    4. Error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects
      LHBL2003 last edited by
      ich habe seit einiger Zeit das Problem, das mein ioBroker abstürzt.
      Keine Kommunikation von meiner Heizung nach FHEM, ebenso ist der Aufruf der Admin Seite nicht möglich.
      Ein Neustart des Raspbarry PI hilft zwar, ist aber keine Dauerlösung.
      Begonnen habe ich mit der Prüfung:
      ps -A | grep iobroker
      Keine Reaktion
      Ein Start bringt folgendes:
      pi@raspberrypi:/opt/iobroker $ iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
      Error: Failed to write pidfile (EACCES)
      Der manuelle Neustart bringt folgendes:
      pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
      2017-12-26 18:24:24.430  - info: host.raspberrypi iobroker.js-controller version 0.15.3 js-controller starting
      2017-12-26 18:24:24.440  - info: host.raspberrypi Copyright (c) 2014-2016 bluefox, hobbyquaker
      2017-12-26 18:24:24.443  - info: host.raspberrypi hostname: raspberrypi, node: v4.2.1
      2017-12-26 18:24:24.445  - info: host.raspberrypi ip addresses: XYZ
      2017-12-26 18:24:24.709  - info: inMem-states listening on port 9000
      2017-12-26 18:24:25.207  - info: inMem-objects listening on port 9001
      2017-12-26 18:24:25.216  - info: host.raspberrypi InMemoryDB connected
      2017-12-26 18:24:25.268  - info: host.raspberrypi 4 instances found
      host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.fhem.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.wolf.0" for host "raspberrypi"
      2017-12-26 18:24:25.277  - info: host.raspberrypi starting 4 instances
      2017-12-26 18:24:25.355  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2247
      2017-12-26 18:24:29.294  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 2256
      2017-12-26 18:24:31.055  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:24:33.296  - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 2265
      2017-12-26 18:24:33.474  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2017-12-26 18:24:37.302  - info: host.raspberrypi instance system.adapter.wolf.0 started with pid 2279
      2017-12-26 18:24:37.908  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:24:43.359  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:24:48.492  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:24:53.801  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:24:59.273  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      2017-12-26 18:25:04.424  - error: Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
      Der ioBroker läuft dann wieder aber die Meldung stört mich beim Start schon einmal (ist dies Normal?):
      Danke für die Rückmeldung.
      Frage 2: Gibt es außer auf der Admin Seite im Register Log noch wo anders Logs? Denn entweder wird mein Absturz von ioBroker nicht dokumentiert oder es steht in einem anderen log oder es wird abgelöscht nach Neustart.
        Ich noch mal, das log habe ich natürlich Falsch herum gelesen.
