    4. Exception bei Installation Harmony Adapter
      Stmiko last edited by
      Würde gerne den Harmony Adapter testen. Leider bekomme ich ihn nicht installiert.
      Folgende exception wird geworfen:
      ` > iobroker 2015-08-15 19:33:37 info exit 25
      iobroker 2015-08-15 19:33:37 info Cannot install iobroker.harmony: 1
      iobroker 2015-08-15 19:33:37 info code 0
      iobroker 2015-08-15 19:33:37 info npm ERR! not ok
      iobroker 2015-08-15 19:33:37 info Additional logging details can be found in:npm ERR! /opt/npm-debug.log
      iobroker 2015-08-15 19:33:37 info ERR!
      iobroker 2015-08-15 19:33:37 info ERR! npm
      iobroker 2015-08-15 19:33:36 info npm ERR! type non_object_property_call
      iobroker 2015-08-15 19:33:36 info npm ERR! node -v v0.10.22npm ERR! npm -v 1.3.14
      iobroker 2015-08-15 19:33:36 info npm ERR! cwd /opt
      iobroker 2015-08-15 19:33:36 info npm ERR! command '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.harmony' '–production' '--prefix' '/opt/iobroker'
      iobroker 2015-08-15 19:33:36 info npm ERR! System Linux 4.0.9-v7+
      iobroker 2015-08-15 19:33:36 info npm ERR! or email it to:
      iobroker 2015-08-15 19:33:36 info npm ERR! If you need help, you may report this log at:
      iobroker 2015-08-15 19:33:36 info npm ERR! at _stream_readable.js:920:16
      iobroker 2015-08-15 19:33:36 info npm ERR! at IncomingMessage.EventEmitter.emit (events.js:117:20)
      iobroker 2015-08-15 19:33:36 info npm ERR! at IncomingMessage. (/usr/local/lib/node_modules/npm/node_modules/request/request.js:824:12)
      iobroker 2015-08-15 19:33:36 info npm ERR! at Request.EventEmitter.emit (events.js:117:20)
      iobroker 2015-08-15 19:33:36 info npm ERR! at Request. (/usr/local/lib/node_modules/npm/node_modules/request/request.js:873:14)
      iobroker 2015-08-15 19:33:36 info at Request.self.callback (/usr/local/lib/node_modules/npm/node_modules/request/request.js:129:22)npm ERR! at Request.EventEmitter.emit (events.js:98:17)
      iobroker 2015-08-15 19:33:36 info npm ERR! at RegClient. (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:252:14)
      iobroker 2015-08-15 19:33:36 info npm ERR! at RegClient. (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:119:29)npm ERR! at cb (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:158:9)
      iobroker 2015-08-15 19:33:36 info npm ERR! TypeError: Cannot call method 'match' of undefined
      iobroker 2015-08-15 19:33:36 info npm http 404 https://registry.npmjs.org/iobroker.harmony
      iobroker 2015-08-15 19:33:36 info http GET https://registry.npmjs.org/iobroker.harmony
      iobroker 2015-08-15 19:33:33 info npm install iobroker.harmony --production --prefix '/opt/iobroker' (System call)
      iobroker 2015-08-15 19:33:31 info add harmony `
      Danke für jede Hilfe!
        Vermutlich hat Pman noch nicht auf npm das gelegt.
        Momentan kannst du nur manuell installieren:
        cd /opt/iobroker
        npm install https://github.com/Pmant/ioBroker.harmony/tarball/master
        iobroker add harmony
          Prima….das hat funktioniert......vielen Dank 😄
            Pman last edited by
            Ich mache den npm publish sobald die Channel Struktur funktioniert, ausprobieren und berichten kannst du gerne schon.
