    4. 0.6.5 installation
    0.6.5 installation
      Pman last edited by
      Ich kann die 0.6.5 nicht installieren. Log:
      install adapter vis
      npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
      npm
      WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
      got /opt/iobroker/node_modules/iobroker.vis/admin
      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
      ERROR:
      ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
      ERROR:                             console.warn('Adapter "' + obj._id + ' is disabled                                                          ^
      ERROR: TypeError: Cannot read property '_id' of null    at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
          at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
          at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      ERROR: process exited with code 8</anonymous></anonymous></anonymous>
        Ich hab es auch gerade probiert.
        Lief sehr schnell, konnte daher nicht alles sehen
        War auch ein cannot run in wd dabei, dann lief es schnell weiter und endete schließlich in exit with code 0 OK!
        Habe es am tablet über den admin gemacht. Komme im Moment auch nicht an das vollständige log.
        Gesendet von meinem LIFETAB_S785X mit Tapatalk
          Pman last edited by
          Habe schon alles probiert, löschen und neu installieren gibt den selben Fehler. Irgendwas ist da wohl wieder schief gelaufen bei mir :evil:
            Hast du beim controller die 0.7.4?
              Pman last edited by
              Ja, 0.7.4 und auch sonst alles auf neustem Stand.
              EDIT:
              iobroker update gibt viele Fehler:
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-material-png/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-material-svg/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-mfd-png/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-mfd-svg/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-open-icon-library-png/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.icons-ultimate-png/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.megad/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.mqtt/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.node-red/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.s7/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sayit/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.simple-api/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.pushover/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-colorpicker/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-hqwidgets/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-lcars/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis-metro/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/package.json. Error: Error: ETIMEDOUT
              update done
              Adapter    "zwave"         : 0.1.0
              Adapter    "yr"            : 0.1.7
              Adapter    "web"           : 0.4.2    , installed 0.4.2
              Adapter    "vis-metro"     : 0.1.2
              Adapter    "vis-lcars"     : 0.1.4
              Adapter    "vis-hqwidgets" : 0.1.0
              Adapter    "vis-colorpicker": 0.1.0
              Adapter    "vis"           : 0.6.5
              Adapter    "sonos"         : 0.1.6
              Adapter    "rickshaw"      : 0.2.2
              Adapter    "pushover"      : 0.1.1    , installed 0.1.1
              Adapter    "owfs"          : 0.0.2
              Adapter    "onkyo"         : 0.1.9
              Adapter    "socketio"      : 0.4.4
              Adapter    "simple-api"    : 0.1.1
              Adapter    "sayit"         : 0.3.9
              Adapter    "s7"            : 0.1.2
              Adapter    "ping"          : 0.1.4    , installed 0.1.4
              Adapter    "node-red"      : 0.3.3
              Adapter    "mqtt"          : 0.2.9    , installed 0.2.9
              Adapter    "megad"         : 0.1.1
              Adapter    "legacy"        : 0.1.12
              Adapter    "knx"           : 0.0.1
              Controller "js-controller" : 0.7.4    , installed 0.7.4
              Adapter    "javascript"    : 0.4.13   , installed 0.4.13
              Adapter    "icons-ultimate-png": 0.1.0    , installed 0.1.0
              Adapter    "icons-open-icon-library-png": 0.1.1
              Adapter    "icons-mfd-svg" : 0.1.0    , installed 0.1.0
              Adapter    "icons-mfd-png" : 0.1.0
              Adapter    "icons-material-svg": 0.1.0
              Adapter    "icons-material-png": 0.1.0
              Adapter    "icons-addictive-flavour-png": 0.1.0
              Adapter    "ical"          : 1.0.2
              Adapter    "hmm"           : 0.1.1    , installed 0.1.1
              Adapter    "hue"           : 0.3.0    , installed 0.3.0
              Adapter    "hm-rpc"        : 0.5.1    , installed 0.5.1
              Adapter    "hm-rega"       : 0.2.2    , installed 0.2.2
              Adapter    "history"       : 0.1.3
              Adapter    "example"       : 0.1.1    , installed 0.1.1
              Adapter    "fritzbox"      : 0.2.1
              Adapter    "flot"          : 0.1.1
              Adapter    "email"         : 0.1.2
              Adapter    "dwd"           : 0.1.9    , installed 0.1.9
              Adapter    "cul"           : 0.0.4
              Adapter    "b-control-em"  : 0.1.1
              Adapter    "artnet"        : 0.0.3
              Adapter    "admin"         : 0.5.4    , installed 0.5.4
              • htrecksler
                Bei mir hat's geklappt. Erst den Controller und dann vis.
