    4. RegEx Probleme
    RegEx Probleme
      Jautze last edited by
      ich bin dran den rpi Adapter umzuschreiben auf mein System (Debian VM) auf Synology Nas.
      "native": {
              "c_cpu": true,
              "c_raspberry": false,
              "c_memory": true,
              "c_network": true,
              "c_sdcard": true,
              "c_swap": true,
              "c_temperature": true,
              "c_uptime": true,
              "c_wlan": true,
              "interval": 60000,
              "cpu": {
                  "cpu_frequency": {
                      "command": "cat /proc/cpuinfo",
                      "regexp": "cpu\\sMHz\\s+:\\s(\\d+).\\d+",
                      "post": "$1"
                  "load1,load5,load15": {
                      "command": "cat /proc/loadavg",
                      "regexp": "^(\\S+)\\s(\\S+)\\s(\\S+)",
                      "post": ""
                  "scaling_governor": {
                      "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor",
                      "regexp": "(.*)",
                      "post": ""
      cat /proc/cpuinfo
      processor       : 0
      vendor_id       : GenuineIntel
      cpu family      : 6
      model           : 92
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      stepping        : 9
      microcode       : 0x1
      cpu MHz         : 1497.610
      cache size      : 1024 KB
      physical id     : 0
      siblings        : 2
      core id         : 0
      cpu cores       : 2
      apicid          : 0
      initial apicid  : 0
      fpu             : yes
      fpu_exception   : yes
      cpuid level     : 13
      wp              : yes
      flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes rdrand hypervisor lahf_lm 3dnowprefetch tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms mpx rdseed smap clflushopt
      bugs            :
      bogomips        : 2995.22
      clflush size    : 64
      cache_alignment : 64
      address sizes   : 40 bits physical, 48 bits virtual
      power management:
      processor       : 1
      cpu family      : 6
      model           : 92
      stepping        : 9
      microcode       : 0x1
      cpu MHz         : 1497.610
      physical id     : 0
      siblings        : 2
      core id         : 1
      cpu cores       : 2
      apicid          : 1
      initial apicid  : 1
      fpu             : yes
      fpu_exception   : yes
      cpuid level     : 13
      wp              : yes
      bugs            :
      bogomips        : 2995.22
      clflush size    : 64
      power management:
      Im Broker kommt:
      rpi2.0 2017-12-15 10:49:48.010 error No Value found for cpu_frequency
      Wer hat eine Ahnung warum das nicht funktioniert?
      Im Regex Tester funtioniert es.
      Viele Grüße
      Marcel Jaud
        Ich habe mal den Code in Code-Tags gesetzt.
        Was bitte machst du da?
        und wie genau gehst du vor?
          Also oben der Code ist vom rpi2 json File.
          "cpu_frequency": {
          "regexp": "cpu\sMHz\s+:\s(\d+).\d+",
          "post": "$1"
          Da versuche ich die CPU Frequenz aus der cpuinfo auszulesen und per Regex zu bekommen.
          Aber ich bekomme ein Fehler in iobroker.
          Danke und viele Grüße
          Marcel Jaud
          • frankjoke
            frankjoke last edited by
            Bei mir funktioniert die Abfrage mit dem RegExp (Debian 9, CSI nuk)
            Übrigens, ich habe den rpi-Adapter durch den Systeminfo-Adapter ersetzt, da kannst alles - und mehr abfragen!
