    4. Fehler beim Installieren von Adaptern
      Karl_999 last edited by
      Die Installation (fast) aller Adapter schlägt bei mir fehl.
      Hier die Aufzeichnung der letzten beiden Versuche
      iobroker	2017-11-26 18:32:09.506	info	exit 1
      iobroker	2017-11-26 18:32:09.419	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      iobroker	2017-11-26 18:32:09.419	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
      iobroker	2017-11-26 18:32:09.419	error	at net.js:1408:9
      iobroker	2017-11-26 18:32:09.419	error	at listen (net.js:1298:10)
      iobroker	2017-11-26 18:32:09.419	error	at Server._listen2 (net.js:1262:14)
      iobroker	2017-11-26 18:32:09.419	error	at exports._exceptionWithHostPort (util.js:1043:20)
      iobroker	2017-11-26 18:32:09.419	error	at Object.exports._errnoException (util.js:1020:11)
      iobroker	2017-11-26 18:32:09.419	error	Error: listen EADDRINUSE 127.0.0.1:9001
      iobroker	2017-11-26 18:32:09.419	error	^
      iobroker	2017-11-26 18:32:09.419	error	events.js:160 throw er; // Unhandled 'error' event
      iobroker	2017-11-26 18:31:55.453	info	add vis-hqwidgets
      iobroker	2017-11-26 18:30:33.129	info	exit 1
      iobroker	2017-11-26 18:30:33.037	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      iobroker	2017-11-26 18:30:33.037	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
      iobroker	2017-11-26 18:30:33.037	error	at net.js:1408:9
      iobroker	2017-11-26 18:30:33.037	error	at listen (net.js:1298:10)
      iobroker	2017-11-26 18:30:33.037	error	at Server._listen2 (net.js:1262:14)
      iobroker	2017-11-26 18:30:33.037	error	at exports._exceptionWithHostPort (util.js:1043:20)
      iobroker	2017-11-26 18:30:33.037	error	at Object.exports._errnoException (util.js:1020:11)
      iobroker	2017-11-26 18:30:33.037	error	Error: listen EADDRINUSE 127.0.0.1:9001
      iobroker	2017-11-26 18:30:33.037	error	^
      iobroker	2017-11-26 18:30:33.037	error	events.js:160 throw er; // Unhandled 'error' event
      iobroker	2017-11-26 18:30:18.790	info	add vis-jqui-mfd
      Meine ioBroker läuft auf einem Pi
      Vorhandene Instanzen:
      admin
      cloud
      discovey
      flot
      history
      hm-rega
      hm-rpc
      javascript
      mobile
      rpi2
      socketio
      vis
      web
        Dieser Fehler tritt bestenfalls auf, weil du einen Pi1 nutzst, der einfach zu langsam ist.
        Schlimmstenfalls hast du zwei (oder mehr) Installationen zeitgleich laufen
        Wenn ich die Informationen aus deinem anderen Thread dazu nehme befürchte ich eher letzteres.
          @Homoran:
          Rainer `
          Danke für die Info.
          Ich habe den Pi nochmals neu aufgesetzt und nun das richtige Image benutzt.
          Allerdings scheitert die Installation von zusätzlichen Adaptern noch immer.
          iobroker	2017-11-26 22:39:12.019	info	exit 1
          iobroker	2017-11-26 22:39:11.910	error	at ontimeout (timers.js:365:14)
          iobroker	2017-11-26 22:39:11.910	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2644:27)
          iobroker	2017-11-26 22:39:11.910	error	at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2732:7)
          iobroker	2017-11-26 22:39:11.910	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2725:9
          iobroker	2017-11-26 22:39:11.910	error	at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2627:24)
          iobroker	2017-11-26 22:39:11.910	error	at Server.listen (net.js:1391:5)
          iobroker	2017-11-26 22:39:11.910	error	at listen (net.js:1295:10)
          iobroker	2017-11-26 22:39:11.910	error	at Server._listen2 (net.js:1259:14)
          iobroker	2017-11-26 22:39:11.910	error	at exports._exceptionWithHostPort (util.js:1045:20)
          iobroker	2017-11-26 22:39:11.910	error	at Object.exports._errnoException (util.js:1022:11)
          iobroker	2017-11-26 22:39:11.910	error	Error: listen EADDRINUSE :::9001
          iobroker	2017-11-26 22:39:11.910	error	^
          iobroker	2017-11-26 22:39:11.910	error	events.js:160 throw er; // Unhandled 'error' event
          iobroker	2017-11-26 22:39:00.235	info	add vis-weather
          host.ioBroker-Pi1	2017-11-26 22:37:51.544	info	Delete log file iobroker.2017-03-01.log
          iobroker	2017-11-26 22:37:42.918	info	exit 1
          iobroker	2017-11-26 22:37:42.812	error	at ontimeout (timers.js:365:14)
          iobroker	2017-11-26 22:37:42.812	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2673:26)
          iobroker	2017-11-26 22:37:42.812	error	at new StatesInMemory (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:204:7)
          iobroker	2017-11-26 22:37:42.812	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:197:9
          iobroker	2017-11-26 22:37:42.812	error	at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:1000:20)
          iobroker	2017-11-26 22:37:42.812	error	at Server.listen (net.js:1391:5)
          iobroker	2017-11-26 22:37:42.812	error	at listen (net.js:1295:10)
          iobroker	2017-11-26 22:37:42.812	error	at Server._listen2 (net.js:1259:14)
          iobroker	2017-11-26 22:37:42.812	error	at exports._exceptionWithHostPort (util.js:1045:20)
          iobroker	2017-11-26 22:37:42.812	error	at Object.exports._errnoException (util.js:1022:11)
          iobroker	2017-11-26 22:37:42.812	error	Error: listen EADDRINUSE :::9000
          iobroker	2017-11-26 22:37:42.812	error	^
          iobroker	2017-11-26 22:37:42.812	error	events.js:160 throw er; // Unhandled 'error' event
          iobroker	2017-11-26 22:37:32.551	info	add vis-hqwidgets
          Zur Entlastung des PI habe ich extra gewartet, bis die Initialisierung und Synchronisation des HM-Adapters beendet war und das Logfile sich beruhigte.
          Die installierten Module sind nun auch weniger
          admin
          flot
          history
          hm-rega
          hm-rpc
          javascript
          mobile
          rpi2
          vis
          web
            Die fehler mit dem EADDRINUSE sind typischbfür den pi1
            Workaround
            Installieren übet die konsole. Zuerst
            sudo iobroker stop
            Danach die instanzen anlegen mit
            sudo iobroker add AdapterName
            Wobei AdapterName natürlich ersetzt werden muss durch den Namen des Adapters.
              Danke für den Tip.
              @Homoran:
              Code:
              So hat es bei mir jetzt auch geklappt.
              ` > Wie kann ich für die von dir vorgeschlagene Installationstechnik die Installationsnamen der Adapter herausfinden?
              Ist es typischerweise der erste Eintrag der Schlüsselworte, die ich zum Adapter im Admin sehe? `
              Beim Stöbern habe ich gerade gefunden, dass es unter http://download.iobroker.net/list.html eine Liste der Adapter mit den benötigten Namen zur Installation gibt.