        Ein wenig steht doch vorm Absturz drinnen, aber bisher habe ich noch keine Begründung warum er gestoppt wird.
        host.raspberrypi	2017-12-26 06:50:08.123	info	terminated
        host.raspberrypi	2017-12-26 06:50:08.026	info	All instances are stopped.
        host.raspberrypi	2017-12-26 06:50:08.025	info	instance system.adapter.node-red.0 terminated with code 0 (OK)
        host.raspberrypi	2017-12-26 06:50:08.012	info	instance system.adapter.admin.0 terminated with code null ()
        host.raspberrypi	2017-12-26 06:50:08.012	warn	instance system.adapter.admin.0 terminated due to SIGTERM
        host.raspberrypi	2017-12-26 06:50:07.996	info	instance system.adapter.wolf.0 terminated with code null ()
        host.raspberrypi	2017-12-26 06:50:07.996	warn	instance system.adapter.wolf.0 terminated due to SIGTERM
        host.raspberrypi	2017-12-26 06:50:07.981	info	instance system.adapter.fhem.0 terminated with code null ()
        host.raspberrypi	2017-12-26 06:50:07.980	warn	instance system.adapter.fhem.0 terminated due to SIGTERM
        host.raspberrypi	2017-12-26 06:50:07.919	info	stopInstance system.adapter.wolf.0 killing pid 11747
        host.raspberrypi	2017-12-26 06:50:07.918	info	stopInstance system.adapter.wolf.0
        host.raspberrypi	2017-12-26 06:50:07.915	info	stopInstance system.adapter.node-red.0
        host.raspberrypi	2017-12-26 06:50:07.914	info	stopInstance system.adapter.fhem.0 killing pid 11729
        host.raspberrypi	2017-12-26 06:50:07.913	info	stopInstance system.adapter.fhem.0
        host.raspberrypi	2017-12-26 06:50:07.911	info	stopInstance system.adapter.admin.0 killing pid 11735
        host.raspberrypi	2017-12-26 06:50:07.910	info	stopInstance system.adapter.admin.0
        host.raspberrypi	2017-12-26 06:50:07.898	info	received SIGTERM
        fhem.0	2017-12-26 06:49:36.109	info	fhem.0.d_Wolf_HG1.6_Ruecklauftemperatur.47.6 ==> writeFHEM: set d_Wolf_HG1 6_Ruecklauftemperatur 47.6
        fhem.0	2017-12-26 06:49:34.205	info	fhem.0.d_Wolf_HG1.3_Modulationsgrad_Brennerleistung.25 ==> writeFHEM: set d_Wolf_HG1 3_Modulationsgrad_Brennerleistung 25
        fhem.0	2017-12-26 06:47:54.021	info	fhem.0.d_Wolf_MM1.116_Vorlauftemperatur_Mischerkreis.36.5 ==> writeFHEM: set d_Wolf_MM1 116_Vorlauftemperatur_Mischerkreis 36.5
        fhem.0	2017-12-26 06:46:43.845	info	fhem.0.d_Wolf_HG1.3_Modulationsgrad_Brennerleistung.24 ==> writeFHEM: set d_Wolf_HG1 3_Modulationsgrad_Brennerleistung 24
        fhem.0	2017-12-26 06:46:00.591	info	fhem.0.d_Wolf_HG1.7_Warmwassertemperatur.46.68 ==> writeFHEM: set d_Wolf_HG1 7_Warmwassertemperatur 46.68
        fhem.0	2017-12-26 06:45:08.405	info	fhem.0.d_Wolf_HG1.6_Ruecklauftemperatur.47.08 ==> writeFHEM: set d_Wolf_HG1 6_Ruecklauftemperatur 47.08
        fhem.0	2017-12-26 06:45:07.944	info	fhem.0.d_Wolf_HG1.3_Modulationsgrad_Brennerleistung.25 ==> writeFHEM: set d_Wolf_HG1 3_Modulationsgrad_Brennerleistung 25
