    4. Pi3 Stretch, ioBroker macht keinen Autostart
    • 0
      0018 last edited by
      ich setze gerade meinem Pi3 mit Stretch neu auf und habe Probleme mit dem Autostart.
      Habe die Installation nach Anweisung http://www.iobroker.net/docu/?page_id=5106&lang=degemacht.
      Bekomme bei "sudo systemctl status iobroker" folgendes:
      ● iobroker.service - LSB: starts ioBroker
         Loaded: loaded (/etc/init.d/iobroker.sh; generated; vendor preset: enabled)
         Active: failed (Result: exit-code) since Tue 2017-12-26 14:06:05 CET; 9min ago
           Docs: man:systemd-sysv-generator(8)
        Process: 429 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=203/EXEC)
      Dez 26 14:06:05 BrokerPi systemd[1]: Starting LSB: starts ioBroker...
      Dez 26 14:06:05 BrokerPi systemd[1]: iobroker.service: Control process exited, code=exited status=203
      Dez 26 14:06:05 BrokerPi systemd[1]: Failed to start LSB: starts ioBroker.
      Dez 26 14:06:05 BrokerPi systemd[1]: iobroker.service: Unit entered failed state.
      Dez 26 14:06:05 BrokerPi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Habe schon gesucht und auch schon in der "/etc/init.d/iobroker.sh" geschaut aber klappt trotzdem nicht.
      Die iobroker.sh sieht so aus:
      #!/bin/bash
      BEGIN INIT INFO
      Provides: iobroker.sh
      Required-Start: $network $local_fs $remote_fs
      Required-Stop:: $network $local_fs $remote_fs
      Default-Start: 2 3 4 5
      Default-Stop: 0 1 6
      Short-Description: starts ioBroker
      END INIT INFO
      (( EUID )) && echo .You need to have root privileges.. && exit 1
      PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
      #NODECMD=@@node
      NODECMD=/usr/bin/node
      IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      RETVAL=0
      IOBROKERUSER=root
      ! start() {
      export IOBROKER_HOME=/opt/iobroker
      echo -n "Starting ioBroker"
      sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
      RETVAL=$?
      ! stop() {
      echo -n "Stopping ioBroker"
      sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
      RETVAL=$?
      case "$1" in
      start)
      start
      stop)
      stop
      restart)
      stop
      start
      echo "Usage: iobroker {start|stop|restart}"
      exit 1
      esac
      exit $RETVAL
      Meine Versionen:
      pi@BrokerPi:/ $ node -v
      v6.12.2
      pi@BrokerPi:/ $ nodejs -v
      v6.12.2
      pi@BrokerPi:/ $ npm -v
      3.10.10
      Kann mir jemand weiterhelfen?
      Danke 🙂
      • 0
        0018 last edited by
        Endlich…. Fehler gefunden.
        Irgendwie hat sich ein Fehler in der /etc/init.d/iobroker.sh eingeschlichen.
        Habe mal versucht die Datei iobroker.sh direkt auszuführen und bekam die Fehlermeldung:
        pi@BrokerPi:/etc/init.d $ ./iobroker.sh
        -bash: ./iobroker.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
        Konnte aber keine Auffälligkeiten am Interpreter feststellen, eingetragen war "#!/bin/bash"
        Habe den Dateiinhalt gespeichert, Datei gelöscht und dann neu angelegt.
        Siehe da…. jetzt läuft es.
          @0018:
          eingetragen war "#!/bin/bash" `
          Aber mit einem windows Editor geschrieben!
          Gruß Rainer
          • 0
            0018 last edited by
            @Homoran:
            Aber mit einem windows Editor geschrieben! `
            Ja, von dem Problem habe ich gehört…. aber es war eine frische Installation nach Anleitung und ich war mit dem Editor nicht an der Datei, zumal ich wenn dann immer über Putty und nano editiere.
            Naja wie dem auch sei.... es läuft wieder 8-)
            • 0
              0018 last edited by
              So ich habe das ganze nochmal ein zweites mal probiert und das System ein zweites mal komplett neu installiert.
