    4. Installationsprobleme Raspi3
      ASommer last edited by
      ich habe einen neuen Raspi 3. Bin genau nach der Installationsanleitung gegangen.
      Aber unter xxx.xxx.xxx.xxx:8081 startet der ioBrocker nicht.
      Hatte vorher einen Raspi 1. Jetzt dachte ich das es mit dem 3er besser geht. Aber auch da will er nicht immer.
      Er hat als die SD Karte noch frisch war …(gleich nach der Installation) den ioBroker gestartet.
      Nachdem ich````
      sudo apt-get update && sudo apt-get upgrade -y
      ps -ef |grep io
      root 9 2 0 16:52 ? 00:00:00 [migration/0]
      root 13 2 0 16:52 ? 00:00:00 [migration/1]
      root 18 2 0 16:52 ? 00:00:00 [migration/2]
      root 23 2 0 16:52 ? 00:00:00 [migration/3]
      root 34 2 0 16:52 ? 00:00:00 [bioset]
      root 38 2 0 16:52 ? 00:00:00 [rpciod]
      root 39 2 0 16:52 ? 00:00:00 [xprtiod]
      root 42 2 0 16:52 ? 00:00:00 [nfsiod]
      root 53 2 0 16:52 ? 00:00:00 [bioset]
      root 54 2 0 16:52 ? 00:00:00 [bioset]
      root 55 2 0 16:52 ? 00:00:00 [bioset]
      root 56 2 0 16:52 ? 00:00:00 [bioset]
      root 57 2 0 16:52 ? 00:00:00 [bioset]
      root 58 2 0 16:52 ? 00:00:00 [bioset]
      root 59 2 0 16:52 ? 00:00:00 [bioset]
      root 60 2 0 16:52 ? 00:00:00 [bioset]
      root 61 2 0 16:52 ? 00:00:00 [bioset]
      root 62 2 0 16:52 ? 00:00:00 [bioset]
      root 63 2 0 16:52 ? 00:00:00 [bioset]
      root 64 2 0 16:52 ? 00:00:00 [bioset]
      root 65 2 0 16:52 ? 00:00:00 [bioset]
      root 66 2 0 16:52 ? 00:00:00 [bioset]
      root 67 2 0 16:52 ? 00:00:00 [bioset]
      root 68 2 0 16:52 ? 00:00:00 [bioset]
      root 69 2 0 16:52 ? 00:00:00 [bioset]
      root 70 2 0 16:52 ? 00:00:00 [bioset]
      root 71 2 0 16:52 ? 00:00:00 [bioset]
      root 72 2 0 16:52 ? 00:00:00 [bioset]
      root 73 2 0 16:52 ? 00:00:00 [bioset]
      root 74 2 0 16:52 ? 00:00:00 [bioset]
      root 75 2 0 16:52 ? 00:00:00 [bioset]
      root 76 2 0 16:52 ? 00:00:00 [bioset]
      root 80 2 0 16:52 ? 00:00:00 [DWC Notificatio]
      root 91 2 0 16:52 ? 00:00:00 [bioset]
      avahi 324 1 0 16:52 ? 00:00:00 avahi-daemon: running [ioBroker-Pi.local]
      message+ 335 1 0 16:52 ? 00:00:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
      root 573 1 1 16:53 ? 00:00:06 iobroker.js-controller
      root 642 573 1 16:53 ? 00:00:06 /usr/bin/node /opt/iobroker/node_modules/iobroker.admin/admin.js 0 info
      root 726 573 0 16:53 ? 00:00:04 /usr/bin/node /opt/iobroker/node_modules/iobroker.web/main.js 0 info
      root 778 573 0 16:53 ? 00:00:04 /usr/bin/node /opt/iobroker/node_modules/iobroker.vis/main.js 0 info
      root 830 573 0 16:53 ? 00:00:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.history/history.js 0 info
      root 882 573 1 16:53 ? 00:00:05 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/javascript.js 0 info
      root 932 573 0 16:53 ? 00:00:04 /usr/bin/node /opt/iobroker/node_modules/iobroker.socketio/main.js 0 info
      root 956 573 0 16:53 ? 00:00:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.rpi2/main.js 0 info
      pi 2634 702 0 17:01 pts/0 00:00:00 grep --color=auto io
      Wenn ich "sudo iobroker start" eingebe kommt folgendes.
      iobroker controller daemon already running. PID: 573
      iobroker start all kommt es zu dieser Meldung
      sudo iobroker start all
      No connection to states 127.0.0.1:6379[redis]
      Was kann ich machen?