        fhem.0	2017-12-26 06:44:17.244	info	fhem.0.d_Wolf_HG1.3_Modulationsgrad_Brennerleistung.24 ==> writeFHEM: set d_Wolf_HG1 3_Modulationsgrad_Brennerleistung 24
        fhem.0	2017-12-26 06:43:37.320	info	fhem.0.d_Wolf_MM1.116_Vorlauftemperatur_Mischerkreis.37.3 ==> writeFHEM: set d_Wolf_MM1 116_Vorlauftemperatur_Mischerkreis 37.3
        fhem.0	2017-12-26 06:43:31.853	info	fhem.0.d_Wolf_HG1.4_Kesseltemperatur.53.6 ==> writeFHEM: set d_Wolf_HG1 4_Kesseltemperatur 53.6
        fhem.0	2017-12-26 06:43:31.694	info	fhem.0.d_Wolf_HG1.3_Modulationsgrad_Brennerleistung.25 ==> writeFHEM: set d_Wolf_HG1 3_Modulationsgrad_Brennerleistung 25
        fhem.0	2017-12-26 06:41:47.187	info	fhem.0.d_Wolf_SM1.147_Aktuelle_Leistung.3276.8 ==> writeFHEM: set d_Wolf_SM1 147_Aktuelle_Leistung 3276.8
        fhem.0	2017-12-26 06:41:46.999	info	fhem.0.d_Wolf_SM1.146_Durchfluss.0 ==> writeFHEM: set d_Wolf_SM1 146_Durchfluss 0
        fhem.0	2017-12-26 06:41:46.821	info	fhem.0.d_Wolf_SM1.145_Status_Ausgang_A4.false ==> writeFHEM: set d_Wolf_SM1 145_Status_Ausgang_A4 false
        fhem.0	2017-12-26 06:41:46.637	info	fhem.0.d_Wolf_SM1.144_Status_Ausgang_A3.false ==> writeFHEM: set d_Wolf_SM1 144_Status_Ausgang_A3 false
        fhem.0	2017-12-26 06:41:46.443	info	fhem.0.d_Wolf_SM1.143_Status_Ausgang_A2.false ==> writeFHEM: set d_Wolf_SM1 143_Status_Ausgang_A2 false
        fhem.0	2017-12-26 06:41:46.270	info	fhem.0.d_Wolf_SM1.142_Status_Ausgang_A1.false ==> writeFHEM: set d_Wolf_SM1 142_Status_Ausgang_A1 false
        fhem.0	2017-12-26 06:41:46.085	info	fhem.0.d_Wolf_SM1.141_Status_Solarkreispumpe_SKP1.false ==> writeFHEM: set d_Wolf_SM1 141_Status_Solarkreispumpe_SKP1 false
        fhem.0	2017-12-26 06:41:45.898	info	fhem.0.d_Wolf_SM1.140_Eingang_E3.0 ==> writeFHEM: set d_Wolf_SM1 140_Eingang_E3 0
        fhem.0	2017-12-26 06:41:45.715	info	fhem.0.d_Wolf_SM1.139_Eingang_E2_Durchfluss.0 ==> writeFHEM: set d_Wolf_SM1 139_Eingang_E2_Durchfluss 0
        fhem.0	2017-12-26 06:41:45.538	info	fhem.0.d_Wolf_SM1.138_Eingang_E1.-40 ==> writeFHEM: set d_Wolf_SM1 138_Eingang_E1 -40
        fhem.0	2017-12-26 06:41:45.355	info	fhem.0.d_Wolf_SM1.137_Temperatur_Kollektor_1.3.9 ==> writeFHEM: set d_Wolf_SM1 137_Temperatur_Kollektor_1 3.9
        fhem.0	2017-12-26 06:41:45.172	info	fhem.0.d_Wolf_SM1.136_Warmwassertemperatur_Solar_1.42.8 ==> writeFHEM: set d_Wolf_SM1 136_Warmwassertemperatur_Solar_1 42.8
        fhem.0	2017-12-26 06:41:45.006	info	fhem.0.d_Wolf_SM1.135_Stoerung.false ==> writeFHEM: set d_Wolf_SM1 135_Stoerung false
        fhem.0	2017-12-26 06:41:43.964	info	fhem.0.d_Wolf_MM1.120_Eingang_E2.-40 ==> writeFHEM: set d_Wolf_MM1 120_Eingang_E2 -40
        fhem.0	2017-12-26 06:41:43.803	info	fhem.0.d_Wolf_MM1.119_Eingang_E1.-40 ==> writeFHEM: set d_Wolf_MM1 119_Eingang_E1 -40
        fhem.0	2017-12-26 06:41:43.649	info	fhem.0.d_Wolf_MM1.118_Status_Ausgang_A1.false ==> writeFHEM: set d_Wolf_MM1 118_Status_Ausgang_A1 false
        fhem.0	2017-12-26 06:41:43.479	info	fhem.0.d_Wolf_MM1.117_Status_Mischerkreispumpe.true ==> writeFHEM: set d_Wolf_MM1 117_Status_Mischerkreispumpe true
