    4. Problem mit Homebridge bzw. Yahka Adapter
      Streetjewel last edited by
      Hi Zusammen,
      Habe den Adapter für Homekit installiert, dieser verbindet sich aber nicht.
      Desweiteren steigt ständig die Homebridge App aus nach zweimaligem drücken auf Autorepair ist sie verbunden, steigt aber nach ca. 30sec wieder aus.
      Beim Öffnen von Homekit, wird die Bridge nicht angezeigt.
      Habe mal meine LOG Files kopiert, vielleicht kann mir ja jemand weiterhelfen.
      host.raspberrypi 2017-11-17 17:46:52.754 info Restart adapter system.adapter.yahka.1 because enabled
      host.raspberrypi 2017-11-17 17:46:52.754 error instance system.adapter.yahka.1 terminated with code 1 ()
      host.raspberrypi 2017-11-17 17:46:52.754 error Caught by controller[0]: at Module.load (module.js:343:32)
      host.raspberrypi 2017-11-17 17:46:52.754 error Caught by controller[0]: at Object.Module._extensions..js (module.js:416:10)
      host.raspberrypi 2017-11-17 17:46:52.754 error Caught by controller[0]: at Module._compile (module.js:409:26)
      host.raspberrypi 2017-11-17 17:46:52.753 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/node_modules/mdns/lib/dns_sd.js:24:20)
      host.raspberrypi 2017-11-17 17:46:52.753 error Caught by controller[0]: at require (internal/module.js:12:17)
      host.raspberrypi 2017-11-17 17:46:52.753 error Caught by controller[0]: at Module.require (module.js:353:17)
      host.raspberrypi 2017-11-17 17:46:52.753 error Caught by controller[0]: at Function.Module._load (module.js:300:12)
      host.raspberrypi 2017-11-17 17:46:52.753 error Caught by controller[0]: at Module.load (module.js:343:32)
      host.raspberrypi 2017-11-17 17:46:52.752 error Caught by controller[0]: at Object.Module._extensions..node (module.js:434:18)
      host.raspberrypi 2017-11-17 17:46:52.752 error Caught by controller[0]: at Error (native)
      host.raspberrypi 2017-11-17 17:46:52.752 error Caught by controller[0]: Error: Module version mismatch. Expected 46, got 51.
      host.raspberrypi 2017-11-17 17:46:52.752 error Caught by controller[0]: ^
      host.raspberrypi 2017-11-17 17:46:52.751 error Caught by controller[0]: throw ex;
      host.raspberrypi 2017-11-17 17:46:52.751 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/mdns/lib/dns_sd.js:35
