    4. Iobroker startet nicht mehr nach Ubuntu update
      sveni_lee last edited by
      ich habe iobroker auf meinem Ubuntu-Server 16.04.02 installiert. gestern habe ich ein update gemacht und den Server neu gestartet. Seit dem startet iobroker nicht mehr..
      iobroker-log
      <code>2017-11-16 22:31:53.309  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
      2017-11-16 22:31:53.313  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
      2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v4.8.6
      2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxx.xxxx.x.x.xxxx
      2017-11-16 22:31:53.354  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
      2017-11-16 22:31:53.366  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
      2017-11-16 22:31:53.373  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
      2017-11-16 22:31:53.374  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
      2017-11-16 22:31:53.379  - ^[[32minfo^[[39m: host.Gotham-City no instances found
      2017-11-16 22:31:53.390  - ^[[31merror^[[39m: uncaught exception: logger is not defined
      2017-11-16 22:31:53.393  - ^[[31merror^[[39m: ReferenceError: logger is not defined
          at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9)
          at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27
          at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
          at Timer.listOnTimeout (timers.js:92:15)
      2017-11-16 22:31:53.395  - ^[[32minfo^[[39m: host.Gotham-City terminated
      2017-11-16 22:31:53.404  - ^[[32minfo^[[39m: iobroker _restart
      2017-11-16 22:31:53.678  - ^[[32minfo^[[39m: iobroker Starting node restart.js
      2017-11-16 22:31:53.685  - ^[[32minfo^[[39m: iobroker exit 0
      2017-11-16 22:31:53.824  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
      2017-11-16 22:31:53.825  - ^[[32minfo^[[39m: host.Gotham-City terminated[/code]</code>
        @sveni_lee:
        gestern habe ich ein update gemacht `
        Wovon?
        @sveni_lee:
        iobroker-log `
        Was ist da ausgeixt?
        Ist das ein Multihost-System?
          hier mal ohne xxxx
          2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 + IPv6 Adressen
          Updates waren ganz normale systemupdates von Linux
          ja, es ist ein Multihost
            ich wollte die Werte nicht sehen, nur wissen was es ist.
            Habe die IPv6 Adressen unkenntlich gemacht.
            @sveni_lee:
            ja, es ist ein Multihost `
            deswegen wahrscheinlich auch die @sveni_lee:
            IP address is for states is 0.0.0.0 `
            die er jetzt anmeckert, Warum auch immer.
            Findet das Ganze etwa in einer virtuellen Maschine statt?
              Nein, keine virtuelle Umgebung…
              Nach dem Neustart lies sich iobroker nicht mehr starten...
              Gesendet von iPhone mit Tapatalk Pro
              • Dutchman
                @sveni_lee:
                Gesendet von iPhone mit Tapatalk Pro `
                Hat sich da eventuell ein node update mit eingeschlichen was die das System zermurkst hat?
                Dan könnte es helfen die reinstall.sh aus zu führen.
                Was sagt node -v und npm -v
                ~Dutch
                Send from mobile device
                  svenilee@Gotham-City:~$ node -v
                  v4.8.6
                  svenilee@Gotham-City:~$ npm -v
                  2.15.11
                  wie kann ich die reinstall ausführen?
                  svenilee@Gotham-City:/opt/iobroker$ sudo ./reinstall.sh
                  sudo: unable to execute ./reinstall.sh: No such file or directory
                  Aufgelegt
                  • eric2905
                    eric2905 last edited by
                    Dein npm ist recht alt.
                    Aktualisiere mal bitte (Hilfe gibt es hier ==> http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs)
                    Gruß,
                    Eric
                    Gesendet von iPad mit Tapatalk
                      so, update habe ich gemacht… ist aber alles unverändert
                      svenilee@Gotham-City:/opt/iobroker$ node -v
                      v6.12.0
                      svenilee@Gotham-City:/opt/iobroker$ npm -v
                      3.10.10
                      • Dutchman
                        Die Datei reinstall.sh ist aber in den Verzeichnis?
                          ja, ist da…
                          svenilee@Gotham-City:/opt/iobroker$ ls -la
                          insgesamt 44
                          drwxrwxrwx  6 root     root     4096 Mai 21 10:49 .
                          drwxr-xr-x  4 root     root     4096 Sep 27 09:25 ..