        fhem.0	2017-12-26 06:41:43.319	info	fhem.0.d_Wolf_MM1.116_Vorlauftemperatur_Mischerkreis.37.9 ==> writeFHEM: set d_Wolf_MM1 116_Vorlauftemperatur_Mischerkreis 37.9
        fhem.0	2017-12-26 06:41:43.150	info	fhem.0.d_Wolf_MM1.115_Warmwassertemperatur.-40 ==> writeFHEM: set d_Wolf_MM1 115_Warmwassertemperatur -40
        fhem.0	2017-12-26 06:41:42.992	info	fhem.0.d_Wolf_MM1.114_Stoerung.false ==> writeFHEM: set d_Wolf_MM1 114_Stoerung false
        fhem.0	2017-12-26 06:41:42.822	info	fhem.0.d_Wolf_BM2.79_Sparfaktor.4 ==> writeFHEM: set d_Wolf_BM2 79_Sparfaktor 4
        fhem.0	2017-12-26 06:41:42.670	info	fhem.0.d_Wolf_BM2.78_Sollwertkorrektur.-4 ==> writeFHEM: set d_Wolf_BM2 78_Sollwertkorrektur -4
        fhem.0	2017-12-26 06:41:42.610	info	fhem.0.d_Wolf_BM2.77_Warmwasser_Zeitprogramm_3.false ==> writeFHEM: set d_Wolf_BM2 77_Warmwasser_Zeitprogramm_3 false
        fhem.0	2017-12-26 06:41:42.567	info	fhem.0.d_Wolf_BM2.77_Warmwasser_Zeitprogramm_3.false ==> writeFHEM: set d_Wolf_BM2 77_Warmwasser_Zeitprogramm_3 false
        fhem.0	2017-12-26 06:41:42.554	info	fhem.0.d_Wolf_BM2.76_Warmwasser_Zeitprogramm_2.false ==> writeFHEM: set d_Wolf_BM2 76_Warmwasser_Zeitprogramm_2 false
        fhem.0	2017-12-26 06:41:42.539	info	fhem.0.d_Wolf_BM2.75_Warmwasser_Zeitprogramm_1.true ==> writeFHEM: set d_Wolf_BM2 75_Warmwasser_Zeitprogramm_1 true
        fhem.0	2017-12-26 06:41:42.412	info	fhem.0.d_Wolf_BM2.72_Mischer_Zeitprogramm_1.true ==> writeFHEM: set d_Wolf_BM2 72_Mischer_Zeitprogramm_1 true
        fhem.0	2017-12-26 06:41:42.390	info	fhem.0.d_Wolf_BM2.74_Mischer_Zeitprogramm_3.false ==> writeFHEM: set d_Wolf_BM2 74_Mischer_Zeitprogramm_3 false
        fhem.0	2017-12-26 06:41:42.369	info	fhem.0.d_Wolf_BM2.73_Mischer_Zeitprogramm_2.false ==> writeFHEM: set d_Wolf_BM2 73_Mischer_Zeitprogramm_2 false
        fhem.0	2017-12-26 06:41:42.207	info	fhem.0.d_Wolf_BM2.71_Programmwahl_Warmwasser.Automatikbetrieb ==> writeFHEM: set d_Wolf_BM2 71_Programmwahl_Warmwasser Automatikbetrieb
        fhem.0	2017-12-26 06:41:41.128	info	fhem.0.d_Wolf_BM2.70_Programmwahl_Mischer.Automatikbetrieb ==> writeFHEM: set d_Wolf_BM2 70_Programmwahl_Mischer Automatikbetrieb
        fhem.0	2017-12-26 06:41:40.968	info	fhem.0.d_Wolf_BM2.69_Warmwassersolltemperatur.60 ==> writeFHEM: set d_Wolf_BM2 69_Warmwassersolltemperatur 60
        fhem.0	2017-12-26 06:41:40.678	info	fhem.0.d_Wolf_BM2.68_Raumtemperatur.0 ==> writeFHEM: set d_Wolf_BM2 68_Raumtemperatur 0
        fhem.0	2017-12-26 06:41:40.520	info	fhem.0.d_Wolf_BM2.67_Stoerung.false ==> writeFHEM: set d_Wolf_BM2 67_Stoerung false
        fhem.0	2017-12-26 06:41:39.460	info	fhem.0.d_Wolf_BM1.66_Sparfaktor.4 ==> writeFHEM: set d_Wolf_BM1 66_Sparfaktor 4
        fhem.0	2017-12-26 06:41:39.309	info	fhem.0.d_Wolf_BM1.65_Sollwertkorrektur.-4 ==> writeFHEM: set d_Wolf_BM1 65_Sollwertkorrektur -4
        fhem.0	2017-12-26 06:41:39.252	info	fhem.0.d_Wolf_BM1.64_Warmwasser_Zeitprogramm_3.true ==> writeFHEM: set d_Wolf_BM1 64_Warmwasser_Zeitprogramm_3 true
