    3. Tester
    4. Fehler bei npm Modulinstallation
      rwaechter last edited by
      Hallo liebe iobroker-Gemeinde,
      bei der Installation von zusätzlichen NPM-Modulen im Javascript-Adapter (3.4.0) erhalte ich nach 3 Installationsversuchen im LOG den Fehler error "Cannot install npm packet: pg@6.4.0".
      Weiß jemand Rat?
      Roland
      • apollon77
        apollon77 last edited by
        Vollständiges log bitte?
          Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
          javascript.0	2017-11-10 19:45:55.627	info	requesting all objects
          javascript.0	2017-11-10 19:45:55.627	info	requesting all states
          javascript.0	2017-11-10 19:45:55.626	error	Cannot install npm packet: pg@6.4.0
          javascript.0	2017-11-10 19:45:55.581	info	pg@6.4.0 iobroker/node_modules/iobroker.javascript/node_modules/pg ├── packet-reader@0.3.1 ├── pg-connection-string@0.1.3 ├── buffer-writer@1.0.1 ├── semver@4.3.2 ├── pg-pool@1.8.0 (object-assign@4.1.0, generic-pool@2.4.3) ├── pg-types@1.12.1 (postgres-bytea@1.0.0, postgres-array@1.0.2, postgres-date@1.0.3, postgres-interval@1.1.1) └── pgpass@1.0.2 (split@1.0.1)
          javascript.0	2017-11-10 19:45:48.142	info	npm install pg@6.4.0 --production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
          javascript.0	2017-11-10 19:45:48.102	info	pg@6.4.0 iobroker/node_modules/iobroker.javascript/node_modules/pg ├── packet-reader@0.3.1 ├── pg-connection-string@0.1.3 ├── buffer-writer@1.0.1 ├── semver@4.3.2 ├── pg-pool@1.8.0 (object-assign@4.1.0, generic-pool@2.4.3) ├── pg-types@1.12.1 (postgres-bytea@1.0.0, postgres-date@1.0.3, postgres-array@1.0.2, postgres-interval@1.1.1) └── pgpass@1.0.2 (split@1.0.1)
          javascript.0	2017-11-10 19:45:41.279	info	npm install pg@6.4.0 --production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
          javascript.0	2017-11-10 19:45:41.228	info	pg@6.4.0 iobroker/node_modules/iobroker.javascript/node_modules/pg ├── packet-reader@0.3.1 ├── pg-connection-string@0.1.3 ├── buffer-writer@1.0.1 ├── semver@4.3.2 ├── pg-pool@1.8.0 (object-assign@4.1.0, generic-pool@2.4.3) ├── pg-types@1.12.1 (postgres-bytea@1.0.0, postgres-array@1.0.2, postgres-date@1.0.3, postgres-interval@1.1.1) └── pgpass@1.0.2 (split@1.0.1)
          javascript.0	2017-11-10 19:45:33.561	info	npm install pg@6.4.0 --production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
          javascript.0	2017-11-10 19:45:33.558	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.7.3
          host.iobroker	2017-11-10 19:45:30.526	info	instance system.adapter.javascript.0 started with pid 2049
          host.iobroker	2017-11-10 19:45:28.124	info	instance system.adapter.javascript.0 terminated with code 0 (OK)
          javascript.0	2017-11-10 19:45:28.047	info	terminating
          host.iobroker	2017-11-10 19:45:27.992	info	stopInstance system.adapter.javascript.0 killing pid 1884
          host.iobroker	2017-11-10 19:45:27.990	info	stopInstance system.adapter.javascript.0
          Geändert: Code in Code-Tags; Homoran (Mod)
            paul53 last edited by
            Das kann an der Node-Version 4.7.3 liegen. Bei mir sieht das Log (unter Win 7 / Node v6.11.1) anders aus:
            javascript.0	2017-11-10 19:19:44.682	info	`-- semver@4.3.2
            javascript.0	2017-11-10 19:19:44.682	info	| `-- through@2.3.8
            javascript.0	2017-11-10 19:19:44.682	info	| `-- split@1.0.1
            javascript.0	2017-11-10 19:19:44.682	info	+-- pgpass@1.0.2
            javascript.0	2017-11-10 19:19:44.682	info	| `-- xtend@4.0.1
            javascript.0	2017-11-10 19:19:44.682	info	| `-- postgres-interval@1.1.1
            javascript.0	2017-11-10 19:19:44.682	info	| +-- postgres-date@1.0.3
            javascript.0	2017-11-10 19:19:44.682	info	| +-- postgres-bytea@1.0.0
            javascript.0	2017-11-10 19:19:44.682	info	| +-- postgres-array@1.0.2
            javascript.0	2017-11-10 19:19:44.682	info	+-- pg-types@1.12.1
            javascript.0	2017-11-10 19:19:44.682	info	+-- pg-pool@2.0.3
            javascript.0	2017-11-10 19:19:44.682	info	+-- pg-connection-string@0.1.3
            javascript.0	2017-11-10 19:19:44.682	info	+-- packet-reader@0.3.1
            javascript.0	2017-11-10 19:19:44.682	info	+-- js-string-escape@1.0.1
            javascript.0	2017-11-10 19:19:44.682	info	+-- buffer-writer@1.0.1
            javascript.0	2017-11-10 19:19:44.682	info	`-- pg@7.4.0
            javascript.0	2017-11-10 19:19:44.682	info	iobroker.javascript@3.4.0 C:\Program Files\ioBroker\node_modules\iobroker.javascript
            j
              Welche NODE-Version sollte ich denn auf dem Raspi verwenden?
                @rwaechter:
                Welche NODE-Version sollte ich denn auf dem Raspi verwenden? `
                alles > 6
                  Wobei bei npdejs v8 und höher npmv5.x mitgeliefert wird was wiederum zu problemen führen kann.
                  Dort sollte auf npm 3.x downgegradet werden.
                  31.7k
                  79.8k