              Siehe da - es ist wieder so das die iobroker.sh in der /etc/init.d nicht startet.
              Habe zudem festgestellt das die iobroker.sh nicht ausführbar ist.
              Kann das jemand mal gegenprüfen?
                C-3po last edited by
                Hi Leuts,
                hier genau das selbe.
                root@io-broker-pi:~# systemctl status iobroker
                Active: failed (Result: exit-code) since Sat 2017-12-30 14:04:42 CET; 16s ago
                Process: 670 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=1/FAILURE)
                Dez 30 14:04:42 io-broker-pi systemd[1]: Starting LSB: starts ioBroker…
                Dez 30 14:04:42 io-broker-pi sudo[692]: root : unknown user: @@user
                Dez 30 14:04:42 io-broker-pi iobroker.sh[670]: Starting ioBrokersudo: Unbekannter Benutzer: @@user
                Dez 30 14:04:42 io-broker-pi iobroker.sh[670]: sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                Dez 30 14:04:42 io-broker-pi systemd[1]: iobroker.service: Control process exited, code=exited status=1
                Dez 30 14:04:42 io-broker-pi systemd[1]: Failed to start LSB: starts ioBroker.
                Dez 30 14:04:42 io-broker-pi systemd[1]: iobroker.service: Unit entered failed state.
                Dez 30 14:04:42 io-broker-pi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                ioBroker startet nicht, erst:
                root@io-broker-pi:~# iobroker start
                Starting iobroker controller daemon…
                iobroker controller daemon started. PID: 18638
                startet ihn.
                  So, jetzt geht es bei mir.
                  wie weiter oben schon genannt:
                  Problem beseitigt
                  und die Rechte angepasst.
                  danach noch diese Änderung durchgef.
                  END INIT INFO
                  NODECMD=@@node
                  RETVAL=0
                  IOBROKERUSER=@@user
                  IOBROKERUSER=root
                  start() {
                  jetzt startet ioBroker sauber nach einem Reboot durch.
                  siehe:
                  Active: active (running) since Sat 2017-12-30 14:20:43 CET; 13s ago
                  Process: 597 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=0/SUCCESS)
                  CGroup: /system.slice/iobroker.service
                  ├─ 932 iobroker.js-controller
                  ├─1254 io.admin.0
                  ├─1953 io.discovery.0
                  ├─2489 io.tr-064.4
                  └─3113 /usr/bin/node /opt/iobroker/node_modules/iobroker.web/main.js 0 info
                  Dez 30 14:20:37 io-broker-pi systemd[1]: Starting LSB: starts ioBroker…
                  Dez 30 14:20:38 io-broker-pi sudo[606]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start
                  Dez 30 14:20:38 io-broker-pi sudo[606]: pam_unix(sudo:session): session opened for user root by (uid=0)
                  Dez 30 14:20:40 io-broker-pi iobroker.sh[597]: Starting ioBrokerStarting iobroker controller daemon…
                  Dez 30 14:20:43 io-broker-pi iobroker.sh[597]: iobroker controller daemon started. PID: 932
                  Dez 30 14:20:43 io-broker-pi sudo[606]: pam_unix(sudo:session): session closed for user root
                  Dez 30 14:20:43 io-broker-pi systemd[1]: Started LSB: starts ioBroker.
                    B3ta last edited by
                    Könnte wer nochmal schritt weise erklären ? wie er es behoben habt. Habe auch kein autostart mehr und verstehe nicht ganz was ihr gemacht habt.
                      Bitte auf jeden Fall bei allen Änderungen an Dateien keinen Windows-Editor benutzen.
                      Unter Windows sollte das Notepad++ verwendet werden, und der Zeilenumbruch auf UNIX gestellt sein.
                      Die Zeile:
                      @C-3po:
                      -bash: ./iobroker.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden `
                      deutet darauf hin, dass diese Datei bereits mit einem Windows-Editor bearbeitet wurde.
