    4. [gelöst] Harmony Adapter unter Windows
      Kuddel last edited by
      ich teste gerade ioBroker auf einer Windows 10 VM zwecks mehr Ressourcen, vorallem RAM.
      Ich habe alle Adapter, die ich auf auf meinem PI habe installiert, nur der Harmony Adapter will nicht.
      Hier die Fehlermeldung aus dem Log
      2017-12-30 11:24:59.679  - [32minfo[39m: iobroker add harmony
      2017-12-30 11:25:00.020  - [32minfo[39m: host.ioBroker-Master instance system.adapter.tankerkoenig.0 started with pid 8288
      2017-12-30 11:25:00.442  - [32minfo[39m: iobroker npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
      2017-12-30 11:25:00.879  - [32minfo[39m: tankerkoenig.0 starting. Version 1.0.4 in C:/ioBroker/node_modules/iobroker.tankerkoenig, node: v4.5.0
      2017-12-30 11:25:01.066  - [32minfo[39m: tankerkoenig.0 objects written
      2017-12-30 11:25:01.426  - [32minfo[39m: host.ioBroker-Master instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      2017-12-30 11:25:02.504  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:02.504  - [32minfo[39m: iobroker  WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.5.0","npm":"2.15.9"})
      2017-12-30 11:25:02.707  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:02.707  - [32minfo[39m: iobroker  WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">2017-12-30 11:25:02.723  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker      at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)npm
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker  addRemoteGit
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker      at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)npm WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16
      npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5
      npm
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker  WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
      npm WARN
      2017-12-30 11:25:02.723  - [32minfo[39m: iobroker  addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      2017-12-30 11:25:02.754  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:02.754  - [32minfo[39m: iobroker ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefined
      2017-12-30 11:25:03.035  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:03.035  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm ERR! node v4.5.0
      npm ERR! npm  v2.15.9
      npm ERR! code ENOGIT
      2017-12-30 11:25:03.035  - [32minfo[39m: iobroker npm ERR! not found: git
      npm ERR!
      npm ERR!
      2017-12-30 11:25:03.035  - [32minfo[39m: iobroker  Failed using git.npm ERR! This is most likely not a problem with npm itself.
      2017-12-30 11:25:03.035  - [32minfo[39m: iobroker npm ERR! Please check if you have git installed and in your PATH.
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker  ERR! path C:\npm-debug.log.1735048264npm ERR!
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker code EPERM
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker npm ERR! errno -4048npm ERR! syscall open
      npm ERR! Error: EPERM: operation not permitted, open 'C:\npm-debug.log.1735048264'
      npm ERR!     at Error (native)
      npm ERR!  { [Error: EPERM: operation not permitted, open 'C:\npm-debug.log.1735048264']
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker npm ERR!   errno: -4048,npm ERR!   code: 'EPERM',
      npm ERR!   syscall: 'open',
      npm ERR!   path: 'C:\\npm-debug.log.1735048264' }
      npm
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker  ERR! npm ERR!
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker  Please try running this command again as root/Administrator.
      2017-12-30 11:25:03.098  - [32minfo[39m: iobroker npm ERR! Please include the following file with any support request:
      npm ERR!     C:\npm-debug.log
      2017-12-30 11:25:03.114  - [32minfo[39m: iobroker host.ioBroker-Master install adapter harmony
      2017-12-30 11:25:03.176  - [32minfo[39m: iobroker npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
      2017-12-30 11:25:04.942  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:04.942  - [32minfo[39m: iobroker  WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.5.0","npm":"2.15.9"})
      2017-12-30 11:25:05.098  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:05.098  - [32minfo[39m: iobroker WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">2017-12-30 11:25:05.145  - [32minfo[39m: iobroker npm WARN addRemoteGit Error: not found: git
      2017-12-30 11:25:05.145  - [32minfo[39m: iobroker npm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)npm WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)
      2017-12-30 11:25:05.145  - [32minfo[39m: iobroker npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16
      2017-12-30 11:25:05.145  - [32minfo[39m: iobroker npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5
      2017-12-30 11:25:05.145  - [32minfo[39m: iobroker      at FSReqWrap.oncomplete (fs.js:82:15)npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      2017-12-30 11:25:05.160  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:05.160  - [32minfo[39m: iobroker ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefined
      2017-12-30 11:25:05.239  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:05.239  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm
      2017-12-30 11:25:05.254  - [32minfo[39m: iobroker
      2017-12-30 11:25:05.254  - [32minfo[39m: iobroker ERR!
