    4. Panasonic viera adapter - fehler + fix
      Highpressure last edited by
      Habe gerade den genannten adapter installiert
      hängt sich nach jedem befehl auf.
      ursache ist seine /lib/viera.js
      Zeile 93 folgenden Befehl auskommentieren:
      // callback(null, result);
      laut log passiert sonst jedes mal:
      host.ioBroker-Pi 2018-01-04 22:04:42.759 info Restart adapter system.adapter.panasonic-viera.0 because enabled
      host.ioBroker-Pi 2018-01-04 22:04:42.759 error instance system.adapter.panasonic-viera.0 terminated with code 0 (OK)
      Caught 2018-01-04 22:04:42.759 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught 2018-01-04 22:04:42.758 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
      Caught 2018-01-04 22:04:42.758 error by controller[0]: at endReadableNT (_stream_readable.js:974:12)
      Caught 2018-01-04 22:04:42.757 error by controller[0]: at IncomingMessage.emit (events.js:185:7)
      Caught 2018-01-04 22:04:42.751 error by controller[0]: at emitNone (events.js:91:20)
      Caught 2018-01-04 22:04:42.732 error by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.panasonic-viera/lib/viera.js:93:17)
      Caught 2018-01-04 22:04:42.731 error by controller[0]: TypeError: callback is not a function
      panasonic-viera.0 2018-01-04 22:04:42.714 info terminating
      panasonic-viera.0 2018-01-04 22:04:42.207 error at process._tickCallback (internal/process/next_tick.js:104:9)
      panasonic-viera.0 2018-01-04 22:04:42.207 error at _combinedTickCallback (internal/process/next_tick.js:80:11)
      panasonic-viera.0 2018-01-04 22:04:42.207 error at endReadableNT (_stream_readable.js:974:12)
      panasonic-viera.0 2018-01-04 22:04:42.207 error at IncomingMessage.emit (events.js:185:7)
      panasonic-viera.0 2018-01-04 22:04:42.207 error at emitNone (events.js:91:20)
      panasonic-viera.0 2018-01-04 22:04:42.207 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.panasonic-viera/lib/viera.js:93:17)
      panasonic-viera.0 2018-01-04 22:04:42.207 error TypeError: callback is not a function
      panasonic-viera.0 2018-01-04 22:04:42.205 error uncaught exception: callback is not a function
      panasonic-viera.0 2018-01-04 22:02:44.327 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v6.12.3
      panasonic-viera.0 2018-01-04 22:02:44.252 info States connected to redis: 127.0.0.1:6379
      host.ioBroker-Pi 2018-01-04 22:02:42.644 info instance system.adapter.panasonic-viera.0 started with pid 2922
      hab nicht geprüft ob´s den auf github gibt um einen report zu machen.
        gleich noch eins - power muss state sein, sonst muss man immer "Ein" sagen… auch für ausschalten lol..
        war unter objekt zu ändern
        • Matzebhv
          Matzebhv last edited by
          Auch wenn ich die von Dir genannten Probleme mit dem Adapter nicht habe:
          https://github.com/ldittmar81/ioBroker. … /README.md
          Matze
            danke 🙂
            hab den gestern bei einem freund eingerichtet
            raspberry pi image von iobroker geladen
            apt upgrade und update gemacht
            und losgelegt
            81.0k
