    4. Zwave Adapter ROt + Fehlermeldung
      juergen123 last edited by
      Moin zusammen,
      bin totaler zwave iobroker noob 🙂
      Hab mein ioBroker aufgesetzt zwave installiert leider ist der Adapter im UI immer rot:
      Adapter ist eineGEN5 ZW090-C von Aeotec
      Raspi 3
      Fehlermdeldung
      host.ioBroker	2017-11-25 07:20:24.381	info	Restart adapter system.adapter.zwave.0 because enabled
      host.ioBroker	2017-11-25 07:20:24.381	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
      Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Module._compile (module.js:570:32)
      Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
      Caught	2017-11-25 07:20:24.379	error	by controller[0]: at require (internal/module.js:20:19)
      Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Module.require (module.js:497:17)
      Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Function.Module._load (module.js:438:3)
      Caught	2017-11-25 07:20:24.379	error	by controller[0]: at tryModuleLoad (module.js:446:12)
      Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Module.load (module.js:487:32)
      Caught	2017-11-25 07:20:24.378	error	by controller[0]: at Object.Module._extensions..node (module.js:597:18)
      Caught	2017-11-25 07:20:24.378	error	by controller[0]: at Error (native)
      Caught	2017-11-25 07:20:24.377	error	by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2017-11-25 07:20:24.340	info	terminating
      zwave.0	2017-11-25 07:20:24.259	error	at Object.Module._extensions..js (module.js:579:10)
      zwave.0	2017-11-25 07:20:24.259	error	at Module._compile (module.js:570:32)
      zwave.0	2017-11-25 07:20:24.259	error	at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
      zwave.0	2017-11-25 07:20:24.259	error	at require (internal/module.js:20:19)
      zwave.0	2017-11-25 07:20:24.259	error	at Module.require (module.js:497:17)
      zwave.0	2017-11-25 07:20:24.259	error	at Function.Module._load (module.js:438:3)
      zwave.0	2017-11-25 07:20:24.259	error	at tryModuleLoad (module.js:446:12)
      zwave.0	2017-11-25 07:20:24.259	error	at Module.load (module.js:487:32)
      zwave.0	2017-11-25 07:20:24.259	error	at Object.Module._extensions..node (module.js:597:18)
      zwave.0	2017-11-25 07:20:24.259	error	at Error (native)
      zwave.0	2017-11-25 07:20:24.259	error	Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2017-11-25 07:20:24.257	error	uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0	2017-11-25 07:20:24.111	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v6.12.0
      host.ioBroker	2017-11-25 07:20:22.653	info	instance system.adapter.zwave.0 started with pid 2762
      host.ioBroker	2017-11-25 07:19:52.636	info	Restart adapter system.adapter.zwave.0 because enabled
      Was mach ich falsch?
      gruß
      Jürgen
      • Dutchman
        @juergen123:
        gruß
        Jürgen `
        Du liest dir die readme nicht durch [emoji6]
         Known issues
        If you get the following (or similar) error after starting the adapter
        you can fix it by running
        sudo ldconfig
        or
        sudo ldconfig /usr/local
        or
        sudo ldconfig /usr/local/lib64
        https://github.com/ioBroker/ioBroker.zw … /README.md
        Send from mobile device
          Vielen Dank, hat sofort geklappt.
          Wie bekomm ich es hin das bei eimem KNX befehl das RGB Band angeht?
          ![](</s><URL url=)https://i.imgur.com/PLeR1qp.png" />
          • Dutchman
            Schau die mal die docu zu scenen oder blockly an damit kan man derartige Events erstellen.
            Sollte es nicht klappen bitten einen neuen thread mit deiner Frage und was du probiert hat 😉