                Anschließend kompletter Neustart. –> läuft.
                Nur die paar hqwidgets die ich im Einsatz hatte sind jetzt weg.
                Also immer schön Bluefox in Ruhe lassen damit er die fertig kriegt 😄 😄 😄
                  @Pman:
                  EDIT:
                  iobroker update gibt viele Fehler: `
                  Ja, seit ca. zwei Wochen gibt es bei der Art update die Timeouts.
                  Vielleicht sind es ja die Ursachen für dein Problem.
                  Außerdem scheint es für mich, als ob der npm-server am Wochenende immer Probleme hat.
                  Ein Versuch (von einem Laien):
                  cd /opt/iobroker
                  npm cache clean
                  npm install iobroker.vis --production
                  Viel Glück
                    Pman last edited by
                    npm http GET https://registry.npmjs.org/iobroker.vis
                    npm http 200 https://registry.npmjs.org/iobroker.vis
                    npm http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.5.tgz
                    npm http 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.5.tgz
                    > iobroker.vis@0.6.5 install /opt/iobroker/node_modules/iobroker.vis
                    2015-07-26 10:51:07.185  - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
                    2015-07-26 10:51:10.467  - info: vis.0 Changes in index.html detected => update cache.manifest
                    2015-07-26 10:51:10.525  - info: vis.0 Upload vis anew, while changes detected...
                    2015-07-26 10:51:16.656  - error: vis.0
                    2015-07-26 10:51:16.663  - error: vis.0 /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275                            console.warn('Adapter "' + obj._id + ' is disabled
                    2015-07-26 10:51:16.945  - error: vis.0 TypeError: Cannot read property '_id' of null    at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                    2015-07-26 10:51:16.984  - info: vis.0 Uploaded.
                    iobroker.vis@0.6.5 node_modules/iobroker.vis</anonymous></anonymous></anonymous>
                      Also mit den Fehlermeldungen müsste Bluefox was anfangen können - ich kann es nicht 😞
                      Nur noch vorsorglich die Frage zu deiner Hardware:
                      Deinen anderen posts hatte ich entnommen, dass du vielleicht mit Äpfeln arbeitest ???
                        susouke last edited by
                        also ich kann das Problem bestätigen. Leider bin ich noch sehr neu was ccu.io/iobroker angeht.
                        Hab gerade meine raspberrypi2 neu aufgesetzt und iobroker neu installiert, jetzt hänge ich bei dem beschriebenen Problem mit "VIS" fest.
                        Es war also nichts installiert außer das nackte Raspian, nodejs ist 0.10.22
                        Vorher lief iobroker ohne Probleme, allerdings weiß ich nicht mehr welche Version ich verwendet habe. Das Setup war ca. 2 Wochen alt.
                          Hallo susouke und Willkommen im Forum,
                          @susouke:
                          Hab gerade meine raspberrypi2 neu aufgesetzt und iobroker neu installiert, `
                          komplett neu - jetzt gerade??
                          RasPi plattgemacht??
                          @susouke:
                          Vorher lief iobroker ohne Probleme, allerdings weiß ich nicht mehr welche Version ich verwendet habe. Das Setup war ca. 2 Wochen alt. `
                          hast du da drüberinstalliert?
