    4. Fehlermeldungen bei Adapter Update
    • N
      Newmiraculix last edited by
      ich bekomme in der letzten Zeit immer Fehlermeldungen beim installieren oder updaten von Adaptern.
      Kann jemand von euch mir sagen, was das genaue Problem ist und wie ich es beseitigen kann? Am Ende funktioniert die Installation dann übrigens doch.
      $ ./iobroker upgrade ical
      Update ical from @1.3.2 to @1.4.0
      npm install iobroker.ical@1.4.0 --production --prefix "/opt/iobroker" (System call)
      node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.3.1/usb_bindings-v1.3.1-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.12.2 (node-v48 ABI) (falling back to source compile with node-gyp)
      ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefunden #include <libudev.h>^
      compilation terminated.make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
      gyp
      ERR! build error
      gyp
       ERR! stack Error: `make` failed with exit code: 2gyp
       ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
      stack     at emitTwo (events.js:106:13)gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp
      ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      gyp ERR! System Linux 4.9.59-v7+gyp
       ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"gyp ERR! cwd
       /opt/iobroker/node_modules/usbgyp ERR! node -v v6.12.2
      gyp ERR! node-gyp -v v3.6.0
      gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp
       ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
      node-pre-gyp ERR!
       stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)node-pre-gyp ERR!
       System Linux 4.9.59-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v6.12.2node-pre-gyp ERR!
       node-pre-gyp -v v0.6.32
      node-pre-gyp ERR! not ok</anonymous></libudev.h>
      • N
        Ist ein Linux Spezialist da? 🙂
        • Dutchman
          welche node und NPM version hast du drauf ?
          node -v
          npm -v
          • N
            node v6.12.2 und NPM 3.10.10
            • Dutchman
              @Newmiraculix:
              node v6.12.2 und NPM 3.10.10 `
              ok, habe de adapter auch geupdated gerade die gyp error kan man verwarlosen hatte ich auch laeuft aber durch.
              Steht bei dir am ende:
              got /opt/iobroker/node_modules/iobroker.ical/admin
              upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
              Update "system.adapter.ical.0"
              upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
              upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
              Adapter "ical" updated
              dan ist alles ok
              81.0k
