    4. Tinkerboard Fehlerlog rpi2.0 Adapter
    • HAL
      HAL last edited by
      Moin,
      nach einem (selbstgemachten) Stromausfall sehe ich viele Fehler im Log vom rpi2.0 Adapter und eine VIS View zeigt keine aktuellen Werte, obwohl in den Objekten die Werte vorhanden sind. Wenn ich die Objekte neu anlege, sind die Werte wieder da. Hat jemand einen Tipp ?
      VG Uwe
      Auszug:
      	Zeit		Nachricht
      x
      rpi2.0	2017-12-02 11:55:42.871	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817040 12801168 13% / /1024
      rpi2.0	2017-12-02 11:55:42.871	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:55:42.871	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:55:42.870	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:54:41.848	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817040 12801168 13% / /1024
      rpi2.0	2017-12-02 11:54:41.847	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:54:41.847	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:54:41.846	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:53:41.449	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:53:41.448	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:53:41.447	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:53:41.446	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:53:41.442	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:52:40.741	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:52:40.741	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:52:40.741	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:52:40.740	error	No Value found for cpu_voltage
      web.0	2017-12-02 11:52:33.362	info	2017-12-02T10:52:33.333Z Connected system.user.admin
      rpi2.0	2017-12-02 11:51:40.332	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:51:40.332	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:51:40.332	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:51:40.331	error	No Value found for cpu_voltage
      web.0	2017-12-02 11:50:55.130	info	2017-12-02T10:50:55.124Z Connected system.user.admin
      rpi2.0	2017-12-02 11:50:39.798	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:50:39.798	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:50:39.798	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:50:39.798	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:49:39.573	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:49:39.573	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:49:39.573	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:49:39.572	error	No Value found for cpu_voltage
      web.0	2017-12-02 11:49:18.236	info	2017-12-02T10:49:18.231Z Connected system.user.admin
      web.0	2017-12-02 11:49:14.234	info	2017-12-02T10:49:14.190Z Connected system.user.admin
      rpi2.0	2017-12-02 11:48:39.029	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817036 12801172 13% / /1024
      rpi2.0	2017-12-02 11:48:39.028	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:48:39.028	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:48:39.027	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:47:38.747	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p1 14801136 1817032 12801176 13% / /1024
      rpi2.0	2017-12-02 11:47:38.747	error	No Value found for mem_gpu
      rpi2.0	2017-12-02 11:47:38.747	error	No Value found for mem_arm
      rpi2.0	2017-12-02 11:47:38.746	error	No Value found for cpu_voltage
      rpi2.0	2017-12-02 11:46:38.362	error	/1024
      rpi2.0	2017-12-02 11:46:38.362	error	/dev/mmcblk0p1 14801136 1817032 12801176 13% /
      rpi2.0	2017-12-02 11:46:38.362	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
      rpi2.0	2017-12-02 11:46:38.360	error	/10244
        @HAL:
        Hat jemand einen Tipp ? `
        Ja!
        Was hast du nach dem Stromausfall gemacht?
        Hast du ein Image genommen und dazu die Doku gelesen und befolgt?
        @[url=http://www.iobroker.net/docu/?page_id=7604⟨=de#Der_verwendeterpi2-Adapter:
        ~~Doku"]~~Der verwendete rpi2-Adapter
        Bei Armbian ist die Dateistruktur im Vergleich zum Raspbian geändert, der Adapter kann daher einige Werte in der Grundkonfiguration nicht auswerten und es kommt zu Fehlermeldungen. Der in diesem Image enthaltene rpi2-Adapter wurde dementsprechend angepasst. Bei einem Update des Adapters wird diese Änderung wieder überschrieben. Daher bitte die Datei io-package.json aus dem Verzeichnis /opt/iobroker/node-modules/io.rpi2 sichern und falls es nach dem Update Probleme gibt wieder einspielen. (Oder sich im Forum melden). `
        Solltest du eine eigenständige Installation gemacht haben gilt entsprechend:
        Das ist ein Tinkerboard - kein rpi.
        • HAL
          HAL last edited by
          @Homoran:
          @HAL:
          Ja!
          Rainer `
          Hallo Rainer,
          es ist das all-in-one Image und das Tinkerboard hat nach der Stromunterbrechung ganz normal selbständig gebootet. Einen Update des Adapter habe ich nicht gemacht. Ggf werde ich das Image und den Backup heute Nachmittag noch mal neu einspielen.
          VG Uwe
            Hallo Uwe,
            dann muss ich vermuten, dass sich der Adapter selbst neu installiert hat - warum auch immer.
            • HAL
              HAL last edited by
              @Homoran:
              Hallo Uwe,
              Rainer `
              Hallo Rainer,
              gerade aus dem original Image die io-package.json aus dem Verzeichnis /opt/iobroker/node-modules/iobroker.rpi2 ( das Verzeichnis /opt/iobroker/node-modules/io.rpi2 gibt es nicht) in meine Installation kopiert ( war aber sowohl von der Größe, als auch vom Datum / Zeit identisch ) , aber der Fehler ist nach wie vor existent.
              Nur wenn ich den Adapter deaktiviere, habe ich (verständlicherweise ) keinen Fehler mehr im Log. Kannst Du mal in Deine Installation schauen, ob der Fehler dort auch im Log steht ?
              VG Uwe.
                Hallo Uwe,
                bin im Moment dienstlich unterwegs.
                Kann Ende der Woche nachsehen.
                Bin mir aber ziemlich sicher, dass ich diesen Parameter aus dem rpi2 Adapter entfernt habe, da diese Meldung sonst bei allen "nicht-pi" Installationen auftritt.
                • HAL
                  HAL last edited by
                  Hallo Rainer,
                  ich mache mal ein backup und installiere komplett neu. Mal sehen ob ich noch alle Änderungen zusammenbekomme 🙂
                  VG Uwe
                    Hallo Uwe,
                    mein rpi2 auf dem Tinkerboard mach keine Mucken.
                    hier gibt es keine Fehlermeldungen, die Abfrage der boot-partition ist deaktiviert.
