    4. Wifi Light Adapter Milight
      Matze1708 last edited by
      habe mir von Amazon RGBW LED Stripes gekauft mit einem Wifi LED RGBW Controller.
      Der Discovery Adpater erkennt diesen als Wifi Milight Adpater. Wollte diesen installieren. Geht aber nicht, folgendes wird mir ausgegeben. Was muss ich tun?
      host.ioBroker-RasPi	2017-11-25 13:55:14.127	error	instance system.adapter.wifilight.0 terminated with code 1 ()
      Caught	2017-11-25 13:55:14.127	error	by controller[0]: at startup (bootstrap_node.js:149:9)
      Caught	2017-11-25 13:55:14.127	error	by controller[0]: at run (bootstrap_node.js:383:7)
      Caught	2017-11-25 13:55:14.127	error	by controller[0]: at Module.runMain (module.js:604:10)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Function.Module._load (module.js:438:3)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at tryModuleLoad (module.js:446:12)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Module.load (module.js:487:32)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Module._compile (module.js:570:32)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20)
      Caught	2017-11-25 13:55:14.126	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1141:23)
      Caught	2017-11-25 13:55:14.125	error	by controller[0]: TypeError: fns.adapter is not a function
      Caught	2017-11-25 13:55:14.125	error	by controller[0]: ^
      Caught	2017-11-25 13:55:14.125	error	by controller[0]: fns.adapter = fns.adapter(options);
      Caught	2017-11-25 13:55:14.125	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1141
      host.ioBroker-RasPi	2017-11-25 13:55:13.594	info	instance system.adapter.wifilight.0 started with pid 24090
      Danke und Lieber Gruß Matthias
        Hallo Matthias,
        @Matze1708:
        Wollte diesen installieren. Geht aber nicht `
        Das erscheint mir nicht korrekt, hilft dir aber nicht ,-) . Der Adapter ist anscheinend installiert, die Instanz will nur nicht.
        Bitte weitere Informationen zu Versionen von js-Controller, Admin, OS, und Hardware.
          korrekt, installiert ist er startet nur nicht. Mein Fehler!
          Es läuft auf einem Raspberry Pi
          Host ist 1.2.0 Javascript/Node.js
            Habe den Adapter deinstalliert. Den npm cache geleert und neuinstalliert…
            Habe den host und alle Adapter auf den neusten stand gebracht.
            Immer noch der gleiche Fehler !
            Ist da was am WifiLight Adapter nicht ok?
            node node_modules/iobroker.wifilight/wifilight.js --logs --force
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20)
                at startup (bootstrap_node.js:149:9)</anonymous>
              interessant ist, das es auf einem anderen IoBroker auf einem RasPi ohne weiteres läuft.
              Lässt vermuten, das dem Pi auf dem es laufen soll, irgendetwas fehlt. Nur was. da werde ich aus der Fehlermeldung nicht schlau.