      So einfach wie immer beschrieben ist es anscheinend nicht.
      ioBroker auf einem Raspi zum laufen zu bekommen.
      Danke schon mal im Vorfeld für eure Unterstützung. Würde ioBroker gerne nutzen.
        @ASommer:
        Aber unter xxx.xxx.xxx.xxx:8081 startet der ioBrocker nicht. `
        Wann war das?
        kurzfristig war zwischenzeitlich ein Bug in den Installationsscript.
        @ASommer:
        So einfach wie immer beschrieben ist es anscheinend nicht. `
        Da hast du recht!
        Es ist viel einfacher.
        • eric2905
          eric2905 last edited by
          Welche Node und npm Versionen hast Du?
          node -v
          npm -v
          Nicht das Du Dir mit dem Systemupdate ein npm 5 „eingefangen“ hast.
          Gruß,
          Eric
          Von unterwegs getippert
            @eric2905:
            node -v
            v6.12.3
            @eric2905:
            npm -v
            3.10.10
            Ich habe vor 3 Stunden das Image heruntergeladen. Danach update und Upgrade.
            Jetzt will iobroker nicht mehr starten.
            Folgendes Image und Anleitung
            http://www.iobroker.net/docu/?page_id=7603&lang=de
            Was ich nicht gemacht habe ist die Datei io-package.json gesichert. Muss ich das machen ??? Kann das Problem daran liegen?
            Wie sichere ich eine Datei. Bin Linux Anfänger.
            Danke für eure Hilfe
            • eric2905
              Du hast aber nicht nochmal ioBroker nach dieser Anleitung installiert?
              http://www.iobroker.net/docu/?page_id=5106&lang=de
              Was kommt denn, wenn Du
              sudo iobroker restart
              eingibt?
              Ein reboot hat nicht geholfen?
              Gruß,
              Eric
                @eric2905:
                http://www.iobroker.net/docu/?page_id=5106&lang=de `
                Nein. Nur mehrmals reboot gemacht…. Netzteil ausgewechselt. Stromlos gemacht. Mehr habe ich nicht gemacht.
                @eric2905:
                eingibt? `
                Pi:~ $ sudo iobroker restart
                Stopping iobroker controller daemon...
                Mehr nicht läuft jetzt seit 5 Minuten und nichts geht weiter. Hat sich aufgehangen. …. Wie lange dauert es eigentlich bis ioBroker nach reboot wieder bereits ist?
                  Es gibt Installationen, da dauert es etwa 10 Minuten bis ioBroker gestoppt ist.
                  Habe das auch schon selber erlebt, kann aber bisher nicht herausfinden woran das liegt.
                    @Homoran:
                    Rainer `
                    Auch nach einer Stunde passiert nichts mehr.
                      Das ist zu lange.
                      Steht etwas im log?
                      Gruß Rainer
                        @Homoran:
                        Das ist zu lange.
                        Steht etwas im log?
                        Gruß Rainer `
                        Wie kann ich das aufrufen?
                          Es befindet sich im Verzeichnis /opt/iobroker/log
                          Jeweils das log der letzten 7 tage mit datum.
                          Aber das image müsste out of the box laufen.
                          Auch durch ein apt-get update && apt-get upgrade sollte es nicht zu einem Hänger kommen.