                            danke 🙂
                            @susouke:
                            RasPi plattgemacht?? `
                            Den Raspi2 hab ich extra für ccu.io bestellt und danach festgestellt das iobroker doch etwas cooler ist 😄
                            Das ganze Thema ist noch sehr neu für mich, hab über noobs einfach das Image neu installiert (das wird ersetzt).
                            Also iobroker ist komplett gelöscht und muss dann neu installiert werden. Das habe ich gemacht und jetzt hänge ich fest 😄
                              @susouke:
                              Also iobroker ist komplett gelöscht und muss dann neu installiert werden. Das habe ich gemacht und jetzt hänge ich fest `
                              Bei einem neueinspielen des Images wohl eher "ausradiert" 😉
                              Gut,
                              Installation, gemäß http://www.iobroker.net/docu/?page_id=4 … stallation ??
                              • nodejs installiert
                              • mkdir /opt/iobroker
                              • cd /opt/iobroker
                              • npm install iobroker
                              Danach bist du noch auf den admin gekommen?
                              • von dort aus vis-Instanz erstellt?
                              • Aufruf von <ipdesraspi>:8082/vis/edit.html klappt nicht??
                              Irgendwelche Fehlermeldungen in der Konsole?
                              Irgendwelche Fehlermeldungen im log?
                              Soweit erstmal
                              Rainer</ipdesraspi>
                                Ja genau so habe ich es gemacht inkl. das mit root.
                                Admin-Seite geht ohne Probleme darüber wollte ich dan vis installieren, das ist die Ausgabe:
                                ! $ ./iobroker add vis
                                ! install adapter vis
                                ! npm install –production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                                ! npm
                                ! WARN cannot run in wd iobroker.vis@0.6.5 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                                ! got /opt/iobroker/node_modules/iobroker.vis/admin
                                ! upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                ! upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                ! ERROR:
                                ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275
                                ! ERROR: console.warn('Adapter "' + obj._id + ' is disabled ^
                                ! ERROR: TypeError: Cannot read property '_id' of null at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2275:59)
                                ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                                ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                                ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                                ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                ! at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                                ! at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                                ! ERROR: process exited with code 8</anonymous></anonymous></anonymous>
                                Das gleiche steht natürlich auch im normalen log.
                                Ich kann schauen ob in der Konsole noch was kommt…
                                  Das müsste Bluefox sich ansehen, Sorry
                                    @susouke:
                                    ! npm
                                    ! ERROR:
                                    Ich kann schauen ob in der Konsole noch was kommt… `
                                    Es ist folgendes. Normalerweise ist vis "enabled". Bei dir es ist disabled. (Kann das sein?)
                                    Du kannst trotzdem einfach vis updaten mit:
                                    cd /opt/iobroker
                                      VIS ist nicht enabled, es wird als installiert angezeigt in der Adapterliste (zumindest ist die Mülltonne zum entfernen da).
                                      Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert.
                                        @susouke:
                                        Es taucht aber nicht in der Instanzliste auf. Hab schon mehrfach ein update gemacht und auch nochmal neu installiert. `
                                        Mülltonne zeigt, dass Adapter auf der Festplatte ist und mit der Mülltonne kann man den von der Festplatte löschen.
                                        Instanz braucht man trotzdem.
                                          Es taucht solange nicht in der Instanzenliste auf, bis du es zugefügt hast.
                                          Im Reiter Adapter auf das + ganz rechts klicken, oder in der Konsole mit
                                          cd /opt/iobroker
                                          ./iobroker add vis
                                            Pman last edited by
                                            Der selbe Fehler kommt ja, wenn ich vis garnicht installiert habe (Verzeichnis iobroker.vis existiert auch nicht), nicht beim Update. Das Log im ersten Post ist bei der Installation von vis, nicht beim update.
                                            41
                                            5392
