    4. IoBroker.scenes
    IoBroker.scenes
      Ich habe mir erlaubt was neues zu entwickeln. Hier ist die erste Version von lang versprochenen und gesprochenen Szenen-Adapter.
      https://github.com/ioBroker/ioBroker.scenes
      cd /opt/iobroker
      npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
      iobroker add scenes
      Danach sollte Tab - Szenen in "admin" auftauchen.
      • ruhr70
        ruhr70 last edited by
        Die Installation ging irgendwie schief 😞
        root@iobroker:~# cd /opt/iobroker
        root@iobroker:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
        > iobroker.scenes@0.0.1 install /opt/iobroker/node_modules/iobroker.scenes
        > node main.js --install
        2015-08-04 21:50:26.430  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
        ^Croot@iobroker:/opt/iobroker# 2015-08-04 21:51:43.404  - info: scenes.0 terminating
        nach 1,5 Minuten mit strg + c abgebrochen
        dann, trotzdem mutig:
        root@iobroker:/opt/iobroker# ./iobroker add scenes
        install adapter scenes
        npm install --production --prefix "/opt/iobroker/node_modules/iobroker.scenes" (System call)
        npm WARN cannot run in wd iobroker.scenes@0.0.1 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.scenes)
        got /opt/iobroker/node_modules/iobroker.scenes/admin
        upload [4] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/words.js words.js application/javascript
        upload [3] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.js tab.js application/javascript
        upload [2] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.html tab.html text/html
        upload [1] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/scenes.png scenes.png image/png
        upload [0] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/index.html index.html text/html
        object system.adapter.scenes created
        create instance scenes
        object system.adapter.scenes.0.uptime created
        object system.adapter.scenes.0.memRss created
        object system.adapter.scenes.0.memHeapTotal created
        object system.adapter.scenes.0.memHeapUsed created
        object system.adapter.scenes.0.connected created
        object system.adapter.scenes.0.alive created
        object system.adapter.scenes.0 created
        seitdem komme ich nicht mehr auf ioBroker/admin 😞
        es lädt nur eine weiße Seite, zwischendurch dreht sich mal kurz das Zahnrad.
        ioBroker habe ich mit stop/start einmal neu gestartet
        VIS, VIS Edit, Flot,funktionieren
          Danach taucht gar nichts mehr auf 😢
          bleibt hier irgendwie hängen:
          root@quad-pi:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
          npm http GET https://github.com/ioBroker/ioBroker.scenes/tarball/master
          npm http 200 https://github.com/ioBroker/ioBroker.scenes/tarball/master
          2015-08-04 21:52:09.531  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
          wenn ich vorher iobroker stoppe:
          root@quad-pi:/opt/iobroker# iobroker stop
          Stopping ioBroker controller daemon...
          ioBroker controller daemon stopped.
          2015-08-04 21:50:14.388  - warn: scenes.0 no connection to objects DB
          iobroker.scenes@0.0.1 node_modules/iobroker.scenes
          Da kommt er wenigstens wieder zu sich 😉
          auf den admin komme ich nicht mehr, auch kein drehendes Zahnrad (nur ganz kurz - dann alles weiß)
          Zweimal CTRL-C dann: adapter scenes terminating
          und jetzt kann ich eingeben:
          root@quad-pi:/opt/iobroker# iobroker add scenes
          root@quad-pi:/opt/iobroker# reboot
          Nach dem reboot auch nichts mehr.
          • ruhr70
            Du hast von mir abgeschrieben 😉
            bei mir ist es nur leider das Produktivsystem 😞
              @ruhr70:
              bei mir ist es nur leider das Produktivsystem 😞 `
              Dito!!!
                pix last edited by
                Trau mich jetzt gar nicht, zu testen. Hab nur das Produktivsystem.
                Gesendet von meinem iPhone mit Tapatalk
                • ruhr70
                  root@iobroker:/opt/iobroker# ./iobroker del scenes
                  delete /opt/iobroker/node_modules/iobroker.js-controller/lib/../../iobroker.scenes
                  Counted 1 instances of scenes
                  Counted 6 states (system.adapter.scenes.*) from states
                  Counted 1 adapters for scenes
                  Counted 6 states of scenes
                  Deleting 8 object(s).
                  root@iobroker:/opt/iobroker# ./iobroker stop
                  root@iobroker:/opt/iobroker# ./iobroker start
                  Starting ioBroker controller daemon...
                  ioBroker controller daemon started. PID: 5115
                  hat geholfen…
                  • ruhr70
                    pix, Du hattest doch immer geschrieben… Datensicherung, Datensicherung, ...
                    trau Dich :twisted: 🙂
                    Das mit den Szenen ist schon cool.
                      Da bist du mir schon wieder zuvorgekommen!
                      ich geh jetzt ins Bett, es läuft ja wieder.
                        Installation habe ich jetzt gefixt.
