    4. Update auf 1.2.3 funktioniert nicht
      jensus11 last edited by
      Hi, ich wollte heute auf die neue js-controller version 1.2.3 updaten.
      Dabei bekomme ich folgende Fehlermeldung und iobroker lässt sich danach nicht mehr starten.
      Update js-controller from @1.2.0 to @1.2.3
      npm install iobroker.js-controller@1.2.3 --production --prefix "/opt/iobroker" (System call)
      npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! Linux 4.9.0-4-amd64
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.3" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v6.12.0
      npm ERR! npm  v3.10.10
      npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall rename
      npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
      host.debianioBroker Cannot install iobroker.js-controller@1.2.3: 254
        Ich hatte auch ein Problem, http://forum.iobroker.net/search.php?keywords=js+controller+update&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Suche hat mir weiter geholfen:
        http://forum.iobroker.net/viewtopic.php?f=17&t=9100&p=97758&hilit=js+controller+update#p97758 hatte mir hiermit die Lösung gebracht, allerdings erstmal nur Version 1.2.2! Aber es lief wieder!
        @Bluefox:
        Ich empfehle die neuste js-controller vom github zu installieren:
        cd /opt/iobroker
        iobroker stop
        npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
        iobroker start
        Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren. `
        Enrico
          so update auf 1.2.2 hat geklappt mit tarball/master–production.
          Dann mit upgrade self weiter gemacht und jetzt kommt das.
          npm ERR! errno -2
          npm ERR! enoent
          npm ERR! code 1
          Host "debianioBroker" (linux) updated
          Execute: chmod -R 777 /opt/iobroker
          Chmod finished. Restart controller
          Starting node restart.js
           Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
           Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
          root@debianioBroker:/opt/iobroker# iobroker start
          module.js:471
              throw err;
              at Function.Module._resolveFilename (module.js:469:15)
              at Function.Module._load (module.js:417:25)
              at Module.runMain (module.js:604:10)
              at run (bootstrap_node.js:383:7)
              at startup (bootstrap_node.js:149:9)
              at bootstrap_node.js:496:3
            @jensus11:
            so update auf 1.2.2 hat geklappt mit tarball/master–production. `
            Lass es erstmal dabei, bis sich hier jemand meldet, der mehr Ahnung hat als ich, wichtiger ist doch, dass es wieder läuft. Also nochmal ohne danach wieder upgrade self einzugeben.
            Enrico
              bei dem Slave ist das update auf 1.2.3 super durchgelaufen.
              • lobomau
                lobomau last edited by
                @jensus11:
                bei dem Slave ist das update auf 1.2.3 super durchgelaufen. `
                Bei mir auch. Pi3-slave Update von 1.2 auf 1.2.3 ohne Probleme.
                Beim Master traue ich mich noch nicht… :roll:
                  @jensus11:
                  Bei mir auch, Master (PC mit Ubuntu, glaub 16?) ging bei mir nur so, wie oben beschrieben! 😞
                  Der Workaround oben hat dann wenigstens die Version 1.2.2 gebracht!
                  Enrico
                    knopers1 last edited by
                    hmm, die Version 1.2.3 wurde installiert, jedoch spuckt es Fehler beim Starten aus…
                    root@orangepiplus2e:/opt/iobroker# iobroker start
                    Starting iobroker controller daemon...
                    /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                    throw new Error(msg.error);
                    Error: Error: Cannot find module 'winston/lib/winston/common'
                    at Module.require (module.js:497:17)
                    at require (internal/module.js:20:19)
                    at Object. <anonymous>(/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:6:14)
                    at Module._compile (module.js:570:32)
                    at Object.Module._extensions..js (module.js:579:10)
                    at Module.load (module.js:487:32)
                    at tryModuleLoad (module.js:446:12)
                    at Function.Module._load (module.js:438:3)
                    at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
                    at emitTwo (events.js:106:13)
                    at ChildProcess.emit (events.js:191:7)
                    at process.nextTick (internal/child_process.js:787:12)
                    at _combinedTickCallback (internal/process/next_tick.js:73:7)
                    at process._tickCallback (internal/process/next_tick.js:104:9)
                    root@orangepiplus2e:/opt/iobroker#</anonymous></anonymous>
                      @knopers1:
                      Bei dir könnte helfen:
                      npm install winston
                      Das musste ich bei mir, allerdings auf 1.2.2 auch machen, diesen Fehler hatte ich auch drin!
                      Enrico
                        Tiger015 last edited by
                        Hallo
                        Habe so ein ähnliches problem. Bekommen den admin Bereich auch nicht mehr zum laufen.