      2017-12-30 11:25:05.254  - [32minfo[39m: iobroker  code ENOGIT
      2017-12-30 11:25:05.254  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:05.254  - [32minfo[39m: iobroker  not found: gitnpm ERR!
      npm ERR! Failed using git.
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm ERR!
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm  v2.15.9
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm ERR! path C:\npm-debug.log.3240361705npm ERR! code EPERM
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm ERR! Error: EPERM: operation not permitted, open 'C:\npm-debug.log.3240361705'npm ERR!     at Error (native)
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm ERR!  { [Error: EPERM: operation not permitted, open 'C:\npm-debug.log.3240361705']npm ERR!   errno: -4048,
      npm ERR!
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker    path: 'C:\\npm-debug.log.3240361705' }npm ERR!
      npm ERR! Please try running this command again as root/Administrator.
      2017-12-30 11:25:05.317  - [32minfo[39m: iobroker npm ERR! Please include the following file with any support request:
      2017-12-30 11:25:05.332  - [32minfo[39m: iobroker host.ioBroker-Master install adapter harmony
      2017-12-30 11:25:05.395  - [32minfo[39m: iobroker npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
      2017-12-30 11:25:07.129  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.129  - [32minfo[39m: iobroker  WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.5.0","npm":"2.15.9"})
      2017-12-30 11:25:07.301  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.301  - [32minfo[39m: iobroker WARN
      2017-12-30 11:25:07.301  - [32minfo[39m: iobroker deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">2017-12-30 11:25:07.364  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.364  - [32minfo[39m: iobroker WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
      npm
      2017-12-30 11:25:07.364  - [32minfo[39m: iobroker WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)npm WARN
      2017-12-30 11:25:07.364  - [32minfo[39m: iobroker  addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16npm WARN
      2017-12-30 11:25:07.364  - [32minfo[39m: iobroker      at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5
      2017-12-30 11:25:07.364  - [32minfo[39m: iobroker   git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      2017-12-30 11:25:07.379  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.379  - [32minfo[39m: iobroker ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Daniel\AppData\Roaming\npm-cache\_git-remotes\https-github-com-swissmanu-ltx-git-634cc128: undefined
      2017-12-30 11:25:07.457  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.457  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      2017-12-30 11:25:07.457  - [32minfo[39m: iobroker npm ERR! not found: gitnpm ERR!
      npm ERR!
      2017-12-30 11:25:07.457  - [32minfo[39m: iobroker  Please check if you have git installed and in your PATH.
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker npm
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
      npm
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker ERR! npm  v2.15.9
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker  ERR! path C:\npm-debug.log.3705828459npm
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker ERR! code EPERMnpm ERR! errno -4048
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker npm ERR! Error: EPERM: operation not permitted, open 'C:\npm-debug.log.3705828459'npm ERR!     at Error (native)
      npm ERR!  { [Error: EPERM: operation not permitted, open 'C:\npm-debug.log.3705828459']
      npm ERR!   path: 'C:\\npm-debug.log.3705828459' }
      npm ERR!
      2017-12-30 11:25:07.504  - [32minfo[39m: iobroker npm ERR! Please include the following file with any support request:npm ERR!     C:\npm-debug.log
      2017-12-30 11:25:07.520  - [32minfo[39m: iobroker host.ioBroker-Master install adapter harmony
      2017-12-30 11:25:07.520  - [31merror[39m: iobroker host.ioBroker-Master Cannot install harmony
      2017-12-30 11:25:07.543  - [32minfo[39m: iobroker exit 13</https:></https:></https:>
      Irgendwie scheint er ein Problem mit GIT zu haben. Ich habe die Software (GitHub Desktop) allerdings bereits installiert.
      Kennt jemand das Problem?
      Vielen Dank schon einmal
        @Kuddel:
        Kennt jemand das Problem? `
        Ja, du hast es auch richtig erkannt, nur die falsche lösung genommen.
        Steht bereits irgendwo, ich finde es gerade auf dem Handy nicht
        Gruß Rainer
          @Homoran:
          @Kuddel:
          Gruß Rainer `
          Habe die Sucher angeworfen und folgenden Beitrag gefunden:
          http://forum.iobroker.net/viewtopic.php … ren#p50835
          Werde das jetzt mal testen
          EDIT: Jetzt konnte ich den Adapter installieren...