                        Mit neuer Version vom admin sehe ich das Problem nicht mehr:
                        cd /opt/iobroker
                        npm install https://github.com/ioBroker/ioBroker.admin/tarball/master
                        iobroker add scenes
                        • ruhr70
                          Funktioniert! Sieht aus, als ob der Adapter Potential hat!
                          Man kann wunderbar die Szenen definieren, für true und für false. Mit dem aktuellen hue Adapter können auch die hue Lampen ganz gezielt eingestellt werden.
                          Sieht klasse aus!
                          Jetzt geht ich erst einmal schlafen. Morgen teste ich damit. Gefällt mir auf jeden Fall bisher sehr gut 🙂
                            pix last edited by
                            ich habe mich getraut und wurde belohnt.Ich bin begeistert. 😄
                            Ein paar Fragen zum Verständnis:
                            Kann man Gruppen, wie Direktverknüpfungen verstehen?
                            Werden die festgelegten States bei der Realisierung einer Scene im Burstmodus gesetzt (Funkhygiene) oder irgendwie nacheinander?
                            Macht es Sinn zB Abwesenheit als Szene oder als Gruppe zu beschreiben (alle Lichter aus, einzelne [nicht alle] Geräte aus, Anwesenheit=aus, Alarmanlage=aus [Delay 45s])?
                            Auf jeden Fall ein Top-Geschichte, die sehr viel Scripte spart.
                            Kleine Anregeung: Bitte die Spalte "Name" etwas breiter (auf Kosten der flexiblen Spalte Beschreibung).
                            Pix
                              pix last edited by
                              Noch eine Kleinigkeit:
                              Wenn ich Zustände erneut hinzufüge (mit dem + Button), werden die bisher schon hinzugefügten noch einmal zugefügt.
                              Pix
                                pix last edited by
                                Es gibt wohl doch etwas mehr Probleme:
                                2015-08-04 23:13:30.213  - info: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 started with pid 43079
                                2015-08-04 23:13:30.844  - info: scenes.0 starting. Version 0.0.1 in /Users/pix/Desktop/iobroker/node_modules/iobroker.scenes
                                2015-08-04 23:14:46.609  - error: uncaught exception: Cannot call method 'toString' of undefined
                                2015-08-04 23:14:46.613  - error: TypeError: Cannot call method 'toString' of undefined
                                    at checkTrigger (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:187:118)
                                    at Adapter.id (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:32:17)
                                    at Adapter.emit (events.js:98:17)
                                    at null._onTimeout (/Users/pix/Desktop/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1865:34)
                                    at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                                2015-08-04 23:14:46.920  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 terminated with code 6 (uncaught exception)
                                Lasse es erstmal dabei. Morgen gehts weiter 😉
                                  @pix:
                                  Lasse es erstmal dabei. Morgen gehts weiter 😉 `
                                  Danke. Im letzen Moment eingebaute Debug-Outputs haben versagt.
                                  jetzt sollte gehen.
                                  Ja
                                  Das ist die Aufgabe von hm-rpc Adapter. Obwohl falls es wirklich nicht geht, ich kann eine Einstellung einbauen: Intervall zwischen Befehlen.
                                  Alarmanlage=ein ?
                                  Ja, genau das.
                                  Sollte auch gefixt werden.
                                  Nicht vergessen nach update einen Upload aufrufen.
                                  iobroker upload scenes
                                  • ruhr70
                                    Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt.
                                      @ruhr70:
                                      Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt. `
                                      Na ja. Um eine Ebene zu erschaffen, braucht ein Objekt zwei stufen zu haben.
                                      Falls du deine Szenen "common.szene1" und "common.szene2" nennst, dann wird es gruppiert.
                                      Ich kann wirklich machen, dass die Szenen erst mal unter "scene.all" abgelegt werden.
                                      Oder ich werde machen, dass alle Szenen "scenes.scene.xxx" heißen. Bin noch nicht schlüssig.
                                      GEHT das überhaupt?
                                      • ruhr70
                                        Ich dachte an scenes.0
                                        Aber jetzt wo Du das schreibt, ist mir gerade bewusst geworden, dass man die Szenennamen mit bedacht wählen sollte. Wenn man sie fleissig verwendet (Vis, Javascript, suw.) und dann auf die Idee kommt, die Szenen umzubenennen, bzw. die Namen neu zu strukturieren, stimmen alle Datenpunkte nicht mehr (Vis, Javascript, usw).
                                        @Bluefox:
                                        GEHT das überhaupt? `
                                          > GEHT das überhaupt?
                                          Geht iobroker.scenes? Kannst du was schalten damit?
                                          scenes.0 geht nicht, weil man kann mehrere scenes Adapterinstanzen haben (weiß noch nicht wozu :lol: ) und man kann jede Szene zu einer Instanz zuweisen.
                                          Dann kommt so was wie scene.0.blabla wird auf dem Adapter scenes.1 ausgeführt. Verwirrt.
                                          Richtig…
                                          Also "scenes.scene.blabla" ?
                                            Es gibt neue Version. Man muss aber die Szenen neu konfigurieren.
                                            64
                                            14413