                          Gruß Rainer
                            @Homoran:
                            Jeweils das log der letzten 7 tage mit datum. `
                            ! 2018-01-11 20:56:46.680 - info: host.ioBroker-Pi InMemoryDB connected 2018-01-11 20:56:46.708 - info: host.ioBroker-Pi 13 instances found 2018-01-11 20:56:46.735 - info: host.ioBroker-Pi starting 7 instances 2018-01-11 20:56:46.811 - info: host.ioBroker-Pi instance system.adapter.admin. 0 started with pid 1492 2018-01-11 20:56:47.486 - info: iobroker Starting node restart.js 2018-01-11 20:56:47.524 - info: iobroker exit 0 2018-01-11 20:56:47.927 - info: host.ioBroker-Pi received SIGTERM 2018-01-11 20:57:09.920 - info: host.ioBroker-Pi iobroker.js-controller version 1.2.1 js-controller starting 2018-01-11 20:57:09.936 - info: host.ioBroker-Pi Copyright (c) 2014-2017 bluefo x, 2014 hobbyquaker 2018-01-11 20:57:09.937 - info: host.ioBroker-Pi hostname: ioBroker-Pi, node: v 6.12.3 2018-01-11 20:57:09.939 - info: host.ioBroker-Pi ip addresses: xxx.xxx.xxx.xxx f e80::4ffd:xxxxxxxxx 2018-01-11 20:57:10.192 - info: host.ioBroker-Pi inMem-objects listening on po rt 9001 2018-01-11 20:57:10.223 - error: Another instance is running or some applicatio n uses port! 2018-01-11 20:57:10.223 - error: uncaught exception: listen EADDRINUSE 127.0.0\. 1:9001 2018-01-11 20:57:10.243 - info: iobroker _restart 2018-01-11 20:57:10.261 - info: host.ioBroker-Pi InMemoryDB connected 2018-01-11 20:57:10.288 - info: host.ioBroker-Pi 13 instances found 2018-01-11 20:57:10.315 - info: host.ioBroker-Pi starting 7 instances 2018-01-11 20:57:10.397 - info: host.ioBroker-Pi instance system.adapter.admin. 0 started with pid 1566 2018-01-11 20:57:11.091 - info: iobroker Starting node restart.js 2018-01-11 20:57:11.129 - info: iobroker exit 0 2018-01-11 20:57:11.520 - info: host.ioBroker-Pi received SIGTERM 2018-01-11 20:57:11.523 - info: host.ioBroker-Pi stopInstance system.adapter.ad min.0 2018-01-11 20:57:11.524 - info: host.ioBroker-Pi stopInstance system.adapter.ad min.0 killing pid 1566 2018-01-11 20:57:11.526 - info: host.ioBroker-Pi stopInstance system.adapter.di scovery.0 2018-01-11 20:57:11.527 - warn: host.ioBroker-Pi stopInstance system.adapter.di scovery.0 not running 2018-01-11 20:57:11.527 - info: host.ioBroker-Pi stopInstance system.adapter.hm -rpc.0 2018-01-11 20:57:11.528 - warn: host.ioBroker-Pi stopInstance system.adapter.hm -rpc.0 not running 2018-01-11 20:57:11.528 - info: host.ioBroker-Pi stopInstance system.adapter.hm -rega.0 2018-01-11 20:57:11.528 - warn: host.ioBroker-Pi stopInstance system.adapter.hm -rega.0 not running 2018-01-11 20:57:11.529 - info: host.ioBroker-Pi stopInstance system.adapter.we b.0 2018-01-11 20:57:11.529 - warn: host.ioBroker-Pi stopInstance system.adapter.we b.0 not running 2018-01-11 20:57:11.529 - info: host.ioBroker-Pi stopInstance system.adapter.vi s.0 2018-01-11 20:57:11.530 - info: host.ioBroker-Pi stopInstance system.adapter.hi story.0 2018-01-11 20:57:11.530 - warn: host.ioBroker-Pi stopInstance system.adapter.hi story.0 not running 2018-01-11 20:57:11.530 - info: host.ioBroker-Pi stopInstance system.adapter.ja vascript.0 2018-01-11 20:57:11.530 - warn: host.ioBroker-Pi stopInstance system.adapter.ja vascript.0 not running 2018-01-11 20:57:11.531 - info: host.ioBroker-Pi stopInstance system.adapter.mo bile.0 2018-01-11 20:57:11.532 - info: host.ioBroker-Pi stopInstance system.adapter.so cketio.0 2018-01-11 20:57:11.532 - warn: host.ioBroker-Pi stopInstance system.adapter.so cketio.0 not running 2018-01-11 20:57:11.533 - info: host.ioBroker-Pi stopInstance system.adapter.cl oud.0 2018-01-11 20:57:11.533 - warn: host.ioBroker-Pi stopInstance system.adapter.cl oud.0 not running 2018-01-11 20:57:11.533 - info: host.ioBroker-Pi stopInstance system.adapter.rp i2.0 2018-01-11 20:57:11.533 - warn: host.ioBroker-Pi stopInstance system.adapter.rp i2.0 not running 2018-01-11 20:57:11.542 - warn: host.ioBroker-Pi instance system.adapter.admin. 