        fhem.0	2017-12-26 06:41:39.188	info	fhem.0.d_Wolf_BM1.64_Warmwasser_Zeitprogramm_3.true ==> writeFHEM: set d_Wolf_BM1 64_Warmwasser_Zeitprogramm_3 true
        fhem.0	2017-12-26 06:41:39.178	info	fhem.0.d_Wolf_BM1.63_Warmwasser_Zeitprogramm_2.false ==> writeFHEM: set d_Wolf_BM1 63_Warmwasser_Zeitprogramm_2 false
        fhem.0	2017-12-26 06:41:39.165	info	fhem.0.d_Wolf_BM1.62_Warmwasser_Zeitprogramm_1.false ==> writeFHEM: set d_Wolf_BM1 62_Warmwasser_Zeitprogramm_1 false
        fhem.0	2017-12-26 06:41:39.041	info	fhem.0.d_Wolf_BM1.59_Heizkreis_Zeitprogramm_1.true ==> writeFHEM: set d_Wolf_BM1 59_Heizkreis_Zeitprogramm_1 true
        fhem.0	2017-12-26 06:41:38.985	info	fhem.0.d_Wolf_BM1.59_Heizkreis_Zeitprogramm_1.true ==> writeFHEM: set d_Wolf_BM1 59_Heizkreis_Zeitprogramm_1 true
        fhem.0	2017-12-26 06:41:38.972	info	fhem.0.d_Wolf_BM1.61_Heizkreis_Zeitprogramm_3.false ==> writeFHEM: set d_Wolf_BM1 61_Heizkreis_Zeitprogramm_3 false
        fhem.0	2017-12-26 06:41:38.958	info	fhem.0.d_Wolf_BM1.60_Heizkreis_Zeitprogramm_2.false ==> writeFHEM: set d_Wolf_BM1 60_Heizkreis_Zeitprogramm_2 false
        fhem.0	2017-12-26 06:41:38.831	info	fhem.0.d_Wolf_BM1.58_Programmwahl_Warmwasser.Automatikbetrieb ==> writeFHEM: set d_Wolf_BM1 58_Programmwahl_Warmwasser Automatikbetrieb
        fhem.0	2017-12-26 06:41:38.626	info	fhem.0.d_Wolf_BM1.57_Programmwahl_Heizkreis.Automatikbetrieb ==> writeFHEM: set d_Wolf_BM1 57_Programmwahl_Heizkreis Automatikbetrieb
        fhem.0	2017-12-26 06:41:38.476	info	fhem.0.d_Wolf_BM1.56_Warmwassersolltemperatur.60 ==> writeFHEM: set d_Wolf_BM1 56_Warmwassersolltemperatur 60
        fhem.0	2017-12-26 06:41:38.310	info	fhem.0.d_Wolf_BM1.55_Raumtemperatur.0 ==> writeFHEM: set d_Wolf_BM1 55_Raumtemperatur 0
        fhem.0	2017-12-26 06:41:38.149	info	fhem.0.d_Wolf_BM1.54_Aussentemperatur.6.3 ==> writeFHEM: set d_Wolf_BM1 54_Aussentemperatur 6.3
        fhem.0	2017-12-26 06:41:37.996	info	fhem.0.d_Wolf_BM1.53_Stoerung.false ==> writeFHEM: set d_Wolf_BM1 53_Stoerung false
        fhem.0	2017-12-26 06:41:37.838	info	fhem.0.d_Wolf_HG1.13_Anlagendruck.1.36 ==> writeFHEM: set d_Wolf_HG1 13_Anlagendruck 1.36
        fhem.0	2017-12-26 06:41:37.666	info	fhem.0.d_Wolf_HG1.12_Status_3_Wege_Umschaltventil.false ==> writeFHEM: set d_Wolf_HG1 12_Status_3_Wege_Umschaltventil false
        fhem.0	2017-12-26 06:41:37.645	info	fhem.0.d_Wolf_HG1.11_Status_Speicherladepumpe.false ==> writeFHEM: set d_Wolf_HG1 11_Status_Speicherladepumpe false
        fhem.0	2017-12-26 06:41:37.624	info	fhem.0.d_Wolf_HG1.10_Status_Heizkreispumpe.true ==> writeFHEM: set d_Wolf_HG1 10_Status_Heizkreispumpe true
        fhem.0	2017-12-26 06:41:37.446	info	fhem.0.d_Wolf_HG1.9_Status_Brenner_Flamme.true ==> writeFHEM: set d_Wolf_HG1 9_Status_Brenner_Flamme true
        • apollon77
          apollon77 last edited by
          Mach mal im iobroker Verzeichnis ein „sudo chmod -R 777 *“, das sollte deine Rechteprobleme beheben
          81.0k