                        Bekomme immer diese meldung
                        Error: listen EADDRINUSE 0.0.0.0:9001
                        at Object.exports._errnoException (util.js:1020:11)
                        at exports._exceptionWithHostPort (util.js:1043:20)
                        at Server._listen2 (net.js:1262:14)
                        at listen (net.js:1298:10)
                        at net.js:1408:9
                        at _combinedTickCallback (internal/process/next_tick.js:83:11)
                          Ist es ein RasPi1??
                          (sonst) mach mal einen reboot.
                          Wenn es (bei nicht Pi1) dann wiederkommt hast du ggf. statt drüberzuinstallieren eine zweite Instanz angelegt?
                            Es handelt sich um einen Pi3 und reboot und nach der anleitung hier habe ich es auch schon versucht.
                            alles ohne erfolg.
                            Befehlt iobroker status gibt zurück das es lauft.
                            update habe ich auch alle neu auf gespielt it update self.
                            admin.0 port schon geänder bringt auch kein erfolg.
                              @Tiger015:
                              update habe ich auch alle neu auf gespielt it update self. `
                              update geht aber:
                              sudo iobroker stop
                              sudo iobroker update
                              sudo iobroker upgrade self
                              sudo iobroker start
                              Ich würde aber eher diese Methode wählen:
                              sudo iobroker stop
                              npm cache clean
                              sudo iobroker start
                              Was mich noch irritiert ist:
                              @Tiger015:
                              Hast du eine Multihost Installation?
                                Nein ist kein Multihorst
                                fehler war auch auf einmal von selber da seit heute nach mittage.
                                da vor lief alles noch einbar frei.
                                npm cache clean
                                sudo iobroker start
                                Rüchgabe nach der ausfürhrung:
                                npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                                npm WARN root No description
                                npm WARN root No repository field.
                                npm WARN root No README data
                                npm WARN root No license field.
                                root@raspberrypi3:~# iobroker start
                                iobroker controller daemon started. PID: 1982
                                admin ist aber immer nich nicht erreichbar
                                root@raspberrypi3:~# iobroker stop admin.0
                                events.js:160
                                      throw er; // Unhandled 'error' event
                                    at net.js:1408:9
                                  Ich würde mal sagen, davor fehlt ein:
                                  cd /opt/iobroker
                                  Oder?
                                  Enrico
                                    @RappiRN:
                                    CODE: ALLES AUSWÄHLEN
                                    cd /opt/iobroker `
                                    Das ist ja was ich meinte mit:
                                    @Homoran:
                                    hast du ggf. statt drüberzuinstallieren eine zweite Instanz angelegt? `
                                    Jetzt hat der TE zwei Installationen.
                                    Da sind die Ports natürlich doppelt vergeben.
                                      @RappiRN:
                                      cd /opt/iobroker
                                      Oder?
                                      Enrico `
                                      Gleiches ergebniss:
                                      root@raspberrypi3:~# cd /opt/iobroker
                                      root@raspberrypi3:/opt/iobroker# iobroker stop admin.0
                                      events.js:160
                                          at net.js:1408:9
                                        @Homoran:
                                        Da sind die Ports natürlich doppelt vergeben. `
                                        Dann brauchen wir jetzt ne Anleitung, wie einfach zu prüfen wäre, ob denn wirklich zwei Installationen da sind. Ich selbst würde über z.B. winSCP nachsehen, ob noch weitere ioBroker-Ordner angelegt wurden, aber das geht bestimmt auch eleganter! 😉
                                        Enrico
                                        • Dutchman
                                          @RappiRN:
                                          Enrico `
                                          Auf Linux gibt es dafür dass"find" Commando.
                                          Komme gerade nicht an meine Installation aber wenn du nach einer Datei/Ordner suchst die es nur im ioBroker Verzeichnis gibt solltest du fündig werden:
                                           Finding a directory
                                          To find a directory called apt in / (root) file system, enter:
                                          Alert: When searching / (root) file system, you need to run the find command as root user.
                                          find / -type d -name "apt"
                                          Sample outputs:
                                          /var/log/apt
                                          /var/lib/apt
                                          /var/cache/apt
                                          /etc/apt
                                          /etc/logrotate.d/apt
                                          /etc/cron.daily/apt
                                          https://www.google.nl/amp/s/www.cyberci … mmand/amp/
                                          Send from mobile device
                                            Bei mir hat das zur Lösung geführt.
                                            cd /opt/iobroker
                                            sudo chmod 777 * -R
                                            sudo npm install iobroker.js-controller --production
                                            3225