0 terminated due to SIGTERM 2018-01-11 20:57:11.545 - info: host.ioBroker-Pi instance system.adapter.admin. 0 terminated with code null () 2018-01-11 20:57:11.546 - info: host.ioBroker-Pi All instances are stopped. addresses: xxxxxxxxxxxxx fe80::xxxxxxxxxxxxxxx 2018-01-11 20:57:26.885 - info: host.ioBroker-Pi inMem-objects listening on po rt 9001 2018-01-11 20:57:26.913 - error: Another instance is running or some applicatio n uses port! 2018-01-11 20:57:26.914 - error: uncaught exception: listen EADDRINUSE 127.0.0\. 1:9001 2018-01-11 20:57:26.933 - info: iobroker _restart 2018-01-11 20:57:26.952 - info: host.ioBroker-Pi InMemoryDB connected 2018-01-11 20:57:26.979 - info: host.ioBroker-Pi 13 instances found 2018-01-11 20:57:27.006 - info: host.ioBroker-Pi starting 7 instances 2018-01-11 20:57:27.086 - info: host.ioBroker-Pi instance system.adapter.admin. 0 started with pid 1663 2018-01-11 20:57:27.754 - info: iobroker Starting node restart.js 2018-01-11 20:57:27.784 - info: iobroker exit 0 2018-01-11 20:57:28.195 - info: host.ioBroker-Pi received SIGTERM 2018-01-11 20:57:34.993 - info: host.ioBroker-Pi iobroker.js-controller version 1.2.1 js-controller starting 2018-01-11 20:57:35.009 - info: host.ioBroker-Pi Copyright (c) 2014-2017 bluefo x, 2014 hobbyquaker 2018-01-11 20:57:35.013 - info: host.ioBroker-Pi hostname: ioBroker-Pi, node: v 6.12.3 2018-01-11 20:57:35.015 - info: host.ioBroker-Pi ip addresses: 192.168.178.43 f e80::4ffd:2e9e:ee5d:bc93 2018-01-11 20:57:35.271 - info: host.ioBroker-Pi inMem-objects listening on po rt 9001 2018-01-11 20:57:35.299 - error: Another instance is running or some applicatio n uses port! 2018-01-11 20:57:35.299 - error: uncaught exception: listen EADDRINUSE 127.0.0\. 1:9001 2018-01-11 20:57:35.319 - info: iobroker _restart 2018-01-11 20:57:35.338 - info: host.ioBroker-Pi InMemoryDB connected 2018-01-11 20:57:35.365 - info: host.ioBroker-Pi 13 instances found 2018-01-11 20:57:35.393 - info: host.ioBroker-Pi starting 7 instances 2018-01-11 20:57:35.470 - info: host.ioBroker-Pi instance system.adapter.admin. 0 started with pid 1711 2018-01-11 20:57:36.131 - info: iobroker Starting node restart.js 2018-01-11 20:57:36.174 - info: iobroker exit 0 2018-01-11 20:57:36.576 - info: host.ioBroker-Pi received SIGTERM 2018-01-11 20:58:11.820 - info: host.ioBroker-Pi received SIGTERM 2018-01-11 20:58:13.378 - info: host.ioBroker-Pi instance system.adapter.admin. 0 terminated with code 0 (OK) 2018-01-11 20:58:13.384 - info: host.ioBroker-Pi instance system.adapter.vis.0 terminated while should be started once 2018-01-11 20:58:06.811 - info: host.ioBroker-Pi iobroker.js-controller version 1.2.1 js-controller starting 2018-01-11 20:58:06.831 - info: host.ioBroker-Pi Copyright (c) 2014-2017 bluefo x, 2014 hobbyquaker 2018-01-11 20:58:06.834 - info: host.ioBroker-Pi hostname: ioBroker-Pi, node: v 6.12.3 2018-01-11 20:58:06.836 - info: host.ioBroker-Pi ip addresses: xxxxxxxxxxxxxxxxxxxxxx 2018-01-11 20:58:07.211 - info: host.ioBroker-Pi inMem-objects listening on po rt 9001 2018-01-11 20:58:07.245 - info: host.ioBroker-Pi InMemoryDB connected 2018-01-11 20:58:07.275 - info: host.ioBroker-Pi 13 instances found 2018-01-11 20:58:07.301 - info: host.ioBroker-Pi starting 7 instances 2018-01-11 20:58:07.419 - info: host.ioBroker-Pi instance system.adapter.admin. 0 started with pid 611 2018-01-11 20:58:11.333 - info: host.ioBroker-Pi instance system.adapter.web.0 started with pid 670 2018-01-11 20:58:19.334 - info: host.ioBroker-Pi instance system.adapter.histor y.0 started with pid 792 2018-01-11 21:00:44.269 - info: host.ioBroker-Pi instance system.adapter.javasc ript.0 started with pid 834 2018-01-11 21:00:48.318 - info: host.ioBroker-Pi instance system.adapter.socket io.0 started with pid 870 2018-01-11 21:00:52.293 - info: host.ioBroker-Pi instance system.adapter.rpi2.0 started with pid 876 !
