? Javascript-adapter stoppen 15 Sekunden warten und dann starten. Screenshot der Konfig zeigen.
                Digi-Bit @ticaki last edited by Digi-Bit
                @ticaki
                Moin,
                Also das mit dem Expert im Javascript-adapter finde ich nicht
                  paul53 @Digi-Bit last edited by paul53
                  @digi-bit sagte: das mit dem Expert im Javascript-adapter finde ich nicht
                  Im Javascript-Editor der Kopf (4. Symbol oben):
                  Den Expertenmodus muss man aktivieren, wenn man die Gruppe "global" auswählen möchte.
                    Digi-Bit @paul53 last edited by
                    Ah, ok ^^
                    Also in "Global" sind keine Skripte drin
                      @digi-bit
                      Mache mal den script mirror aus.
                      EDIT: ich sehe das der Adapter auf debug steht - gib mal das Log von einem Restart bis zum Absturz - aber bitte aus dem Download-Log.
                        @ticaki
                        welcher Restart ?
                        Vom IOB oder vom Java ?
                          @digi-bit
                          javascript-adapter
                          Ich meine das log von da:
                            @ticaki
                            Hat etwas gedauert aber ich muss was tun um Leben zu können wie die meisten denke ich mal ^^
                            Hier das log:
                            iobroker.2025-11-05.html
                            Jetzt bin ich ja mal gespannt .....
                            mfg
                            Digi-Bit
                            crunchip T 2 Replies Last reply Reply Quote 0
                            • crunchip
                              @digi-bit für was soll das sein?
                              javascript.0 (43084) Schedule restart: 1 3 * * *
                                @digi-bit
                                Das da ist aber mit allen Skripten am laufen, ich wollte das log mit ausgeschalteten skripten.
                                Der Heap läuft über - bedeutet, das du entweder endlos Daten hinzufügst oder mit zu großen Datenmengen arbeitest. Das dürfe ohne aktivierte Skripte nicht passieren. Deshalb will ich das log mit ausgeschalteten Skripten sehen.
                                  Digi-Bit @crunchip last edited by
                                  @crunchip sagte in javascript.0 bricht ab:
                                  das weis ich auch nicht, ich weis nur das um 3 Uhr schon seit der ersten IOB Installation die Skripte neu starten.
                                  mfg
                                  Digi-Bit
                                    @ticaki sagte in javascript.0 bricht ab:
                                    @digi-bit
                                    mit Ausgeschalteten Skripten rannst der Adapter aber nicht ab, glaub ich, nur das da irgendwelche in und Output's angezeigt werden.
                                    Aber werde ich Morgen dann mal für eine weile mit Abgeschalteten Skripten laufen lassen für eins 2 Stunden mal sehen was passiert.
                                    mfg
                                    Digi-Bit
                                    paul53 T OliverIO 3 Replies Last reply Reply Quote 0
                                      @digi-bit sagte: irgendwelche in und Output's angezeigt werden.
                                      Das passiert auch ohne laufende Skripte, da die Javascript-Instanz alle Zustände abonniert, also der JS-Puffer ständig synchronisiert wird.
                                        @digi-bit
                                        Dann hab ich das falsch verstanden sorry - dann mußt du die Skripte durchprobieren - geht am schnellsten wenn du 50% an machst, wenns stabil läuft ist das problem in der anderen hälfte und das solange bist du es weißt 🙂
                                        • OliverIO
                                          OliverIO @Digi-Bit last edited by OliverIO
                                          @digi-bit
                                          Wie viele Datenpunkte hast du den insgesamt?
                                          und gibt es da viele, die sehr oft aktualisiert werden?
                                          ok, gefunden
                                          Objects and States
                                          Objects: 83729
                                          States: 74561
                                          ist auch nicht übermäßig viel, ausser du speicherst binär daten in den datenpunkten, aber das würde glaube ich den heap nicht betreffen.
                                          heap überlauf kommt meist von rekursiv aufgerufenen funktionen die kein endebegrenzer haben oder falsch programmierte event oder timer handler (was wieder memmory leaks erzeugt, die nicht aufgeräumt werden können)
                                          daher so wie geschrieben erstmal den adapter ohne skripte starten. dann dürfte das nicht mehr passieren.
                                          dann der reihe nach die skripte starten und jeweils eine weile warten.
                                          bewährte methode ist bei bspw 20 skripte
                                          zunächst 10 anschalten und dann eine weile warten (1-2h bzw je nachdem wie schnell sich das problem nach neustart bei dir aufgebaut hat)
                                          dann nach der wartezeit, weitere 50%, also 5 dazuschalten und so fort. wenn du ein segment an skripten gefunden hast was verrückt gespielt hat, dann nur das aktivieren und der reihe nach durchprobieren (wenn es immer noch sehr viele im segment sind, dann wieder die jeweils 50% methode anwenden, da es bei einzelnem zuschalten dann doch länger dauern kann, bis das böse skript identifiziert ist.
                                          ist das problem schon immer oder "plötzlich" nach einem update oder nachdem du skripte bearbeitet hast?
                                          problem ist auch, wenn der speicherzuwachs relativ langsam vorsich geht, dauert es auch länger wenn viele skripte abgeschaltet sind, da ja dann mehr speicher frei ist und es daher erst später zum problem kommt.
                                          Codierknecht T 2 Replies Last reply Reply Quote 0
                                          • Codierknecht
                                            Codierknecht Developer Most Active @OliverIO last edited by
                                            @oliverio sagte in javascript.0 bricht ab:
                                            Ja - z.B. der Kandidat #1: Trigger in Trigger
                                            1.1k
                                            javascript
                                            326
