    4. Send this to developer
      Kamikaze last edited by
      ich habe einen neuen Homematic IP Präsenzmelder in Berteib genommen und erhalte die Meldung:
      2017-12-22 12:34:22.463  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SPI.MAINTENANCE.1"
      2017-12-22 12:34:22.464  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"SABOTAGE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"SABOTAGE","TYPE":"BOOL","DEFAULT":false},"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"ERROR_CODE":{"MIN":0,"OPERATIONS":5,"MAX":255,"FLAGS":9,"ID":"ERROR_CODE","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
      2017-12-22 12:34:22.519  - info: hm-rpc.2 xmlrpc -> getParamsetDescription ["000C170999F7F3:1","VALUES"]
      2017-12-22 12:34:22.641  - warn: hm-rpc.2 Send this info to developer: _id: "hm-rpc.meta.VALUES.HmIP-SPI.PRESENCEDETECTOR_TRANSCEIVER.1"
      2017-12-22 12:34:22.641  - warn: hm-rpc.2 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESENCE_DETECTION_STATE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"PRESENCE_DETECTION_STATE","TYPE":"BOOL","DEFAULT":false,"CONTROL":"PRESENCEDETECTOR_TRANSCEIVER.PRESENCE_DETECTION_STATE"},"ILLUMINATION":{"MIN":0,"OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"ILLUMINATION","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"PRESENCEDETECTOR_TRANSCEIVER.ILLUMINATION"},"RESET_PRESENCE":{"MIN":false,"OPERATIONS":2,"MAX":true,"FLAGS":1,"ID":"RESET_PRESENCE","TYPE":"ACTION","DEFAULT":false,"CONTROL":"PRESENCEDETECTOR_TRANSCEIVER.RESET_PRESENCE"},"CURRENT_ILLUMINATION":{"MIN":0,"OPERATIONS":5,"MAX":163830,"FLAGS":1,"ID":"CURRENT_ILLUMINATION","TYPE":"FLOAT","DEFAULT":0},"PRESENCE_DETECTION_ACTIVE":{"MIN":false,"OPERATIONS":7,"MAX":true,"FLAGS":1,"ID":"PRESENCE_DETECTION_ACTIVE","TYPE":"BOOL","DEFAULT":true,"CONTROL":"PRESENCEDETECTOR_TRANSCEIVER.PRESENCE_DETECTION_ACTIVE"}}}