                          drwxrwxrwx  2 root     root     4096 Mai 21 10:48 etc
                          -rwxrwxrwx  1 root     root      297 Mai 21 10:49 install.sh
                          -rwxrwxrwx  1 root     root       67 Mai 21 10:49 iobroker
                          drwxrwxrwx  3 root     root     4096 Sep 22 17:02 iobroker-data
                          -rwxrwxrwx  1 root     root       92 Nov 17 08:41 killall.sh
                          drwxrwxrwx  2 root     root     4096 Nov 17 19:17 log
                          drwxrwxrwx 31 svenilee svenilee 4096 Nov 17 08:41 node_modules
                          -rwxrwxrwx  1 root     root      116 Mai 21 10:49 package.json
                          -rwxrwxrwx  1 root     root      688 Nov 17 08:41 reinstall.sh
                          • Dutchman
                            Und wenn du in den Verzeichnis bist und das ./ Mal weck läst?
                              paul53 last edited by
                              Wie man an der Dateigröße (688 Byte) sieht, hat reinstall.sh DOS-Format (CR/LF anstelle LF) und muss erst in das http://forum.iobroker.net/viewtopic.php?f=17&t=8530&p=94147#p94110.
                                funktioniert bei mir nicht…
                                nach
                                tr -d '\r' < /opt/iobroker/reinstall.sh > /opt/iobroker/reinstall.sh
                                ist die Größe null
                                • eric2905
                                  Evtl. weil Du die Datei überschreibst?
                                  Mal mit einem neuen Ziel-Dateinamen probiert?
                                  Gruß,
                                  Eric
                                    Yeep… das wars
                                    Dann mach ich mal nen reinstall.
                                      ist nicht ganz sauber durchgelaufen…
                                      DONE iobroker.javascript
                                      npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
                                      npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                                      npm WARN prefer global npm@2.15.12 should be installed with -g
                                      > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                                      > node-gyp rebuild
                                      gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0"
                                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
                                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                                        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                        COPY Release/unix_dgram.node
                                      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                                      > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
                                      > node-gyp rebuild
                                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
                                      make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird betreten
                                        CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                                        SOLINK_MODULE(target) Release/obj.target/ursaNative.node
                                        COPY Release/ursaNative.node
                                      make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
                                      npm ERR! code 1
                                      FAIL iobroker.socketio
                                      iobroker@1.0.0 /opt/iobroker
                                      └─┬ iobroker.tankerkoenig@1.0.4
                                        └─┬ xml2js@0.2.8
                                          └── sax@0.5.8
                                      DONE iobroker.tankerkoenig
                                      npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
                                      npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                                      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                      npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
                                      npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
                                      ./reinstall.sh: Zeile 34: Dateiende beim Suchen nach »"« erreicht.
                                      ./reinstall.sh: Zeile 37: Syntaxfehler: Unerwartetes Dateiende.
                                      • eric2905
                                        Ggf. das Original-reinstall.sh mal mit einem FTP vom Linux ziehen und die Datei mit einem "vernünftiges" Editor wieder umkonvertierten.
                                        Gruß,
                                        Eric
                                          Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
                                          493_reinstall.sh.txt
                                            so, alles gemacht aber noch kein erfolg…
                                            2017-11-17 22:05:40.282  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
                                            2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
                                            2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
                                            2017-11-17 22:05:40.289  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx
                                            2017-11-17 22:05:40.337  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
                                            2017-11-17 22:05:40.358  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
                                            2017-11-17 22:05:40.365  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
                                            2017-11-17 22:05:40.367  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
                                            2017-11-17 22:05:40.371  - ^[[32minfo^[[39m: host.Gotham-City no instances found
                                            2017-11-17 22:05:40.381  - ^[[31merror^[[39m: uncaught exception: logger is not defined
                                            2017-11-17 22:05:40.383  - ^[[31merror^[[39m: ReferenceError: logger is not defined
                                                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
                                                at ontimeout (timers.js:386:11)
                                                at tryOnTimeout (timers.js:250:5)
                                                at Timer.listOnTimeout (timers.js:214:5)
                                            2017-11-17 22:05:40.388  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                            2017-11-17 22:05:40.396  - ^[[32minfo^[[39m: iobroker _restart
                                            2017-11-17 22:05:40.652  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                                            2017-11-17 22:05:40.662  - ^[[32minfo^[[39m: iobroker exit 0
                                            2017-11-17 22:05:40.776  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
                                            2017-11-17 22:05:40.777  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                            einen Fehler gab es doch beim reinstall
                                            iobroker.core@0.1.0 /opt/iobroker
                                            └── (empty)
                                            npm ERR! code 1
                                            2905
