    4. [Fehler] Update sayit schlägt fehl
      michi050 last edited by
      ich habe noch die Version 1.6.1 des Text to speech Adapters installiert. Ein upgrade auf die neueste Version schlägt fehl unter Win 10. Kann mir jemand etwas dazu sagen?
      Vielen Dank im Voraus
      C:\ioBroker>npm install iobroker.sayit
      mdns@2.3.4 install C:\ioBroker\node_modules\iobroker.sayit\node_modules\mdns
      node-gyp rebuild
      C:\ioBroker\node_modules\iobroker.sayit\node_modules\mdns>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "" rebuild )
      Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
      dns_sd.cpp
      dns_service_browse.cpp
      dns_service_enumerate_domains.cpp
      dns_service_get_addr_info.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_enumerate_domains.cpp) [C:\ioBroker
      \node_modules\iobroker.sayit\node_modules\mdns\build\dns_sd_bindings.vcxproj]
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_sd.cpp) [C:\ioBroker\node_modules\iobroker.
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_get_addr_info.cpp) [C:\ioBroker\nod
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_browse.cpp) [C:\ioBroker\node_modul
      dns_service_process_result.cpp
      dns_service_ref.cpp
      dns_service_ref_deallocate.cpp
      dns_service_ref_sock_fd.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_process_result.cpp) [C:\ioBroker\no
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_ref_sock_fd.cpp) [C:\ioBroker\node_
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_ref.cpp) [C:\ioBroker\node_modules\
      dns_service_register.cpp
      dns_service_resolve.cpp
      dns_service_update_record.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_ref_deallocate.cpp) [C:\ioBroker\no
      mdns_utils.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_resolve.cpp) [C:\ioBroker\node_modu
      network_interface.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_register.cpp) [C:\ioBroker\node_mod
      socket_watcher.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\dns_service_update_record.cpp) [C:\ioBroker\nod
      txt_record_ref.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\mdns_utils.cpp) [C:\ioBroker\node_modules\iobro
      txt_record_create.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\network_interface.cpp) [C:\ioBroker\node_module
      txt_record_deallocate.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\socket_watcher.cpp) [C:\ioBroker\node_modules\i
      txt_record_set_value.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_ref.cpp) [C:\ioBroker\node_modules\i
      txt_record_get_length.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_create.cpp) [C:\ioBroker\node_module
      txt_record_buffer_to_object.cpp
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_deallocate.cpp) [C:\ioBroker\node_mo
      win_delay_load_hook.cc
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_set_value.cpp) [C:\ioBroker\node_mod
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_get_length.cpp) [C:\ioBroker\node_mo
      c:\iobroker\node_modules\iobroker.sayit\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file or directory (compiling source file ..\src\txt_record_buffer_to_object.cpp) [C:\ioBroker\n
      gyp ERR! build error
      gyp ERR! stack Error: C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.exe failed with exit code: 1
      gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:87:13)
      gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      gyp ERR! System Windows_NT 10.0.16299
      gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
      gyp ERR! cwd C:\ioBroker\node_modules\iobroker.sayit\node_modules\mdns
      gyp ERR! node -v v4.5.0
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm WARN optional dep failed, continuing mdns@2.3.4
      iobroker.sayit@1.6.6 install C:\ioBroker\node_modules\iobroker.sayit
      node main.js –install
      iobroker.sayit@1.6.6 node_modules\iobroker.sayit
      ├── ivona-node@0.2.0 (aws4@0.4.2)
      ├── jsftp@1.5.5 (unorm@1.4.1, once@1.4.0, parse-listing@1.1.3, stream-combiner@0.2.2, debug@2.6.9, ftp-response-parser@1.0.1)
      ├── castv2-client@1.2.0 (debug@2.6.9, castv2@0.1.9)
      └── aws-sdk@2.8.0 (sax@1.1.5, xml2js@0.4.15, querystring@0.2.0, uuid@3.0.0, url@0.10.3, jmespath@0.15.0, buffer@4.9.1, crypto-browserify@1.0.9, xmlbuilder@2.6.2)
      C:\ioBroker>