                            Das ist das was nach dem letzten reboot rausgekommen ist.
                              Hat keiner einen Lösungsansatz für mich 😞
                              • eric2905
                                Nun mal langsam …
                                Nach 10 Stunden so ein Posting nachschieben ist ....
                                Alle sind hier in ihrer Freizeit und schauen sich Postings und Probleme an, wenn Sie Zeit (und Lust) haben.
                                Gruß,
                                Eric
                                • eric2905
                                  Hast Du irgendwas im Admin- oder Web-Adapter eingestellt/verändert, bevor es nicht mehr ging?
                                  Die Zeile
                                  2018-01-11 20:57:26.914  - error: uncaught exception: listen EADDRINUSE 127.0.0.1:9001
                                  im Log irritiert mich ein wenig.
                                    Vielleicht wahr das Smilie nicht das richtige. Vielleicht wäre ein weinendes Smilie das richtige gewessen.
                                    Bin halt gespannt darauf wie ioBrokere funktioniert.
                                    Da ich schon vor ein paar Tagen mit einem Raspi 1 angefangen habe, mit fast den selben Probleme , bin ich halt noch gespannter darauf, weil mein Raspi3 gestern gekommen ist.
                                    Ich dachte halt mit einem fertigen Image und einem Raspi3 bekommt man das ganz einfach zum laufen.
                                    Lief ja auch, nur halt nach````
                                    Ob ich mit dem Port 8081 oder 8082 versuche, beide sind nicht erreichbar.
                                    Bitte beim letzten Eintrag von mir berücksichtigen, dass ich sehr gespannt auf ioBroker bin und nicht sauer oder enttäuscht von der Community
                                    • eric2905
                                      Ich habe Dir oben noch eine Frage gestellt.
                                      Schau mal bitte.
                                        @eric2905:
                                        Hast Du irgendwas im Admin- oder Web-Adapter eingestellt/verändert, bevor es nicht mehr ging? `
                                        Nein!
                                        Ich habe das Image auf die SD Karte gepackt.
                                        danach :
                                        Expand filesystem (Erweitern des root-filesystems bis zur maximalen Größe der verwendeten SD-Karte)
                                        Change User passwort (Eigenes Passwort für den User Pi vergeben)
                                        und
                                        Parallel mal geguckt, ob der ioBroker über web xxx.xxx.xxx.43:8081 erreichbar ist. Wahr er auch.
                                        Dann reboot und er hat nicht mehr gestartet.
                                          @Eric
                                          Dann müssen wir mal den armen @ASommer quälen, ob Raspbian 20171129, das nach dem upgrade jetzt wohl drauf ist wieder etwas verbogen hat, wie in den anderen Threads zu Raspbian 20171129.
                                          Kannst du das übernehmen, wenn @ASommer mitmacht?
                                          • eric2905
                                            Ok, mach ich.
                                            @ASommer:
                                            Wenn es Dir recht ist, werden wir ein wenig testen.
                                            Evtl. ist im letzten Update des Raspi was drin, was die ioBroker-Installation killt.
                                            Lade Dir mal bitte das aktuelle Original-Raspi-Image von der Webseite (Noobs : https://www.raspberrypi.org/downloads/) und kopiere den Inhalt des ZIP-Files auf eine leere SD.
                                            Dann startest Du davon und installierst das OS.
                                            Dann melde Dich bitte wieder.
                                            Gruß,
                                            Eric
                                            2950
