    4. [Gelöst] Flot installations Probleme
    • E
      eXplOiD last edited by
      Guten Tag,
      mein Flot funktioniert nicht,
      ich bekomme bei der installation eine reihe an fehlern, eventuell kann jemand von euch ja damit was anfangen.
      $ ./iobroker add flot
      npm install iobroker.flot –production --prefix "/mnt/iobroker" (System call)
      node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... x64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@8.8.0 (node-v57 ABI) (falling back to source compile with node-gyp)
      ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: Datei oder Verzeichnis nicht gefundencompilation terminated.
      make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Fehler 1
      gyp
      ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/mnt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
      gyp ERR! stack at emitTwo (events.js:125:13)
      gyp ERR! stack at ChildProcess.emit (events.js:213:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      gyp ERR! System Linux 4.4.0-104-generic
      gyp ERR! command "/usr/local/bin/node" "/mnt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "–fallback-to-build" "--module=/mnt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/mnt/iobroker/node_modules/usb/src/binding"
      gyp ERR! cwd /mnt/iobroker/node_modules/usb
      gyp ERR! node -v v8.8.0
      gyp ERR! node-gyp -v v3.6.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /mnt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/mnt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/mnt/iobroker/node_modules/usb/src/binding' (1)
      node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/mnt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:125:13)
      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:213:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:927:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      node-pre-gyp ERR! System Linux 4.4.0-104-generic
      node-pre-gyp ERR! command "/usr/local/bin/node" "/mnt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /mnt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v8.8.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.36
      node-pre-gyp ERR! not ok
      npm
      WARN
      optional
      SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
      npm
      WARN
      notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
      WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup
      SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      host.homeserver install adapter flot
      npm install --production (System call) in "/mnt/iobroker/node_modules/iobroker.flot"
      got /mnt/iobroker/node_modules/iobroker.flot/admin
      upload [0] flot.admin /mnt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
      got /mnt/iobroker/node_modules/iobroker.flot/www
      upload [30] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/js/jquery.flot.hiddengraphs.js lib/js/jquery.flot.hiddengraphs.js application/javascript
      upload [20] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/preview-opacity.png lib/css/images/preview-opacity.png image/png
      upload [19] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map.png lib/css/images/map.png image/png
      upload [18] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-pointer.png lib/css/images/map-pointer.png image/png
      upload [17] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/map-opacity.png lib/css/images/map-opacity.png image/png
      upload [16] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar.png lib/css/images/bar.png image/png
      upload [15] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-pointer.png lib/css/images/bar-pointer.png image/png
      upload [14] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-opacity.png lib/css/images/bar-opacity.png image/png
      upload [13] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/bar-alpha.png lib/css/images/bar-alpha.png image/png
      upload [12] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/map.png lib/css/images/128/map.png image/png
      upload [11] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar.png lib/css/images/128/bar.png image/png
      upload [10] flot /mnt/iobroker/node_modules/iobroker.flot/www/lib/css/images/128/bar-alpha.png lib/css/images/128/bar-alpha.png image/png
      upload [9] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/words.js js/words.js application/javascript
      upload [8] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/settings.js js/settings.js application/javascript
      upload [7] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
      upload [6] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/data.js js/data.js application/javascript
      upload [5] flot /mnt/iobroker/node_modules/iobroker.flot/www/js/chart.js js/chart.js application/javascript
      upload [4] flot /mnt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
      upload [3] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/resetZoom.png img/resetZoom.png image/png
      upload [2] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
      upload [1] flot /mnt/iobroker/node_modules/iobroker.flot/www/img/edit.svg img/edit.svg image/svg+xml
      upload [0] flot /mnt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
      host.homeserver object system.adapter.flot created
      host.homeserver object _design/chart created
      host.homeserver create instance flot
      host.homeserver object system.adapter.flot.upload created
      host.homeserver object system.adapter.flot.0 created
      process exited with code 0</anonymous>
      • Dutchman
        Die Fehler von gyp sind normal und nicht schlimm, desweiteren sehe ich das die mit upload endet also erfolgreich war.
        Hat du mal unter Instanzen geschaut ob er jetzt dabei steht?
        Send from mobile device
        • E
          @Dutchman:
          Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community `
          ja die Instanz ist da aber wie schon beschrieben funktioniert da nichts ich sehe unten ein dauerhaften ladebalken und objekte auswählen kann ich auch nicht.
          • E
            @Dutchman:
            ich sehe aber das er versucht usb bindings zu installieren das aber nicht geht weil die angegebene adresse nicht mehr existiert.
            • apollon77
              apollon77 last edited by
              Das hat aber mal nichts mit den Fehlern zu tun. Starte mal die Web Instanz neu
              • E
                @apollon77:
                Das hat aber mal nichts mit den Fehlern zu tun. Starte mal die Web Instanz neu `
                erledigt, aber keine veränderung.
                die browser konsole zeigt mir dort aber auch nix an
                • E
                  ~~![](</s><URL url=)https://www2.pic-upload.de/img/34602628/Unbenannt-1.png" />
                  ![](</s><URL url=)https://www2.pic-upload.de/img/34602625/Unbenannt-2.png" />~~
                  • Dutchman
                    Hat du überhaupt history oder einen anderen datenlogger (zB MySQL Adapter) installiert und zeichnest Daten auf ?
                    Die selber geht ja wie ich aus dem Screenshot erkenne sehr nur keine Datenpunkte
                    • E
                      @Dutchman:
                      ja ich habe history installiert
                      • E
                        @Dutchman:
                        richtig weil mir flot keine Datenpunkte anzeigt warum auch immer
                        • Dutchman
                          Und auch logging für Datenpunkte aktiviert?
                          Schau Mal bei den objecten ob überhaupt was aufgezeichnet ist.
                          Zudem in flot links anstatt Default Mal history selektieren
                          • E
                            geht jetzt danke habe im admin_beta nicht gesehen das man den harken noch setzen muss im alten admin war er zu sehen und hatte anschließend auch datenpunkte.
                            Dankeschön
                            1418