                      In der Installationsdatei ist der Windowsumbruch nicht drin!
                      Wo kommt der her?
                        B3ta last edited by
                        bei mir kommt immer
                        pi@raspberrypi:~ $ /etc/init.d $ ./iobroker.sh
                        -bash: /etc/init.d: Ist ein Verzeichnis
                          B3ta last edited by
                          sorry war falsch in der zwischenablage
                          pi@raspberrypi:/etc/init.d $ ./iobroker.sh
                          pi@raspberrypi:/etc/init.d $ systemctl status iobroker
                             Loaded: loaded (/etc/init.d/iobroker.sh)
                             Active: failed (Result: exit-code) since Sa 2017-12-30 17:17:23 CET; 7min ago
                            Process: 509 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=203/EXEC)
                            paul53 last edited by
                            @B3ta:
                            Da hat sich ein CR eingeschlichen. Wurde die Datei mal aktualisiert / modiziert ? Prüfe bitte Länge und Datum:
                            ls -l /etc/init.d/iobroker.sh
                              B3ta last edited by
                              habe die iobroker.sh nochmal neu erzeugen lassen grade. aber halt selbe fehler.
                              root@raspberrypi:/etc/init.d# ls -l /etc/init.d/iobroker.sh
                              -rwxrwxrwx 1 root root 1145 Dez 30 18:06 /etc/init.d/iobroker.sh
                                @B3ta:
                                habe die iobroker.sh nochmal neu erzeugen lassen grade. `
                                Wie ?
                                Die Datei ist 47 Byte zu groß.
                                  B3ta last edited by
                                  #!/bin/bash
                                  ### BEGIN INIT INFO
                                  # Provides:          iobroker.sh
                                  # Required-Start:    $network $local_fs $remote_fs
                                  # Required-Stop::    $network $local_fs $remote_fs
                                  # Default-Start:     2 3 4 5
                                  # Default-Stop:      0 1 6
                                  # Short-Description: starts ioBroker
                                  # Description:       starts ioBroker
                                  ### END INIT INFO
                                  NODECMD=@@node
                                  RETVAL=0
                                  IOBROKERUSER=@@user
                                  start() {
                                              RETVAL=$?
                                  stop() {
                                              RETVAL=$?
                                  case "$1" in
                                      start)
                                        start
                                      stop)
                                        stop
                                      restart)
                                        stop
                                        start
                                        exit 1
                                  esac
                                  exit $RETVAL
                                  das ist der inhalt…
                                    @B3ta:
                                    das ist der inhalt… `
                                    …und der enthält 47 Zeilen. Mit welchem Editor wird der Inhalt angezeigt und abgespeichert ?
                                      B3ta last edited by
                                      Nodepad++
                                      aber wie gesagt die habe ich jetzt schon 2mal frisch erzeugen lassen ohne sie überhaupt zu öffnen.
                                        bei mir unter armbian(!) ist die Ausgabe:
                                        root@linaro-alip:~# ls -l /etc/init.d/iobroker.sh
                                        -rwxr-xr-x 1 root root 1098 Nov 21 21:36 /etc/init.d/iobroker.sh
                                          und wenn ich richtig liege (was hier auf keinen Fall stimmen muss!!!) ist es diese Datei:
                                          https://github.com/ioBroker/ioBroker/bl … obroker.sh
                                          von März 2016 und seitdem nicht geändert worden.
                                          Kann es sein, dass Raspbian 2017-11-29 da Mist baut?
                                            Dann konvertiere die Datei vom DOS- in das Linux-Format:
                                            mv /etc/init.d/iobroker.sh /etc/init.d/iobroker.dos
                                            tr -d '\r' < /etc/init.d/iobroker.dos > /etc/init.d/iobroker.sh
                                            oder
                                            cd /etc/init.d
                                            mv iobroker.sh iobroker.dos
                                            tr -d '\r' < iobroker.dos > iobroker.sh
                                            ls -l iob*
                                            5017
