    4. Zwave im ioBroker docker container auf Rpi3
    • X
      Xyolyp last edited by
      Moin,
      ich habe auf meinem Raspberry Pi 3 Docker laufen und seit gestern einen ioBroker Container (vergleichbar mit einer nativen Installation von ioBroker).
      Heute wollte ich meinen zwave Stick einbinden und schaffe es leider nicht.
      Log: (von unten nach oben lesen)
      host.black-pearl 2018-01-10 19:47:14.618 error instance system.adapter.zwave.0 terminated with code 0 (OK)
      host.black-pearl 2018-01-10 19:47:14.618 error Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      host.black-pearl 2018-01-10 19:47:14.617 error Caught by controller[0]: at Module._compile (module.js:570:32)
      host.black-pearl 2018-01-10 19:47:14.617 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
      host.black-pearl 2018-01-10 19:47:14.617 error Caught by controller[0]: at require (internal/module.js:20:19)
      host.black-pearl 2018-01-10 19:47:14.616 error Caught by controller[0]: at Module.require (module.js:497:17)
      host.black-pearl 2018-01-10 19:47:14.616 error Caught by controller[0]: at Function.Module._load (module.js:438:3)
      host.black-pearl 2018-01-10 19:47:14.616 error Caught by controller[0]: at tryModuleLoad (module.js:446:12)
      host.black-pearl 2018-01-10 19:47:14.616 error Caught by controller[0]: at Module.load (module.js:487:32)
      host.black-pearl 2018-01-10 19:47:14.615 error Caught by controller[0]: at Object.Module._extensions..node (module.js:597:18)
      host.black-pearl 2018-01-10 19:47:14.614 error Caught by controller[0]: at Error (native)
      host.black-pearl 2018-01-10 19:47:14.613 error Caught by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0 2018-01-10 19:47:14.513 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory at Error (native) at Object.Module._extensions..node (module.js:597:18) at Module.load (module.js:487:
      zwave.0 2018-01-10 19:47:14.472 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      Die Tipps von der Seite des zwave Adapters (sudo ldconfig, sudo ldconfig /usr/local, sudo ldconfig /usr/local/lib64) habe ich alle ausgeführt und nach jeder Ausführung getestet. Leider hat nichts geholfen. Hat hier noch jemand eine Idee?
      Danke schonmal im Vorraus
      Jonathan
      • Dutchman
        Du musst den Usb port/Stick an docker weiterleiten sonst sieht er ihn nicht.
        Send from mobile device
        • X
          Ich hatte den falschen Adapter weitergeleitet. Aus einem Tutorial hatte ich /dev/ttyAMA0 übernommen, aber mein Stick war logischerweise unter /dev/ttyUSB0.
          Das Problem ist soweit behoben 🙂
